Need info on bios and config
Compaq mother board 201479-001 pc worked but cant work on bios or config
  • djflo
    djflo May 02, 2008
    Intel® Desktop Board D845PT. the pc boots to win xp fine. but i want to get into the bios I pressed F1,F2
    all keys but can't get into bios.pc won't boot off cd or disk drive I think it was turned off. I also changed the key board.
    the pc was giving to me. Is there another
    way to get in?
  • 871 Answers
Please follow what map9966 has posted. thanks map9966...
Posted on Apr 20, 2008
    President:
  • 2,351 Answers
Hi wootwhoo, here is the link for your Compaq Presario 7940 Desktop 201479-001.
http://h10025.www1.hp.com/ewfrf/wc/product?product=94550&lc=en&cc=us&dlc=en&submit.y=4&submit.x=5&lang=en&cc=us
Everything you need is listed within this link. It's a matter of looking. Since you need help setting up your bios settings. Than the link below will help you through it. I did not find a download for the manual. (Which is what I'm used to using for guidence for setting up bios's).
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07110&lc=en&cc=us&dlc=en&product=94550&lang=en
Now this page/link will walk you through setting up the bios.
All you need to do is scroll down the page. Compaq has pictures to help. Without the board & all it's connected parts I can't walk you through this but I can help some.
If you get stuck you can post back here & I'll try to help you out.
Compaq is unknowing which key to press to enter your bios.
This is how it works. Just after powering on the PC start pressing the F10 key every 2 seconds. The main menu of the bios will open. If, F10 does not open you to the bios we'll have to try some other F keys. (You can only try one F ke at a time).
Try the F2 key next & than the F1 key & the F12 key. One of thses will open the main menue.
It should help you to know most of the settings will already be set to their defaults. (Like most boards are). If your not sure you can set default settings at the main menu. Save & exit. The PC will auto restart. Go back into the bios by pressing the correct F key. Normal items to set are (Time & Date) at the main menu.
You should see your cdrom listed & hard drive listed. Things you want to turn on. Audio should be set to Enable or on if you do not have a seperate sound card. Same for video. Memory & CPU settings (No settings). They usually are already set. Boot will need to be set. Normal is. Floppy Disk is first, 2 is CDROM & 3 is hard drive.
First time through a bios will be a wee bit tough. So read twice & set once. Follow Compaq's instructions.
When in doupt, ask.
Luck!
Mike
I forgot my password to get into the bios of my Compaq armada laptop. Is there another way to get past that password besides taking the battery out? It did not work.
Typically, removing the mother board battery will remove all user settings, including the password you put in. The mother board battery is not the computer battery. Find it in one of the little compartments in the bottom. Again, typically, the password may be persistent for up to 30 minutes. Remove the battery and reattach it tomorrow.
Oct 27, 2011 | Compaq Armada M700 Notebook
I have a compaq presario v3000 but the bios cant detect my hard drive, it seems that there is no power coming into the hard drive, the hard drive is tested on other unit but it work just fine.. i hope...
it is the mother board disconnect pwr...take out battery...use hot soldering iron with smallest tip and reheat connector wires if you can...
let us know what you did
Nov 25, 2010 | HP Compaq Presario v3000z Notebook
Bios chip location on mother board
no,, reinstalll the vista,, the problem will not occur again
Jan 08, 2010 | HP Compaq Presario V2000 Notebook
Compaq desktop pc serial no 6S2BLB5ZP1F0 mother board drivers
get a win xp bootable disk and install the o.s. it will automatically install the drivers of some devices. however, u must copy the bios version, and other devices found in the mother board, then download it through the net...
May 17, 2009 | HP Compaq Motherboard
Corrupted DMI Strings in BIOS
May be the bios chip on the mother board defective.Plse contact a technician who is doing chiplevel servicing mother board
May 01, 2009 | Computers & Internet
I have a old compaq desktop computer which is supported prientieum 4 processer but i lost my mother bord driver cd.which site give me free down load mother board cd.
Visit driversguide.com, register yourself(its free) and finally visit this link:
http://members.driverguide.com/index.php?action=dosearch&qm0=Compaq+Presario+5000+PC&qa5=1&qa6=236&qa7=All+Windows&dp=3&sm=h&jmd=and&fzz=d&si=0714a172c4fc2aef5b5a2106375cb1db&st=1240205618&gqm0=Compaq+Presario+5000+PC+BIOS+Motherboard
and get your drivers.......sodeep
Apr 20, 2009 | Compaq Presario 5000 PC Desktop
Serial port dosent work
make sure serial port is enables in the bios config, the one you can enter just when you power up the computer and press... usually DEL, but also F1, F2,F10, etc, depending on the motherboard...
i cannot tell you where in the bios is that parameter, i don`t know what bios do you have... so spend a time in there and you will find it...
Mar 19, 2008 | ASUS P5P800-VM Motherboard
Computers & Internet Logo
444 people viewed this question
David Payne
David Payne
