Question about Dewalt Heavy - Duty 12" Double - Bevel Sliding Compound Miter Saw
How to change the head locking pin - Dewalt Heavy - Duty 12" Double - Bevel Sliding Compound Miter Saw
Take it to TAW in Marple..I have the number.. Minge
Posted on Jul 08, 2010
Kitchenaid mixer will not lock
If it is new take it back and get a service agent to sort it out for you. The solution can often involve filing out the locking slot. Make sure that the hinge pin is locked tight and that the head height is set correctly. Incorrect head height can certainly prevent the head locking.
Feb 16, 2015 | KitchenAid Food Mixers
Timing marks
You need locking pins for both cam shaft pulleys as well as for the crank. The cam pulleys each have a hole in them which line up with a hole in the cylinder head through which an 8mm bolt cam be used to lock them. If you are looking at the cam pulleys from the RH fender side, the LH pulley hole locks at about 5 o'clock and the RH pulley at about 7 o'clock.
The crank locking pin is in an awkward position and a bit difficult to access. the hole is behind the oil filter housing and the pin locks into a hole in the back of the flywheel.
Please note that if your cam belt has snapped this engine will bend valves. If it is a scheduled belt change then it is quite easy to line up the marks and do the belt replacement.
Apr 27, 2014 | 2005 Citroen C3 1.6i
Uppa baby vista won't lock into place when open
This is what will work. First get some WD-40 and spray it around the jammed locking pin. Give the lubricant 10 mins and then get a knife or flat head screwdriver. What you will want to do is try to pry the locking pin up. Be gentle as you are dealing with plastic and if you break the plastic locking pin your stroller is done. As you slowly pry the pin upwards you will feel or see grooves which you can use to continue to raise the locking pin. Once the locking pin is unjammed push down on it a few times to get dust,dirt or sand out of the locking pin. The pin should pop up freely every time you push down on it and let go.
Hope that helps as I also had the same issue.
Aug 25, 2012 | Vista UPPAbaby - Carlin Stroller
Head won't lift without force. The head lock is in the Unlock position but it doesn't lift up easily. I have to stand behind the unit and use a lot of force to pull it up. It was fine one minute...
Presuming all looks OK near pivot & lock mechinism? can you see the locking hook in rear of mixer head at the hinge area directly behind lock lever, and is it nested in the slot on the base, or is it jamming up outside the stand and scratching it up?
There is a flat-head height adjust screw to control clearance between spatula and bottom of bowl visible from head-back position- leave it alone. There is a headless set screw visible when mixer is upside down to hold the pivot pin secure. This must be loostened with long-shaft flat screwdriver to remove the pivot pin for head removal if necessary ---avoid removing the pin if possible.
Is the hinge stuck with film of sticky sugar, milk-glue residue, ot the like? That is most common cause, distant second is the lock mechinism alignment (very rare)
Its important to keep head from wobbling side-to-side in use, so dont file or sand anything
Can telephone 609 213 2222 if necessary no charge for my talk.
Oct 16, 2011 | KitchenAid KSM150PS Artisan Series Stand...
Sims locked
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave', for today.
Subject: How to unlock a SIM card
Customer's exact description: sims locked
Discussion: Problems of this type can be easily solved. Customer did not provide the name of the service provider.
Solution: Provide instructions on the entire battery of solutions.
PUK Codes
A PUK (PIN Unlock Key) code is required to unlock SIM cards that have become locked following three successive incorrect PIN entries. If your SIM card becomes locked, you will need to get a PUK code from AT&T to unlock your SIM card.
Since I don't know the name of you carrier, I'm using AT&T as an example. Most carriers use the same methodology though the wording may be different.
You can obtain your phone's PUK code from AT&T in one of these ways:
Take the phone into your carrier's retail outlet.
OR
• Log in to myAT&T online
• Use our Technical Support Chat.
• Contact Customer Care
To get your phone's PUK code online:
? Log in to myAT&T.
? From the myAT&T tab at the top of the page, hover over the Wireless link and select Phone/Device under the My Wireless Service heading.
? From the My Phone/Device screen, select the Unblock SIM Card link under the My Make & Model heading.
? The Unblock SIM screen will display your PUK code and will give you instructions for unblocking your SIM Card.
Once you receive your PUK code, you will need to enter it into your phone to set a new PIN code.
Note: If you enter the wrong PUK code 10 times in a row, your SIM card will be invalidated, and you will need to purchase a new SIM Card. The phone will display the following error: "PUK blocked call operator."
