Question about Sharper Image Deluxe Spire SI788SNX Tower Fan
Spire fan S1868 shuts off when I press the rotate button.
Where can i find the picture rotation button on a acer spire 5250 computer
To rotate what picture? If you want to rotate the desktop you only need to right click on the desktop and select the "Rotate" button.
Apr 18, 2013 | Acer Aspire Computers & Internet
Have a Kenmore 90 series gas dryer. When I press the button to turn it on, it makes a noise but won't start
Assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Check the blower fan and motor for any obstructions.
Jan 09, 2011 | Kenmore Dryers
How to adjust brightness in accer spire 4738z
Press the little blue "Fn" button next to the left "Ctrl" button. Then whilst still holding down the "Fn" button, tap the left and right arrow keys accordingly to increase/decrease the brightness.
Nov 18, 2010 | Acer Aspire One PC Notebook
How do you clean the gill on the Sharper image delux spire fan
I recommend using canned air to blow it out from the front. If you have access to a compressor, this works even better. Farmerbear at FixYa.com
Sep 30, 2010 | Sharper Image Deluxe Spire SI788SNX Tower...
K8mc51g motherboard wont turn on i shut it down and now it wont power on i tried reset jumpers and removing the battery for 30 sec and taking away all power for 24 hours
If after pressing power button the fan rotates ...then the BIOS might have been corrupt ...and if the fan dont rotate then the SMPS might have fault
Oct 21, 2009 | E-Machines eMachines Desktop PC
When i on the system, the fan is not rolling, sometime when on and boot upto the the window evironment, its shut itself down. what could be the possible problem with them
Please Check CPU making any noise or not.
remove the CPU side door and check Fan is rotating on Processor if not it may not rotate due to heavy dust inside. ( clean it and refix it)
Check SMPS Fan is rotating or not..
If fans or not rotating Heat Builds up then computer shuts down itself.
If both fans are working...Just Open BIOS window by press DEL button continuosly while startup and wait for 2 to 3 minutes If the computer shuts down Itself in BIOS Window also then we can confirm issue with Hardware.
If Computer not shutting down in BIOS Window then issue with Operating System Boot files corrupted.
While Turn ON the system press F8 to enter in Safe Mode.
Open command prompt by clicking on
Start >. RUN >> type cmd >> then press enter.
now type chkdsk /f
now press Y
then reboot PC it fixes the Boot files error then your PC works perfectly.
If you still exp same issue let meknow..
Feb 18, 2009 | HP Pavilion dv6000z Notebook
How to brighten the moniter for a acer spire 3650
*in your monitor there are some digital buttons just click the button the menu items will appear press + button to increase brigthness of ur monitor
Jun 25, 2008 | Acer Computers & Internet
Motherboard failure
REMOVE PROCESSOR HEATSINK AND CLEAR DUST ON HEAT SINK AND ON PROCESSOR
Jan 05, 2008 | Intel D865GBF Motherboard
Fan wont work
I have the same problem, warranty on this fan is only 90 days...
Apr 25, 2007 | Sharper Image Deluxe Spire SI788SNX Tower...
Sharper Image Deluxe Spire SI788SNX Tower Fan Logo
57 people viewed this question
Top Sharper Image Dryers Experts
Dan Webster
Dan Webster
Are you a Sharper Image Dryer Expert? Answer questions, earn points and help others
