Question about Toshiba Satellite P15-S470 (PSP10U-0GGPGR) PC Notebook (PSP10U0GGPGRPSP10U0GGPGR) PC Desktop
Unable to hold onto the internet
Inter net doesn't come on automatically
called provider and Belkin (router) they didn't help
Hello, I do not know much about troubleshooting internet connections. I just rely on Microsoft's "Diagnose Problem" option and most often than not, it works. But when I replaced our old...
Thank you for using fixya.
Being that your other computers in the network are working properly, you should switch the ip settings on your comnputer to automatically detect. That way your computer does all the routing and ip setting,
After you have set that back. Remove the power of your router, remove the power of your modem, and restart your computer.
Once your computer is back up, turn on modem, then the router.
It sounds very simple, but in most cases, it solves the problem.
Hope this information is helpful
Jul 18, 2011 | Belkin Basic Wireless Router
The interent will work for everything for a day but...
Hello, Bobby.
Either your router or the service to your router is a problem.
Contact your provider for testing. You may need a new router.
Hope this helps.
Dec 13, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do i hook up my belkin f5d7230-4 router to hughes net internet when there is only one ethernet port?
Connect that one port to your Belkin WAN (Internet)connector (Yellow Port). The other ports go to other computers, to their Broadband RJ45 connectors.
Here's from the manual:
1. Unplug your existing modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router
2. Connect the new cable (provided in the box) to the yellow
port on the Router. Plug the other end into the modem.
G WIRELESS ROUTER Quick Installation Guide
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer (Windows®)
or the Finder (Mac OS® X) and double-click on the
“Setup Assistant” icon
Nov 15, 2009 | Belkin (F5D7230-4) Router (587009)
When I hook the router up, it does not allow me to get online via laptop. But when I disconnect it and use my normal interent on my desktop, it's as fast as ever. Sometimes, I can catch the router working...
1. Try a different brand or model router
2. Try a different cable
3. Sometimes the internet modem needs updated firmware. Explain what happens to your internet provider and see if they will provide an updated modem or setting changes to prevent dropping the connection.
Nov 07, 2009 | Belkin (F5D7230-4) Router (587009)
CANNOT GET INTERNET_ROUTER CONNECTED AND WORKING PROPERLY
www.west.net/-jay/modem
www.tweakit.com
www.k56.org
www.itu.ch
www.firewire.org
elaine.teleport.com/%ecurt/modems.html
www.belkin.com
check the networking and sharing folders in the control panal.
the security software in windowsand the anti virus program provider you are using ing on the net.
go to address bar and type in router driver only i got over 200,000 hits without any manufacture names added to the driver list of manufactures name or name list
rod
Feb 06, 2009 | HP Pavilion dv6000z Notebook
Need to hookup router for laptop to access inter-net. I already have a Belkin Wireless G Router -2.4hz-802.11g. It needs to be re-configured after being shutdown.
connect your pc to router using a lan (RJ45 cable), then open up internet explorer and type 192.168.0.1 or 192.168.2.1 in the web address, you can then enter the default password and username and then set up your router
Aug 16, 2008 | Belkin Computers & Internet
Have a 1year old Belkin wireless router that has worked until a couple of weeks ago. Unable to connect to internet wirelessly and unable to secure it. Have spoken to several tech people and after extensive...
I believe you need to call the netgear support again and ask if you can talk to their department with replacement concerns. Because if the online replacement order didn't work, your only option is to call their customer support number for manual process of replacement.
Hope that helps.
Jul 24, 2008 | Belkin Computers & Internet
Can't get to my internet
you can connect to interent via wifi even though you may have interent service by your phoen provider. navigate to ppcgeeks.com
Jun 17, 2008 | HTC PPC-6800 Smartphone
Internet Connection drop outs on Belkin ADLS2+ modem router
Try to call your internet service provider. They should most likely resolve your problem. Or, disconnect everything. Plug the cable wire to the back of your modem. Give it 30 seconds. Plug in the ethernet cord from your router to your modem. Plug in the power adapter to your modem and give it 1-2 minutes to start up. Next, Plug the power to your router. Give about 1 minute. Go onto your computer and hit the start menu, go to the control panel. Look for internet connection and click on it. Find you internet connection, right click, and hit properties. Click on TCP/IP. Make sure your settings are on automatic. Then try your internet.
Mar 22, 2008 | Belkin (F5D7633UK4A) Wireless Router
Wireless router
first connect the devices in this way
from us inter net modem to belkin routers inter net port connect a ether net cable rj45-->then connect another ether net cable rj45 from pc to -->ethernet port on teh belkin router>and reboot the router and modem if u r using cable inter net then immediatly that will work>and open a browser window type this in address bar http://192.168.2.1 u can see the belkin login screen and follow this link
http://www.gorge.net/help/wizard/belkin/f5d7230-4_pppoe.htm
rate me solved if its helps
Nov 18, 2007 | Gateway Belkin 54g Wireless DSL/Cable...
Computers & Internet Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
