HAVE A SHARP AR275 WITH WITH FOLLOWING ERROR CODE H4-00-----THANKS
    Problem Solver:
  • 10 Answers
Fusion error , try to reset it with CROP 14
Posted on Jul 10, 2010
I TRIED YOUR SOLUTION BUT IT IS NOT WORKED (H4-00 PHOTOCOPY MACHINE)
Posted on Jul 27, 2010
2 Suggested Answers
angelus316
  • 41 Answers
SOURCE: I have a Sharp AR275 that has an error code of
yes just reset the code via the following combo
# / interrupt / C / interrupt
punch in 16 and select ok / enter
reboot and away you go
Posted on Jun 18, 2009
Sharp AR275 call for service,the reset is not being helpful.
Must replaced developer and run initialization through service program.
Oct 17, 2014 | Sharp Digital Copier Toner AR235 AR275...
Sharp AR275 copier error message received is "call for service u2-40" please what can i do to solve the problem?
in order press
* Entering the simulation mode
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
Simply # * C * and the machine will enter simulation mode.
Then enter the number 16, which is U2 code correction, follow what the screen says, Normally just press start and the machine will reset.
U2 codes are software glitches. A U2 40 is a CRUM fault which is a drum or toner chip problem.
Sim 16 almost always clears them.
May 19, 2011 | Sharp AR-275 Copier
I have a Sharp AR275 that has an error code of U2-40. Non of the controls works. Any ideas on how to fix? Thanks JKP
Jun 15, 2009 | Sharp Office Equipment & Supplies
Call for service U2-40, on a sharp AR275 printer
In AR 275 Sharp copier U2 40 is very common problem, U have to only reset the above error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 16 then press ok key
pl ask for any difficulty
May 17, 2009 | Sharp AR-275 Copier
Call service
ASIC error. Try turning the copier off, wait 30 seconds, and turn it back on again.
Aug 02, 2008 | Sharp AR-275 Copier
ERROR L4-01
What you have is a main motor lock. Check to see if you have anything blocking the movement of the drum, it could be anything from a staple, a jammed sheet of paper, or a broken drum separation pawl. If you have already removed something from the drum area do a SIMM 14-01 to clear the code.
There also could be trouble with the main motor itself. Check the motor by using SIMM 6-1 to see if the motor turns. If not, check the harness connection between the main motor and the PCU PWB. You may need to replace the main motor, the harness or the PCU PWB.
Nov 22, 2007 | Sharp AR-275 Copier
498 people viewed this question
k24674
jasbo
jasbo
