Question about Bunn 10 Cup Home Coffee Brewer
Butter melted into top and down in to water container
Is there a way of cleaning the inside where the water is stored. Have tried to run about 30 pot of hot water through but still getting butter coffee....B10-B model I know never set anything on top of the coffee maker....wasn't me
    Genius:
  • 1,970 Answers
Mcdevito75 here, Try to clean your coffee maker by running a decanter full of white vinegar thru the system 2--3 times, then fesh water to rinse out the vinegar. Use a new or clean filter at the beginning of the vinegar treatment and after when you rinse with regular water.
Posted on Jul 07, 2010
GE fridge modle#GSH25JFRFWW serial# MH236895. My freezer will stop freezing for a while. Ice will start melting down the door. Then freezer will freeze again leaving ice cycles down the door. Also my water...
Yes this is complicated for me.
But in case my method works for you here it is:
Turn off the freezer and empty it. Depends on the time of the year where to put the things you take out of the freezer.
Put boiling water in cooking pots, the pots inside the freezer and have a lot of towels handy when the melting begins.
When all the "frost" has melted and still no power on the freezer, clean it well and take a knitting needle and try to put it in the hole in the middle of the waterline. Usually some muck comes out. Leave it like that and put everything that you are going to keep,in the freezer again.
The power on and hope for the best, which usually happens.
kolbrun
Apr 09, 2012 | GE Refrigerators
Hi...have a ge micro jvm1190sy 011 i melted marshmellow in it....it bubbled over and is now stuck in the ceiling of the micro on top of the whole metal sheet i can not clean it so there is layer...
How about boiling a small container of water and once it starts boiling. Just shut the unit off and let it sit and let the steam do the work for you. Might soften it enough to scrape it off.
Aug 23, 2017 | GE JVM1190SY/WY/AY/BY Microwave Oven
I had a stick of butter laying on top of my bunn coffee pot and some butter leaked through the vents. the coffee tasted terrible so i cleaned it with vinegar and ran about 10 pots of clear water through...
Believe it or not I had a customer once that left 6 pounds of butter on top of one of our brewers. They had it cleaned up on the outside so it took me a while to figure out what had happened but I could taste the rancid oils.
We ran about 20 pots of just water through it... make sure you let it heat back up before each one. I think the only thing vinegar might help with would be lime/calcium build up so I wouldn't think it helps this particular situation.
Dec 21, 2010 | Bunn BT10B Coffee Maker
I have water draining back into the reservoir. It has been descaled and the needle openings have been cleaned.
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 14, 2010 | Keurig B60 Coffee Maker
We spilled melted butter into the base that holds the kernals. Now we get black smoke when we plug it in. I tried running it on empty for awhile, but the smoke continues. Can we remove the top and clean...
you can open it but not from the top. unscrew the bottom and take out the heater and clean out the Popper without using any water or soap just a toothbrush and cloth. it will take more then one clean out to get it to stop smoking (took me 3 times). put it back together place a plate under it to catch butter and run it for 10 min. to get hidden butter to melt and seep out of hidden spaces then repeat cleaning.
Sep 11, 2010 | Presto 04820 PopLite Popcorn Maker
Want to purchase electrical cord for West Bend 30 cup coffee maker model #58030 . Also what do I use to clean the interior of the pot? It has not been used in more than 2 years. Looks corroded inside.
go to "Nelson's Appliance Cords" web-site you can order on line, as for the pot cleaner put 1 cup of regular white vinegar in with a full pot of water and run a cycle, when water is not dark then pot is clean
Oct 25, 2009 | Coffee Makers & Espresso Machines
Bunn BT 10B -RANCID BUTTER in Resevoir!
Hi Tina - I'm no expert on melted butter in your coffee maker; but, I'd bet that the butter also got into the internal water tank where the water gets heated. Try going to the Bunn website: www.bunn.com , and click on their Customer Service link. You can either call their toll-free number or write to them with your problem from there.
Hope this helps!
Jan 13, 2009 | Bunn BT10B Coffee Maker
RANCID BUTTER melted in Bunn Thermofresh resevoir vents!
There is one thing you can try first. With the machine filled with water and turned on, pour in 1 quart of white vinegar and let it sit in there for 2 hours. Then flush it back out with 8-10 carafes of water. If this doesn't correct the problem, then call customer service with the model and code date. This can be replaced under the warranty if it is under 3 years old or less. If it is over 3 years old, it can be replaced at a reduced price.
Jan 12, 2009 | Bunn NHB Coffee Maker
Brewstation
There is a very fine screen on the outlet of the carafe that becomes plugged over time with fine coffee grounds. You can see it if you look down inside the pot above where the coffee comes out. Just using coffee pot cleaner won't clean it, because it's fine coffee grounds stuck in the screen, that are slowing the coffee going through it.
It's not easy to reach, so you'll a pair of needle nose pliers. Get ahold of the plastic ridge the runs across the top of it and it pops right out. You can use the bristles of an old toothbrush to scrub it. The bristles will fit in the spaces of the fine screen and force the deposits out. You can probably just leave the screen out altogether, it's just there to stop grounds.
Feb 14, 2008 | Hamilton Beach BrewStation 47214 Coffee...
Bunn 10 Cup Home Coffee Brewer Logo
154 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
