Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony kv-32fq86e 16 blinks
I was initially recommended to replace the MCZ3001D, I did but the sympthoms persist.
I am talking about a chassis AE6BA.
Thanks in advance!
  • jonvon5705 Feb 08, 2009
    I've had my Sony KV-32FQ86U for 5 years. The 16 blinks are followed by a 3 second delay thhen the 16 blinks repeat. Pressing any channel button seemed to display screen, now the screen will not display even after an hour of continuously pressing the channel button. appreciate any help offered jc
  • 24 Answers
If red led blinks continously , please check horizontal o/p or EHT screen control reduce and check for power on
sam
Posted on Jul 06, 2008
Bugaboo cameleon 72200
Hi Anna
We would recommend you contact Bugaboo for assistance.
Bugaboo Customer Service
May 19, 2014 | Baby Gear
Error59.c0
Per my service manual for this printer, the 59.C0 error states:
The product has experienced a developer motor error.
Recommended action:
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. Turn on the power and wait for the product to initialize.
If the error persists, replace the developer motor.
If the error persists, replace the DC controller
Apr 08, 2014 | HP Laserjet CM2320nf All-In-One Color...
Sony Qualia 004 doesnt work i cannot turn it on.
Hi the problem is in the board GB, open the projector and find the GB Board an change only one component, the MCZ3001D! The board have two McZ3001D, only change the side position!
Apr 18, 2012 | Sony QUALIA 004 Multimedia Projector
I get error code 3 from my sony wega kv-32fq86e TV
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672
Apr 16, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Turn power off and on again appears on the screen
Turn the Power Off and On again error message is displayed when the Lens in the Camera is stuck is affected by a malfunction. Try turning off the power and on again. If the issue persists, try performing a power reset.
To power reset the Camera; turn off the Camera and remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the Camera to remain without power for 60 seconds.
Then, reinsert the battery and check if it helps.
You may also try INITIALIZING the Camera.
To Initialize the Camera, press the On-Screen key.
Touch MENU-->SETUP-->SETUP 2-->INITIALIZE-->OK. Initializing the Camera will change all the settings back to factory reset.
If the issue persists, service may be required.
Thanks for using FixYa
KenSolutions
Dec 06, 2010 | Sony Cyber-shot DSC-N2 Digital Camera
My sony cybershot dsc-w350 keeps turning itself on and off and reads system error
The system error is displayed in the Camera when there is some internal malfunction or when the Lens in the Camera get stuck.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
If the issue persists, try Initializing the Camera. The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETTINGS-->MAIN SETTINGS-->INITIALIZE-->OK.
KenSolutions
Dec 05, 2010 | Sony Cybershot DSCW350 Digital Camera
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Light blinks 6 times, no picture, no sound
6 times blinks shows error of Low +B, OVP/ OCP
Replace IC6501 & IC8002 [ MCZ3001D ] on D board.
If you are handy with electronics stuff repair and can solder parts in circuit board then replace above said ICs or call local TV tech to do the job.
Thanks.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Hi I have a whirlpool gas dryer and it heats up when you 1st start it up but after a while it runs cool. Also the timer does not advance so it just runs aimlessly. I already cleaned the vent and lint chute...
The timer is the Principal initiator of the entire heating cycle. it authorizes the needed current for proper element functions. you have stated that the timer fails to advance, or rotate properly. this will cause inadequate heating, therefore, not allowing optimal dryer performance.
replacing the timer will fix this issue.
((I would also like to recommend replacing the running thermostat as well. this is good preventive maintenance. its located on the dryer blower housing or vent duct.))
Sep 02, 2009 | Dryers
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
1,138 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