Second Solution:
You can also do it without any assistance from anyone. However, be sure to read the following carefully because there are pitfalls. If you want to try to do it yourself, just click on the following link: Universal Software Solution for Unlocking a SIM Card
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below I've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators.
More importantly, when changing one's PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes.
The Final Solution:
The following methodology does not work for every phone. Perhaps you'll be lucky. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
** 04 * old PIN * new PIN * new PIN #
Change SIM Card PIN 2 (Write down the new code)
** 042 * old PIN * new PIN * new PIN #
Change SIM Card PUK (Write down the new code)
** 05 * old PUK * new PUK * new PUK #
Change SIM Card PUK 2 (Write down the new code)
** 052 * old PUK * new PUK * new PUK #
Display Handset IMEI
*# 06 #
This was wordy but hopefully it helped you.
Ben
Sep 16, 2011 | Motorola Mobility TracFone w175 PayAsYouGo...
Sony ericsson w302 lock sye sim card lock i dont no problem.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave' for today.
PUK Codes
? Log in to myAT&T.
You can also do it without any assistance from anyone, However, be sure to read the following carefully because there are pitfalls.
Although most people remember their primary SIM PIN code, those other codes - used for various verification purposes - are never to be found when needed. Below we've included a set of short codes which, when entered on a handset's standby screen, will let you easily change PIN and PUK (short for Pin Unlock Code) codes - but keep in mind, they may not work with all handsets and mobile operators. If you are interested in a software fix, click on the following link: Universal SIM Lock Remover
More importantly, when changing ones PUK codes there'll be no help to get from the mobile operator if the new codes are forgotten, so make sure to write any changes down alongside the old PUK codes. Also, please note that the codes should be entered without the spaces shown below.
Change SIM Card PIN
*# 06 #
Ben
*# 06 #
Ben
Aug 17, 2011 | Sony Ericsson W302 Silver +512MB by Fedex...
How to i remove the head on a Husqvarna 223: trimmer?
The head screws on to the shaft. be advised that it is a left handed thread You should have gotten a locking pin with the trimmer
Turn the blade shaft until one of the holes in the drive disc
aligns with the corresponding hole in the gear housing.
• Insert the locking pin (C) in the hole to lock the shaft.
• UnScrew on the trimmer head/plastic blades (H) in the
direction of rotation
Jun 26, 2011 | Garden
How do i change ignition switch on my 19890 ford ranger xl 4x4 2.9L V6
Rotate the lock cylinder to the lock position. On tilt columns, remove upper extension shround by squeezing at 6 and 10 o'clock and popping free of the retainer plate at 3 o'clock.
Remove 2 shroud halves by removing the screws. Disconnect the electrical connector from the ignition switch. Drill out the 2 break-off bolt heads that hold the switch to the lock cylinder using a 1/8" drill bit.
Remove bolts (may have to use a screw extractor). Disengage ignition switch from actuator pin and remove switch.
To Install:
Rotate the key to the run position. Install switch by aligning holes on switch base with hole in the cylinder housing. You may have to move it a little to get the actuator pin to line up.
Install new break-off bolts untill the heads shear off. Connect electrical connector to switch.Then reverse the removal procedure to complete.
Mar 19, 2011 | 1989 Ford Ranger
How to change to a rapid loader head on an echo
line up the hole on the collar that the trimmer head is installed against with the arrow or notch on the gear housing, insert a punch or the brass colored pin that most Echo pieces of equipment come included with, this will lock the head. now turn the head clock wise, IT IS LEFT HAND THREADED! so righty loosey lefty tightey. now install the rapid loader with the included washers and10mm gold colored lefthand thread nut
May 18, 2010 | Echo Rapid Loader, Trimmer Head
Replacing low beam head lamp 2006 trailblazer
with my 2003 gmc when you open the hood and look at the top of the head light assembly you see two rods that kinda look like the end of an allen wrench (hard to explain in words) you have to turn them a quarter turn to unlock them and then pull them straight up and out. they are pins that hold the headlight assembly into the truck. when you remove them the whole assembly will then come out forward and you can change the bulb. the hard part if aligning the holes and getting the pins back in. dont forget to turn the pins back into the locked position after. hope this helps as my truck is a little older.
Jan 18, 2009 | 2006 Chevrolet Trailblazer
Dewalt Heavy - Duty 12" Double - Bevel Sliding Compound Miter Saw Logo
76 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
