Question about McCulloch 16 Inch Gas Chain Saw MCC1635AK
Bar oil doesn't seem to oil the chain while running. After a long sit in the case, the oil seems to seep out and I need to refill before using. Rarely used, always starts but the chain oil is the problem. Last time the chain was getting hot so now I sit. Oil in the resivor. What to do?
  • 518 Answers
The oilways feeding the chain must be chocked with sawdust,,a clean out will help
Posted on Jul 07, 2010
Oiler mechanism to bar of ryobi 40cc 10532 18 inch
I get asked this question a lot , im gonna have to make a video on this subject someday .
but here:
1st ck your oil viscosity/SAE it should be 30 and say bar/chain oil
next dump out entire oil tank and wash out with kerosene (you'd be surprised what I seen come out)
then remove bar and chain , locate oil outlet it's in body of saw near adjustment screw , use a small can of air to blow in this port softly , use a touch more of kero to clean this all out , refill tank with proper oil !!!! and run saw (no need to put bar/chain back on yet ) might take several minutes but oil should start to flow out hole !! stop saw and reinstall bar/chain then run again .. fixed !! if no oil comes out ever your oil pump is gonna need some fixing
for a low cost oil I use filtered used motor oil cut down with a dab of kerosene
Jul 07, 2014 | Ryobi Factory Reconditioned 18" 40cc...
No oil going to the chain and bar. I've drained
You will need to disassemble the saw and clear the oil line at the least. It could also be a bad pump.
Jun 26, 2011 | Poulan Garden
I installed new bar and chain .cleaned every thing .assembled saw filled up chain oil thank. started sarted saw ,chain still not oiling.
Without knowing what saw you have it is hard to exact directions.On most saws their is an adjusting screw on the bottom side of saw by oil tank and chain that adjusted the flow rate of oil. If you can locate that try rurning it one turn clockwise and run saw for a short period and see if you are getting any more oil.If youare sure you have the right screw I would continue adjusting . If it doesn''t seem to work I would remove screw and make sure there is no blockage and that oil is present. For proper operation you need to keep a light film of oil on it. If you aren't getting enough oil you will cause chains to overheat,possibly ruining chain and bar. Hope this help you. Thanks
Nov 14, 2010 | Garden
Can't seem to get my oiler to work properly. oil emerges when i run the saw with the bar removed, but chain is dry and hot when run put together.
Some saw manufactures design their oilers to only work with their bars. Are you running the mfg suggested or stock bar? Chain? Stihl Chain is designed to use 30% less oil because of oil groves cut into each drive link directed to the rivets. So if your running an aftermarket bar/chain, the oiling ports may not line up. Especially if it oils with no bar & chain
Oct 09, 2010 | Husqvarna Chain Saw 20" Bar
Chain oil leaks out quickly a rancher 55
Remove the bar and chain. Clean the engine side case where the bar fits. Does the oil port itself leak or is it coming from the engine case? If from the case, it may be a loose or split line from the tank or it could be a cracked oil tank. If the tank is cracked, replace it as there is no glue or epoxy that can permanently repair it. If the leakage seems to have stopped, clean the drive end of the bar including the two small oil passages that run out to the chain groove. Re-assemble the bar and chain, then run the bar tip at speed near some cardboard for a few moments--it should throw off a thin line of oil. This saw should have an oil volume adjustment screw located near the chain return area on the back or underneath the case. Adjust CW to reduce the oil volume. Hope some of this helps!
Jul 11, 2010 | Husqvarna Chain Saw 20" Bar
Chain not lubricating
Remove the bar and chain. Clean all parts exposed including the bar drive-end small oil channels that feed oil out to the chain groove on both sides of the bar. Start the engine and look for oil oozing out of a small side port where the bar fits to. If ok and no oil seems to coming from under the case, reassemble all components. Start the engine and run the bar tip at speed near some cardboard--it should throw off a thin line of oil. This saw should have an oil volume adjustment screw in the case back near the lower run of chain or just under the case in the same area. Turn CW to reduce volume. Hope this helps!
Jul 06, 2010 | Husqvarna Chain Saw 20" Bar
Husqvarna 455 Rancher - oil coming out of muffler and not oiler. Just emptied gas and remixed new batch so that should not be issue. It was working fine until I took off chain cover to clean and got brake...
Re-clean the engine case and loose parts. Start the engine with the bar removed--oil should ooze out of the side port where the bar fits to, but nowhere else. Clean the bar drive end oil passages--especially the two small channels that go out to the chain groove on both sides. If you seem to be pumping excess oil out, there should be an oil volume adjustment screw either in the back case or just underneath the case near the lower run of chain. Turn the screw CW to lessen the volume of oil. Hope this helps!
Jun 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Not much oil on poulan chain saw bar
there is some debris blocking from entering the bar and when sits it seeps out,clean bar and are under chain cover
Jan 30, 2009 | Poulan 1630 16" Chain Saw
McCulloch 16 Inch Gas Chain Saw MCC1635AK Logo
338 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
