Question about Ferret Instruments Digital Tach Advance Timing Light
97 eclipse 2.0 got timmin set new wires new cole pack new cam sinser and it still wont iddle and
  • 5,603 Answers
Check the auto-idle speed motor and EGR valve.
Take to an AutoZone or someplace they can read out any error codes for you.
Posted on Jul 07, 2010
1996 plymouth grand voyager 3.3 does not fire have change ecm cole cam sensor crank sensor
Did you test power an grounds ? B+ to coil pack . Check for battery voltage at dark green with orange stripe wire at coil pack . No B+ voltage there you need a ASD relay - auto shut down relay !
Jan 05, 2016 | Plymouth Cars & Trucks
1999 mitsubishi eclipse automatic transmission wont shift into 4th gear.
First off.. If you have a check engine light on, Find someone with an OBD2 READER or buy one yourself(very good tool to have) and that will give you the code(s) to your problem..
If not.. Check ALL your fuses..
If those are good and you DO NOT have a sealed tranny.. Check your fluid..
If all the above check out good.. It's gonna be 1 of 2 things..
1. Your overdrive is either turned off and/or damaged.. (Over drive on: uses all 4 gears/Over drive off: uses only 3 gears)
2. Your shift silonoid pack is damaged, which normally when this happens your car goes into a thing called "dummy mode" and keeps the tranny ONLY in 2nd gear..
Now assuming your car shifts into every other gear just fine.. And the fact that normally reverse is the first gear to go out.. I'm gonna say it's your overdrive or a relay that runs with your overdrive..
Let me know what happens or if you have anymore questions..
-Daniel
Proud Owner of the
sickest 97 eclipse.
Sep 28, 2014 | 1999 Mitsubishi Eclipse
Ihave changed the crank sensor and the coles on the plugs but still the it wont give a spark.
DID YOU CHECK THE COIL PACK.........THIS SENDS A SPARK TO YOUR SPARK PLUG
Apr 15, 2014 | 2005 Toyota RunX 160i
I have a 97 pontiac grand prix and it will turn over but it wont start. i've had it look at my a couple mechanics and they said it wasnt my fuel pump maybe its the coil pack, so i buy a new set of
Learning how to test a GM distributor less ignition system rather then guessing an replacing parts is the proper way to diagnose . Pulling a couple of pull wires of the same coil an having someone crank the engine over to see if there is spark would the first test . If there is no spark ,could be the ignition module , or the crankshaft postion sensor .
GM 3 8L Ignition Control Module And Crank 3X 18X Sensor Test
Jan 03, 2018 | 1997 Pontiac Grand Prix
92 dodge D150 3.9l replaced timmin gears and chain new distributor rotor wires plugs timmin is dead on but will not start
Can you take the valve cover off and turn the crank until the number one valve closes, then check the rotor on the dist ?
TDC for number one cyl is when that intake valve closes.
I assume you checked the compression and all 6 cylinders are ok ?
If you have compression and the valve timing is close, you should be able to turn the dist and get it to backfire or something if the ignition timing is the only problem.
Jul 19, 2012 | 1992 Dodge Dakota
CAR HAS A MISS,ALSO VIBRATES AR-T A CERTAIN SPEED
bad plug or wire possibly a weak coil pack MIGHT be a cam position sensor. sounds like what happened with my 97 olds 88, was a weak 2/5 coil pack.
Jan 13, 2011 | 1995 Oldsmobile Ninety Eight
Swapped a 1999 420A engine into a 1995 eclipse (also a 420A) and we have no spark. We started by checking the cam sensor and it is working properly it is upside down from the 95 but the ASD relay is...
first the cam sensor shouldn't be upside down from the 95. they both should be with the plug facing down. they 95 CAS has a different plug than the 99 CAS.
the 95 has round pins and the 99 has flat pins.
95-96
97-99
also the 95-96 relays are opposite the 97-99
95-96
97-99
besides that it could be the ecu. i also have heard of the locating pin on the intake cam shearing off, allowing the gear to turn with the timing belt without the actual camshaft spinning.
Sep 27, 2010 | 1996 Mitsubishi Eclipse
After replacing a camshaft position sensor a p1390 shows up
Cam sensor fires the injectors so ignition control is not really what it does. The crankshaft sensor provides spark control, the Cam sensor provides injector pulse timing.
The actual code no it throws is much more use for us to diagnose...pls specify the Engine light code and I can be much more helpful.
Why did u change the cam sensor for an oil leak? that does not seem to be an appropriate repair.... anyhow more info=better help
Jan 17, 2009 | 1999 Mitsubishi Eclipse
I have a 1995 mitsubishi eclipse, 4 cylinder, 2.0 non-turbo. The car will crank but there is no spark and we are not getting any gas. We've checked all of the fuses and the relays. Do you have any...
if you haven't checked the ASD relay, make sure its working.
175c874.jpg if thats okay, check the Cam Angle and Crank Angle sensors. if it isn't any of those, its probably the ECU
Jul 22, 2008 | Mitsubishi Eclipse Cars & Trucks
Can i bplt up a eclipse 2.0L 420a non turbo to a 95 eagle talon non turbo
yes. they are exactly the same.
NOTE:
  • the 95-96 year models, have a few sensor plugs that are different than the 97-99 models. such as the coil pack and the cam angle senor.
Jul 21, 2008 | 1994 Eagle Talon
Ferret Instruments  Digital Tach Advance Timing Light Logo
55 people viewed this question
Top Ferret Instruments Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Ferret Instruments Measuring Tool and Sensor Expert? Answer questions, earn points and help others
