Hi I've got water coming out of the bottom of my f& p aquasmart washing machine. It's not coming out of the hoses or the hose connection but from under the machine when it is running? Any suggestions? Regards Justine
  • 262 Answers
SOURCE: washing machine
there is a tool that hooks to you garden hose that goes in your pipe and expands then blows water down the drain to blow out stoppage it work great you can get it at your local hardware store
Posted on Dec 20, 2007
JULIANFIX
  • 975 Answers
SOURCE: Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Posted on Apr 22, 2008
  • 25 Answers
You may want to check the seal at the bottom of the agitator, there is a o-ring that keeps the water in the drum from leaking through the agitator as it spins. This is a cheap seal and will wear over a period of time from exposure to bleach and detergent. You need to take the agitator apart and remove it from the drum and you should see this seal at the base of the agitator were it meets the drum.
Replace the seal and reassemble, take the metal casing off the washer and fill the drum with a little water, wait, and see if the water is leaking under the drum. If no leak, try to reassemble and run the washer. If is still leaks then check http://www.applianceaid.com/genew.html
Yours Truly,
Mr.Fix-it-guy
Posted on Aug 12, 2009
SOURCE: Washing machine leaking from bottom.
maytag pav2300 washer leaking at pump..should I replace entire pump or just seal? also, screeches to a stop....what is causing this?
Posted on Oct 19, 2009
  • 447 Answers
SOURCE: Water leaks from my Aquasmart 8 kg washing
On most units, the water pump was a "weep" hole on it which tells you pump needs to be changed soon. It tells you the internal seals are starting to fail.
Posted on Dec 28, 2009
I have Beco WM616 7W washing machine...when I start washing...water should filled in washing machine but it comes out from somewere..all programms working...just water comes from bottom..
Check all your hose connections. Sounds as if the drain hose has come loose or burst. (common fault in all machines).
Open soap drawer, and check that water is flowing into it.
If no water is flowing into it, looks like the water connection hose at rear is not secure.
If water is flowing into the drawer, but not staying in the drum, then check the drainage outlet hose is secure and undamaged.
Jan 21, 2013 | Washing Machines
Fisher and Paykel washing machine Aquasmart during cleaning cycle alarm indicating fault code 12 - drum full of water
If the drum is full of water your drain pump is not functioning correctly. Could be a bad pump but more likely it is a clogged drain hose (hose between tub and drain pump) or filter basket on the pump if it has one.
Jan 11, 2013 | Washing Machines
I have an Aquasmart W80T65C. After each load there is a small amount of water under the machine. The water is dripping off a black rubber elbow at right rear of the machine.
Hi - if you could try this - fill the machine with water and leave it overnite to see if there is any water on the floor.
Yes - then just tilt the machine on its back & find the leak.
No - then there is a small hole on the drain hose, this will be due to the movement of the bowl - rubs against something and over time springs a leak.
My washer has one on it now - just located the pin hole & wrapped duct tape around it - works fine for us.
Jun 22, 2011 | Fisher and Paykel Washing Machines
I have a 7 year old LG WM2277....that stinks like crazy!.......So I removed the Water Circulation Nozzle inside the washing machine door at the top of the grey rubber ring. I did this with the intention...
The easiest way is to remove the top panel of the machine. There are 4 screws in back that hold the top of the washer. Remove the bottom screws and push the top rearward to remove the top. You can access the hose from the top and reconnect the hose.
Good luck
Jun 16, 2011 | LG WM-2277HW Front Load Washer
Hi, We have just moved and relocated our washing machine. The problem is that the wash and rinse cycles for all types of cycles is coming into the machine hot, extremely hot. What did we hook up wrong?
It's hard to say without more details, but normally, these machines have two hoses, each connecting to a seperate water spigot, one for hot, one for cold. You don't say how you hooked these hoses up, but it's possible you've crossed the hoses. It's also possible you've hooked up to a faucet that has only ONE spigot, using a "Y" connector. Take a look: You must have two spigots, and each must have a hose going to the appropriate water intake on the back of the machine. They should be marked "HOT"/"COLD" (or, possibly red for hot & blue for cold). If this is not the problem, then you have a much trickier problem that will involve bringing in a trained professional. Good luck.
Apr 20, 2011 | GE WCVH6260FWW
Leak underneith washing machine
Tip washer to inspect belts & hoses on bottom. Check hose connections & plastic pump housing for crack.
Nov 04, 2009 | Westinghouse WWS833ES Super Capacity Top...
Leaking water out of the bottom
Leaking water from a washing machine usually comes from hoses or connections. Be sure that water appearing to be a
leak isn’t drain water from a backed-up standpipe. To prevent potential flood damage, which can occur if washing
machine supply hoses burst, be sure to install “no-burst” stainless-steel mesh hoses and lever-type shutoff valves,
as shown below. With these, you can easily turn off the levers for both hot and cold water between wash days.
1) Check the fittings where the hoses connect to the faucets and to the back of the washing machine. Also look for
worn or leaky hoses. Tighten couplings or hose clamps if needed, or replace the hoses altogether. Be sure to turn
the water off before removing the hoses, and drain them into a bucket after disconnecting them.
2) Determine whether the machine is oversudsing, which can cause the machine to overflow. Reduce suds by pouring 1/2
cup white vinegar in 1 quart water into the washer. Then switch to either less detergent or a low-sudsing variety.
3) The machine may have a faulty basket gasket or tub seal and bearing that must be replaced; in this case, call an
appliance repairperson.
Thank You for contacting fixya.com
Oct 12, 2009 | Frigidaire FWS833A Top Load Washer
Leak at the bottom of front door
Leaking water usually comes from hoses or connections. Be sure that water appearing to be a leak isn't drain water from a backed-up standpipe (see HERE for information on clearing clogged drains).
NOTE: To prevent serious flood damage that can occur if washing machine supply hoses burst, be sure to install "no-burst" stainless-steel mesh hoses and lever-type shutoff valves, as shown in the illustration. With these, you can easily turn off the levers for both hot and cold water between wash days.
1) Check the fittings where hoses connect to the faucets and to the back of the washing machine. Also look for worn or leaky hoses. Tighten couplings or hose clamps if necessary, or replace hoses altogether (be sure to turn the water off before removing hoses and drain them into a bucket after disconnecting them).
2) Determine whether machine is over-sudsing during wash loads-- this can cause the entire washing machine to overflow. Reduce suds by pouring a mixture of 1/2 cup of white vinegar and 1 quart water into the washer. Then switch to less detergent or use a low-sudsing variety.
3) Call a repairperson. The machine may have a faulty basket gasket or tub seal and bearing that must be replaced
Please rate this solution
RNJ VINODKUMAR
Oct 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How long is the fill and drain hose for Haier HLP21E washer?
No need to worry, you can get a new inlet hose & drain hose of any length at any major hardware store. I have the larger Haier outside my kitchen & got a 10' drain hose & inlet hoses & this same situation was instantly solved...
Howard
Feb 19, 2009 | Haier HLP21E Top Load Washer
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
