Question about Weber Genesis Silver A Grill
Low flame change out the tank but the flame is now very low. tried re setting the regulator by the manual but doesn't seem to help
  • 8,220 Answers
Your tank has a safety device. Read more here
Posted on Jul 14, 2010
    Champion:
  • 274 Answers
Try replacing the hose and regulator, easy to do, and not very expensive.
Posted on Jul 12, 2010
My gas grill sprays alot of gas when i first turn it on, the has very low flame
Hi axmaster892
You have a faulty gas regulator...
Gas Regulators are notorious for doing just what yours is doing.
After sitting in the same position for a length of time they freeze in that position, then along comes a grain of sand, or other debris and blocks the gas flow.
Remove the regulator if possible, if not try it in place with the tank removed.
Get a plastic headed hammer and gently but firmly tap on the regulator, your trying to free up the diaghram inside.
After tapping and freeing the regulator diaphram reinstall and you will be good to go.
If this does not work, the replace the regulator as it is defective.
Some regulators are ajustable, if you have one of those then try to adjust the regulator, you will see a cap on top of the regulator, that is where the adjustment screw is located.
Please take time to rate me
Bud
Oct 29, 2012 | Brinkmann Grilling
I can't get any burners to light. I have changed tank,regulator,and cleaned burners. When I open regulator all the way and I use match. A small puff then out. It seems simple but can get it to work....
The problem you're experiencing is cause by one of two things. Low gas in the tank or a locked up regulator. To solve the problem, do the following:
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! Thanks for choosing FixYa.
Sep 20, 2011 | Char-Broil Designer 463261106 Grill
The gas doesn't seem to be feeding properly?
Bruce, this is probably due to the grill's gas regulator being locked up.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Jul 15, 2011 | Napoleon Ultra Chef US405RSBI Propane...
Low flame after winter non usage. All burners light, but low flame. Need to be cleaned? New regulator, fill tank?
Could be a low or empty tank. But, I suspect if the tank was turned OFF all winter and you just turned it ON, the tank's OPD Valve has lcked up you grills regulator. To test this theory, turn the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve on VERY, VERY SLOWLY (slow motion, slow). Once the tank valve is fully open, light the burner farthest from the tank and turn it to it's highest setting. Does the flame height now appear to be normal. If so, light the remaining burner(s) the same way. If everything has returned to normal, you've solved the problem. If it hasn't, then more thank likely your Propane Tank is empty.
Hope this helped you solve the problem
Apr 03, 2011 | Brinkmann 810-2300-B Grill
Won't light properly or vary the flame
You're probably turning the LP tank valve on too fast. Close the tank valve, disconnect it and reconnect it. Then very slowly turn on the tank valve. Make sure all your grill knobs are closed. Light one at a time and turn to low setting. After they are all lit, slowly turn up the heat on each as needed. Hope this helps. Douglas
Jun 07, 2010 | Weber Q Grill
Low flame
Try putting on a new regulator
Nov 23, 2009 | Weber Q Grill
When ever we get a full 20 lb. tank of lp gas, our 3 burner weber grill has a very low flame and it goes out frequently with low heat until it runs for a long time, then it runs normal.
Hello.
It sounds like your regulator is not quite right. Try a different one, or just replace yours. New regulators are inexpensive, and are available at Lowe's/Ace/Similar.
Best regards (and happy grillin'), --W/D--
Aug 18, 2009 | Grilling
Low gas flow - low heat
Hi Lyon,
Yeah, it's the regulator. Fortunately, they're cheap and easy to replace!
You can look on line for part number 80012. Or you can remove yours and take it to Home Depot or Lowe's in the outdoor cooking area and match up a replacement. <--- they're all the same... just make sure the compression fitting (the brass end) is the same size.
The only other thing I could recommend is this... Turn the LP bottle completely off. Then completely remove the big plastic knurled knob from the tank. Now replace the knob back onto the tank (all the way and make sure it's tight). Then S L O W L Y turn the gas back on. Now try your pit. If you get the same flame, it's the regulator. If you get full flame, you just reset the safety device inside the tank.
I'm betting regulator. Good luck and happy cookin'!
SG
Jun 03, 2009 | Weber Q Grill
Grill with a full tank of gas will not get hot
Low flame, low temperature, yellow flame: This has become the biggest problem with many grills these days and it's almost always because of the regulator (the funny UFO shaped thing on the gas hose). Regulators seem to be stickier these days and when they stick you don't get enough gas to generate a good grilling temperature. To get your regulator unstuck you need to release the pressure on it. Follow these steps exactly:
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
To keep the regulator from sticking again make sure that you turn off the control valves first, then turn off the tank valve. Always open your tank valve slowly. If this doesn't work give it a second try. If you still have low flame then you probably have a faulty regulator that will need to be replaced.
May 24, 2009 | Char-Broil Patio Caddie 4654870 (LP) Grill
Heat is about low or just a little higher on high setting
May 24, 2009 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Weber Genesis Silver A Grill Logo
173 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
