Question about SanDisk Sansa e250 MP3 Player
Light is on and shows connected, the USB is not recognized by the PC, No other buttons work
  • kakima Jul 07, 2010
    Press the power button and hold it for at least fifteen seconds before releasing it. Does that do anything?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • SanDisk Master
  • 102,366 Answers
Having gone over a month without a response, I assume the reset solved the problem.
Posted on Sep 02, 2010
When I Connect My Aiptek 8100 camera to the PC, they show a message "USB device not recognized." Is this because I did not install it's driver? If so please tell me where I can find the driver?
Usually usb device not recognized is due to damaged usb cable or usb port..use a different usb cable and connect it to your pc, if your usb cable is ok then connect it to a different usb port. if the problem in not with the usb cable or port install driver from the cd you got with camera. if you dont have that cd download driver from the device manufacturer site.
Oct 03, 2012 | PC Mall 8100 (MODEL 8100) PC Notebook
Wifi modem is not recognized
Try recycling the wireless router by unplugging the power to it and wait 20 seconds then plug the router back in. Sometimes that is all it takes.
After recycling the router if the adapter still does not show any wireless networks make sure you don't have the wireless radio turned off in the software that runs the adapter.
If all fails, try the adapter in another usb port if it is a usb adapter.
You could reinstall the adapter's software and driver.
May 06, 2012 | AcerPower 2000-UD431C - Core 2 Duo E4300...
Laptop will not recognize psp
Hi lawolf77,
If your laptop wont recognize your PSP there might be a connection problem between the two. So you need to check what's causing the problem. There are several ways to check if PSP and your computer are properly connected, one good example is by checking the connectors and the device setting.
If you want to check some configuration on how to connect your PSP to your PC please try to follow these steps:
1. First, connect your PSP to your PC using a usb cable.
- please make sure both ends are properly intact.
2. Using the left and right directional button find "Setting", then scroll down or up to find the "USB CONNECTION".
3. USB CONNECTION will display after you pressed the x button.
4. Please wait until computer detects the USB connection. After that it will show the drive for your PSP. usually F: or G:
5. Click on your PSP drive letter.
6. Now you can determine if your PC recognizes the PSP, just access the root folder and try to put some files on it.
Hope it helps.
Thank you for using FixYa.
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
My nokia 6600i is not recognizing the usb wire when connected to the computer and when connecting the headset it keeps showing the usb wire icon for some minutes and then asks to connect the device. I...
Hi, if you want your PC to recognize the phone your using, you will need to install a nokia connectivity first before install nokia pc suite.
Nokia connectivity is a driver that makes your PC to recognize the phone when connected.
When you install the nokia connectivity, install nokia pc suite, and then try it out again. am sure it will work.
Note:Hope the cables are ok.
Take care.
Jun 21, 2010 | Nokia 6600i Slide Cell Phone
My new gopro camera is not recognized by my mac when plugged in via usb...?
You need to push the POWER/MODE button once it is connected and the red charging light is on. It will then say "usb" and will show up on the desktop for you.
Feb 04, 2010 | GoPro Digital Hero 3 Digital Camera
I plug in my mouse to my laptop and it wont work, the bottem doesnt even turn red.. when i connect it all it says is usb device not recognized, it worked last night and tonight its not.
Try disconnecting the mouse from the usb port and reboot the unit.
Now, on your touch pad, top left blue led is let showing it is functioning. Press the center button next to the led, which will shut off the internal mouse.
Plug in your mouse to a different USB port and the unit should see the mouse.
If not and the mouse does not light up, replace the mouse.
You may have had a conflict with the internal and external mouse.
Nov 13, 2009 | HP Pavilion dv9000z Notebook
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
Unrecognized Flash Drive
Check out if the USB ports are 1.1 or 2.0
Your computer may use 1.1 and not see the newer 2.0
May 07, 2009 | Dell Dimension 8300 PC Desktop
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
Pc cant recognize the camera on the USB port
What is the Pc doing that shows you it is not recognizing the camera?
Have you looked in My computer at your drives to see if it is showing there? For some reason mine sometimes shows up my F drive instead of my camera drive. Then you can just click on the drive and open the folder for the photos.
Aug 22, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
SanDisk Sansa e250 MP3 Player Logo
18 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
