Question about Toshiba 22LV505 22 in. LCD TV
Toshiba 22LV505 TV-DVD:
Toshiba 22" Model 22LV505 TV-DVD:
I get sound but no picture. Just a black screen. A very dim (extremely dim) backlight is visible at start-up (when the unit is turned on), but it goes to black in less than a second. Inserted a DVD and the result is the same (sound but no picture). Is this a backlight issue? Is there a fuse for the backlight? Any fuse (in this unit) that I could replace myself?
I have unplugged and plugged the unit, tried to see if I could do picture set-up (remote control), but no luck so far.
Thanks for any help...
Kevin
  • 11,361 Answers
Check the DC filter caps in the power supply first. Check the 24vdc (or 18vdc for this 22" model) to see if it goes away when the screen goes black.
There are main AC fuse, backlight inverter fuses, T-CON fuses.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 08, 2010
I have a Toshiba 50L2300U TV which has sound, but the screen is black. I believe it's because the backlight inverter is not functioning. What part needs to be replaced?
Hi Anonymous, The link below is a YouTube video showing how to fix a Toshiba television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
https://www.youtube.com/watch?v=WtRuUBS9doE
Toshiba 55HT1U repair No Picture
May 05, 2016 | Toshiba 50L2300U
No picture
Sounds like you have a backlight problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flashlight on the screen. If you see a faint picture you have a backlight fault. It could be as simple as a bad capacitor in the power supply, or a faulty inverter board, or in rare cases a bad backlamp.
May 04, 2013 | LG 32LD350 32 in. LCD TV
My toshiba 22cv100u screen is black when I have tv on, i have sound but no picture
your backlight may be out....I working on one with same problem...the transformer on the backlight inverter board went bad, its about 12 dollars on ebay....but in your case, would require some troubleshooting to determine if you have the same problem. there is an access panel on the back of the tv, under that is 4 connectors, they are high voltage out to the backlight lamps. you would need a volt meter to determine if the lamps are bad or the board
Mar 10, 2012 | Toshiba 22CV100U 22 in. LCD HDTV/DVD Combo
No picture
Hello
The T'Con board [Timeing control Board] has to be suspected for damage. Replace it. this board can be bought from the authorised service center for Toshiba at your town.
Dec 31, 2011 | Toshiba 22LV505 22 in. LCD TV
Toshiba 22lv505 TV/DVD Region Code Error
maybe the spindle motor is turning defect causing not to spin the disc naturally,its time to have to check that to the Toshiba service center
Jun 20, 2010 | Toshiba 22LV505 22 in. LCD TV
When I turn on the tv, Get a blank screen with
Unplug it,replug it back an hour later,the tv should set back to the factory setting.
Mar 22, 2010 | Toshiba 22LV505 22 in. LCD TV
Dim display ... no backlight
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 30, 2009 | Toshiba Qosmio G25 (G25-AV513) PC Notebook
Sound with no picture
the problem is in the backlight try to measure the supply.and replace the inverter.
Dec 05, 2007 | Toshiba LCDTV/DVD Player 19HLV87
Toshiba 22LV505 22 in. LCD TV Logo
697 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
