Question about Avanti W1092F Front Load Washer
I am looking for repair parts for an Avanti W1092, specifically the damper shocks springs. Does anyone know where would be a good place to look? I did call the US rep in Miami and they had a couple of things.
2 Suggested Answers
  • 63 Answers
SOURCE: looking for parts for Avanti g20aw
Go to www.repairclinic.com. You will need the model number. You will see all the parts available for this unit. Good luck.
Posted on Sep 29, 2009
How do i fix my jenn-air refrigerator JSD2488DEB .The damper door and spring fell off while removing a part.I have no idea where the spring is placed?
Parts for Jenn Air JSD2488DEB Shelves Accessories Parts
This might help. However you could try putting the damper door in without the spring and moving it through its open and closing to see what is near the door the spring could hook to. Look for small holes or tabs.
Dec 31, 2014 | Jenn-Air Refrigerators
Does the jeep liberty have both shocks and struts ? I have uneven tire ware on right side of Jeep the outside edge of tire both front and back on right side
it has struts in front and shocks in rear have a professional do a front end alinement and check strut and shock perfomence they may have to road test.
Jun 29, 2010 | 2003 Jeep Liberty
Shaking a lot seams out of balance, what to do?
take off back panel and see if the retaining springs are loose or came off.
there should be 4-8 springs.
Feb 16, 2010 | LG WM-2277HW Front Load Washer
Shakes bad during spin can shocks and springs wear out how do you replace them?
Usually, the damper system has dislodged or misaligned causing this problem. Open the top and shake the outer drum assembly to find the offending part(s). Repair is usually simple unless something has broken loose. A mounting bolt may be lying on the floor under the machine. Good luck!
Feb 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite tub shaking badly
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 10, 2009 | Kenmore Elite 45986 Front Load Washer
Looking for parts for Avanti g20aw
Sep 29, 2009 | Avanti G20AW-1 Gas Kitchen Range
Remove/replace shock absorber assembly 900s 1995 saab
  1. Slightly loosen hub center nut when all four wheels are on ground.
  2. Raise and support vehicle, then remove five wheel bolts and wheel.
  3. Remove hub center nut, then the wheel sensor,
  4. Press back brake piston using slip-joint pliers,
  5. Remove caliper from steering swivel member, then suspend in wheel housing with cable tie.
  6. Remove brake disc and back plate, then slightly loosen tie rod end nut.
  7. Press out tie rod end nut using puller tool or equivalent.
  8. Remove nut and tie rod end bolt, then the anti-roll bar to swinging arm nut.
  9. Remove outer ball joint nut.
  10. Press ball joint out of steering swivel member using puller tool or equivalent, installed on spring link.
  11. Remove nut and discard. This self-locking nut must not be reused.
  12. Remove three upper mounting nuts for MacPherson strut, then the strut.
  13. Clamp MacPherson strut in vice.
  14. Compress spring using spring compressor or equivalents.
  15. Hold piston rod and remove nut using MacPherson strut socket tool 89 96 662, or equivalent. This is a self-locking nut and must not be reused.
  16. Remove mounting and top spring seat, then the coil spring, gaiter and compression stop.
  17. Unscrew damper using wrench tool No. 89 96 670, or equivalent, then remove damper from strut.
  18. Reverse procedure to install, noting the following:
    1. Screw damper in place using wrench tool No. 89 96 670, or equivalent.
    2. Lower end of coil spring should abut against stop in bottom of spring cup.
    3. Position MacPherson strut on vehicle and install three retaining nuts on top mounting. Tighten nuts alternately, according to specifications.
    4. Always use new hub center nut with self-locking threads.
Jun 04, 2009 | 1995 Saab 900
98 cadillac deville needs rear shocks
I have a 1998 Deville and both rear coil springs are broken.. It also has the air shocks that I dont think work.. Can I put regular shocks in and is there a after market coil spring out there for it ??
Mar 12, 2009 | 1998 Cadillac DeVille
1988 Avanti Convertible
You may have already found this site:
http://theavanti.com/parts.htm
But if not, it seems a good place to start.
I empathize with your plight; I have a Bertone '87 X1/9, my favorite car of all time but have been fortunate in finding a low-mileage parts car in case I need any.
I grew up in original Avanti-land; South Bend, IN.
Aug 26, 2008 | Avanti Convertible Cars & Trucks
Tub wobbles terrably in spin mode
Try lifting the inner drum to check if there is any movement between the inner and outer drums, also turn the drum and listen for any grinding or scraping sound from the rear of the drum. Its possible that your bearings have gone out & need to be replaced. The job is far from easy.
Mar 16, 2008 | Kenmore 98702 Stacked Washer/Dryer
Avanti W1092F Front Load Washer Logo
48 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
No_ky
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
