Question about Lands Phones
No link to base, batt,ok won't charge end - Lands Phones
  • 1 more comment
  • Anonymous May 21, 2008
    My Panasonic KX-TG2420 shows the following message: "No link to base. Move closer to base, try again." The battery is ok, and the phone is right next to the base. Can someone tell me how to repair this issue.
  • Anonymous Jul 29, 2008
    same problem
  • Anonymous Mar 04, 2009
    No link to base. Move closer to base, try again. Same problem here, I don't see a solution.
I have similar problem
Posted on Oct 27, 2008
Switronix Tl-50 won't turn on
I too have had a problem with mine no longer charging. I talked to the manufacture. Since the cord light is on however my torchlights charging light is not on they said could be the batt or could be a bad wire in the charger. I've been debating whether to send it in for fix or buy a new batt to try first. For yours I would send in for repair. Unfortunately these lights only come with a 1 yr manufacturing warranty so if you've had it over a yr you will end up paying 60-130 was the price range I was quoted depending on the problem.
Mar 03, 2013 | Switronix TorchLED TL-50 Video Light - 75...
My jeep grand Cherokee lorado 1998 won't start. If
are the inside of the battery terms dirty,corroided? do you know if motor alt is charging batt? how long did it run when you put new batt in? if it lasted about two days, its proubly not charging, also make sure nothing is being left on draining batt down, to check that, leave batt nuhooked pos side over night.
Feb 19, 2013 | Cars & Trucks
Batt won't charge
Please check the charger if it can charge other similar phone. Also check if connector is ok.
Jul 19, 2012 | Android Apps
Toshiba satellite battery won't charge
DID YOU NOTICE ANY OVER HEAT IN BOTH,THE PC OR CHARGER? IF SO THE CAN BE 2 ISSUES.
1-THE CHARGER
2-THE BAT
IF YOU TRY TO CONNECT THE CHARGER WITHOUT THE BATT,THE CHARGER GET HOT? (1) ,DO THE CHARGER IS OK (2)
Apr 26, 2012 | Toshiba Satellite A65-S126 Notebook
New holland tractor won't start just clicks
check both batt. termial ends,also check cenections at the starter and the ground wire,if that wont fix it next maybe charge batt .
Jan 07, 2012 | Garden
Not charging replaced alternater still wont charge
Be sure to charge the battery, otherwise you might smoke the new alternator(not made to charge a dead batt.). Have the batt. load tested. Check batt. cable ends for corrosion.
Nov 11, 2010 | 1994 Plymouth Voyager
My 1997 650 savage wont keep a charge
Hmm, do you have a voltmeter, check the voltage on the battery with it running, usually 13.5 to 15 volts
If that reads ok, you probably have a short, get a testlight, pull off the negative cable off the battery,clamp one end to the cable and the other to the battery. If it lights up, you have a short, start unplugging stuff until you find the short and the light goes out!
Jun 09, 2009 | 1989 Suzuki LS 650 Savage
Alternator not charging batt.
inspect cables, they break down over time, corrode and turn green inside
Nov 25, 2008 | 1988 Lincoln Continental
Motorola MD760 dies after 5 minutes of use-- from being charged for days on base
this is a battery prob replacing battery will solve this prob hope this solves your prob make sure the battery connectors are conected propery securely first before replacing if ok then replace batt and prob should be solved check then conectors are clean where the phone sits on base and check phone sit on base properly if it does then it is def the batt replace.
Nov 15, 2007 | Motorola Mobility MD761 Cordless Phone
No link to base
check your handset.. reheat or resolder the components at pcb.
Aug 15, 2007 | Panasonic KX TC1703 Cordless Phone
Lands Phones Logo
186 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
