Question about Toto Washlet S400 for Power Gravity Toilets - SW564T694
Low water pressure on my Toto S300 Washlet
Recently my Toto S300 has had very low water pressure on the Rear Cleansing Mode. On the high setting it is as if it is on the very lowest setting. On the lowest setting the water just dribbles out. It is as if something is clogging it but all the sounds are normal. Could it be hard water build up, and if so how can I fix it?
Thanks for your time
Rob
2 Suggested Answers
  • 5 Answers
SOURCE: Recently my Toto S300 has
Clean the internal water filter. See page 24 of the instruction manual. If you don't have the instruction manual you can download it.
Posted on Apr 02, 2011
Front AC cold but Rear AC very hot
Not likely, but Is Hot water flowing to heater coil in back? How hot is "very hot" Is it a refrigerant line? If a refrigirant line, Very Hot means it is hot gas from the compressor that "should be going to the condenser coil usually in front of the radiator. It's almost impossible for that Hot refrigerant gas to go to the cooling coil in the back unless you had some repairs done and they weren't certified. My guess is the radiator hot water is not being controlled properly, due to bad valve or control system components.
Jun 07, 2015 | 2009 Saturn Outlook XR
Toto neorest leaking & low pressure wand
Sounds like the washer in the shutoff at the wall has failed and is partially blocking the fill pipe. Some rubber from it may have gotten into the toilet valve internally. With the wall valve closed, try to remove the connection pipe to the toilet. If you can do it without water continuing to flow out of the wall shut off...then remove the pipe from the wall shut off. Flush the toilet. Now, apply air pressure to the rubber hose the goes into the overflow pipe. That may clear the valve in the tank and solve both problems. If you cannot stop the water at the wall shut off, close the water valve feeding the house. Remove static water pressure by opening the cold water a the kitchen sink faucet. Now you can open the wall shutoff valve and replace the washer and clean it out....
Mar 08, 2014 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
Little water pressure from wand. The pressure does increase and decreasefrom little to nothing and only from one hole.
Try removing tip on wand 9 out of 10 times sand or grit will plug spray orifice
Mar 27, 2017 | Toto Home
Everything works, but water will not come out of the wand. Changed all filter, checked water lines? Read the manuel, tried all trouble shooting answers.
The supply line running from the junction valve to the seat is kinked or pluged in some other way way. take that line lose at the juction valve and see if you can blow air through it.
Jan 27, 2011 | Toto Round Washlet S300 Toilet Seat -...
The water does not squirt out of the bidet wand
My Toto Washlet has stopped squirting water. Any ideas for fixes?
Dec 02, 2010 | Toto Washlet S400 for Power Gravity...
How do I turn the soap on my mcculloch power washer
Not sure about the McCulloch , but most pressure washers will only draw the soap in low pressure mode. either turn or pull the nosel on the end of the lance to switch to low pressure. I hope this helps.
Sep 07, 2009 | McCulloch Garden
Flush problem with toto toilet
If your hooked to city water it can be cause of the high water pressure comes across and keeps flapper from seating rite. Take a empty plastic bottle,cut it in half long ways. flush toilet then place plastic bottle between fill valve and flapper,trying to devert water away from where flapper seats. good luck.
Jul 23, 2009 | Toto Dartmouth 2pc. E/F Toilet ...
ToTo S300 spray very weak
Poor some clr in the washer bottleand block the nozzles as you run the clr through. they will clear up, but don't leave the clr on your paint or in the washer bottle. Rinse everything out and off.
Jul 10, 2009 | Toto MS950CG-12 Neorest 500 Elongated One...
Toto Washlet S400 for Power Gravity Toilets - SW564T694 Logo
643 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
