Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Pulling string on weed eater does not want to turn
The pull start string on weed eater does not want to turn the string head
    Brigadier General:
  • 4,088 Answers
It's possible that the engine has seized if the pull cord won't turn the engine over. Remove the starter mechanism from the engine and try to turn the flywheel by hand. One or more of the mounting screws may be hidden under a decal or other label. If the engine won't turn at all, remove the muffler and check the piston skirt for bad scoring--which usually means either dirt inhalation (bad air cleaner) or running the unit on straight gasoline. Either of these conditions require replacement of the cylinder, piston and ring(s) plus labor if you farm out the repair. Weigh the approximate cost of up to $150 against a new trimmer. Hope this helps!
Posted on Jul 11, 2010
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
I don't remember how to start my weed eater;i've lost my manual
Pump the gas bubble near the black box air filter. Start pulling the string. Keep pulling until it turns.
Thanks
Jun 03, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
When pulling the string to start the weed eater it feels as it's locked and won't pull out more than an inch I have set it to full choke half choke also primed it nothing works how do I get it...
If this is a 2 cycle engine , which most weed eaters are, then it sounds like probably the piston is locked up inside the cylinder. Try taking the spark plug out. if it still will not pull out then take the recoil cover off. There should only be 4 screws holding it on. Once you get that off see if the string pulls out of recoil if it does then check to see if you can turn the crank on the engine.If the recoil string does not pull over then that needs to be repaired or replaced. If the crank on the engine will not turn over by hand then your engine is siezed. If you take the covers off to expose the exhaust there are 2 bolts that hold it on take those out and look inside. If you see vertical scoring on piston then your machine isnot worth fixing
May 15, 2011 | Garden
The string in the spool of the weed eater is stuck. How can I remove the string and how can I avoid this problem in the future? I'm using the pre-cut strings. Thanks
Sounds like one of the loops is over the one being fed out. Does that make sense? I hope so. If one of the windings of string is over another, it makes it hard to unwind. Maybe if you were to put on a glove and really pull on the string, it would start to unwind. Other than that, pull the head and check the string. Good luck...Lee
Sep 20, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
How do you put string in
turn trimmer upside down grab the spool head firmly and pull out replace string but wind in the way arrow shows you and replace fishing the loose end back through the hole on the side as you slip back together ,once together grab string and pull to remove any slack and away you go
Aug 22, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
383 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
