Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel lines disconnected
Need fuel line routing diagrams for McCoulloch 3216 chain saw. Also need routing diagram for bar chain oil lines
Fuel lines on craftsman chain saw
go to the website and see if you can download a manual
most saws have 2 lines fuel in and a return
the fuel in line is the one that goes in the tank and has a filter on it
hold you finger over the fuel line on carb and pull cord, the one that sucks is your fuel in, the one that blows air out is your return
Mar 07, 2014 | Craftsman 42cc 18" Gas Chain Saw
I need a diagram for the fuel lines on 1997 kawasaki vulcan 750. i took the fuel lines loose and i don't know where they go
Hi.
There is no "diagram" showing the whole routing of fuel lines in the bike. You need to use different diagrams in Fuel System section of the service manual. Fuel system section starts at page 15 in service manual, but what you really need starts at page 40. I have posted fuel service manual at the end of comment.
There is one forum where users discussed the routing. One user has colored the diagram from service manual to indicate lines routing. Here the diagram:
Here the forum, I quote:
"The red and yellow are the fuel lines that go to the petcock. The green one you left unmarked also goes to the petcock. The line with a question mark is a vacuum line that connects to a part in front of the battery along with the larger lines to the cylinders."
Here the service manual in PDF format.
Regards.
Ginko
Sep 05, 2011 | 1988 kawasaki VN 750 Vulcan
Need diagram / pictures of routing of all fuel lines. 1981. CX500 Custom
It's hard to find diagram for older bike.
I got the pic from the tank to pet ****.
LINK HERE
Aug 10, 2011 | Honda CX 500 B Motorcycles
I have a 2250 Poulan. The fuel lines have been removed. Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out...
Is there a fix for bar oil running out of the saw all the time until the tank is empty?
there is bad oil line repalce it.
Is this the correct routing for the fuel line? Starting at the filter in the tank,will the line go to the bottom of the carb.? Then the line goes out at the top of the carb. to the primer\'s suction side? Then out of the primer to the fuel tank? This route the primer pulls gas through the carb. Does it make any difference which hole in the tank the lines go to?
YES that correct
Dec 29, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Am replaceing fuel lines think i might have them crossed need diagram
There is an illustration on the link that should provide what you ask.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
The IPL for your saw can be here:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but on multiple illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Try PP4620 AV Gas Saw. HTH
Lou
Jan 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Sep 14, 2009 | Poulan Garden
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
106 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
