Control panel is blank, when the dial is turned to a wash mode the door lock light comes on. door lock light remains illuminated, door will open and close. light remains illuminated control panel is blank when the dial is moved back to zero , the light goes out, control panel remains blank.
  • shammon2 Jul 12, 2010
    I've bought a new customer interface module around 90 usd,
    still no difference.
    The light is telling us that we mustn't open the door ,but the door will open,
    is it the signal to the door module or the door module itself that could be at fault,
    EIther way there is absolutely no signal to the interface module.
    If it's the main module, thats about another 200 usd to replace and I'd still be guessing.
    President:
  • 1,554 Answers
This is obviously an issue with the control panel electronics. There must be a loose or broken wiring connection or the control panel electronics is going out. Indicate the make and the exact model number of the machine for further and accurate troubleshooting. You don't have to accept, reject, or rate this post in order to add information or post follow-up questions. Accepting and rating a solution does not stop you from posting clarifications or follow-up questions. You may keep posting and communicate with an expert as long as you need assistance with regard to the issue stated herein.
Posted on Jul 07, 2010
  • 1 more comment
  • shammon2 Jul 07, 2010
    it's an electrolux ewf1430,
    first time i've used the service, realised make and model was missing after posting.
  • Jahn27
    Jahn27 Jul 07, 2010
    Remove the top panel then the screws attaching the control panel/console to the cabinet. Remove the console then check the console electronics wiring connections. Replace the console electronics if there's no issue found with the wiring connections.
  • Jahn27
    Jahn27 Jul 12, 2010
    The main module must then be at fault because the door lock mechanism is independent of the user interface module. A faulty door lock mechanism cannot result in a blank control panel and vice-versa. The false detection of a locked door clearly indicates a faulty main module. You may disconnect the door lock mechanism connection to the main module and verify this condition. You can definitely tell then that the main module is the one at fault if door lock light keeps illuminated. If the door lock light has gone, disconnect all other connections to the main module except the user interface and of course the power. Control panel still blank? If yes, then you are 101% sure that the main module is at fault. Otherwise, one of the disconnected components must be preventing the main module to power up the control panel. Reconnect one of the components then power up the machine. Do the same with the other parts one at a time until you run through that faulty part. This is the method of isolation and elimination and it should work in determining the real score now that the user interface is known to be in good working condition.
2009g6 dome light comes on all by its self why
The dome lamp switch has 3 positions: DOOR, OFF, and ON. When in the DOOR position, the dome lamp operation is controlled by the body control module (BCM).The ON position provides a ground for continuous operation. Ground is provided at G302. The OFF position turns OFF any dome lamp operation. The courtesy lamps, may be manually turned ON by placing the instrument panel (I/P) dimmer switch in the DOME position. When the dome lamp switch is in the DOOR position, the dome lamp will illuminate when a door is opened. When a door is opened, the courtesy lamps turn ON. After all the doors have been closed, the courtesy lamps will remain illuminated approximately 10 seconds after the last door closes. When the driver places the dome lamp switch in the OFF position, the dome lamp will be disabled.
Do you hear any chimes when the light comes on ? Door ajar switch problem , maybe . Picture of car with door open light lit on the instrument cluster ? When does it come on , when driving or sitting still or both ?
You mite want to take it to a qualified repair shop and have it checked for DTC'S - diagnostic trouble codes .
DTC B2555 05: Passenger Compartment Lamp Control Circuit Short to Battery or Open
The body control module (BCM) applies battery voltage to the courtesy lamps through the courtesy lamps high control circuit. When any door is opened, the door ajar switch contacts close and the BCM receives a door-open input. If the BCM receives a door lock or unlock input or a rear hatch open input, the BCM will activate the courtesy lamp high control circuit, providing battery voltage to all of the dome lamps, reading lamps, rear compartment lamp, and vanity mirror lamps. In the event that any of these lamps were to remain illuminated for more than 20 minutes with the ignition switch in the OFF position, the BCM will deactivate the courtesy lamp high control circuit to prevent a total battery discharge condition.
Do you know how to do basic automotive electrical testing ? How to test inputs and outputs of a control module ? in this case the BCM - body control module ? Find wiring diagrams at
http://www.bbbind.com/free_tsb.html also watch this video ECM Inputs and Outputs Diagnosis
Jan 19, 2017 | 2009 Pontiac G6
Just got my 2003 explorer sport trac dome light dont come on when you open the doors but they come on when you push the button to turn them on how do I get them to come on when I open the doors?????
The instrument cluster illuminates the interior lamps when an unlock signal is received from the vehicle security module. The illuminated entry feature will be canceled when any of the following conditions are met:
  • 25 seconds have elapsed since the illuminated entry feature was activated and the interior lamp control is not activated (door ajar or courtesy lamp switch on).
  • The instrument cluster receives a request from the vehicle security module (remote transmitter lock button pressed) and the interior lamp control is not activated.
  • The ignition is in the RUN or START position and the interior lamp control is not activated.
The instrument cluster illuminates the courtesy lamps when any door is open or ajar. The courtesy lamps shuts off when the doors are closed and the illuminated entry feature is not active or when the vehicle speed is greater than 5 mph (8 km/h). The interior lamps are not reactivated until the vehicle speed is less than 3 mph (5 km/h) and a new door open warning lamp signal is received.
The instrument cluster controls the courtesy lamps illuminated entry function by activating the battery saver relay.
The panel dimmer switch is integrated into the headlamp switch and controls the interior lamps by activating the instrument cluster through circuit 1034 (BK/WH).
The vehicle security module sends a signal to the instrument cluster on the UBP network circuit to indicate a request to turn the illuminated entry feature on or off.
The on-demand lamps, glove compartment assembly, homelink module, puddle lamps and illuminated vanity mirrors are controlled by the battery saver relay. The battery saver relay becomes active (relay coil is energized) when the instrument is in the awake mode, or in the sleep mode (relay coil is de-energized).
Nov 28, 2016 | 2003 Ford Explorer Sport Trac
My interior light won't come on in my 1999 Buick Lesabre. I have checked the bulb & the fuse. Can anyone help me with this problem? Any ideas are sincerely appreciated.
Courtesy Lights
The courtesy lights come on under the following conditions:
Any door is opened.
The interior lamp switch is in the ON position.
The keyless entry transmitter unlocks the doors (illuminated entry).
When the key is removed from the ignition switch with all of the doors closed, the courtesy lights light for approximately 25 seconds before fading out.
Battery positive voltage (B+) is applied at all times through the IP fuse block CTSY LP/PWR MIR fuse 6A via CKT 640 (ORN) through the body control module (MALL) to the courtesy lights via CKT 1732 (ORN). The MALL provides a ground through CKT 156 (WHT) for the courtesy lights under the following conditions:
The MALL receives an input from a door being opened.
The MALL receives an input from the interior lamp being turned ON.
The MALL receives an input from the doors being unlocked using the keyless entry transmitter.
The courtesy lamps then light.
When the courtesy lights are activated by opening and closing a door, the courtesy lights will remain on for approximately 25 seconds before fading out after all of the doors are closed. If the ignition switch is turned to START or RUN within the 25 seconds, the lights immediately begin to fade out. If a door is left open, the MALL removes battery positive voltage (B+) to the courtesy lights after 10 minutes. When the courtesy lights are activated by the interior lamp switch, the lights remain on as long as the interior lamp switch is in the ON position. When the courtesy lights are activated by unlocking the doors using the keyless entry transmitter, the lights remain on for approximately 40 seconds. If the doors are locked using the keyless entry transmitter within the 40 seconds, the lights immediately begin to fade out.
Body Control Module (MALL) Diagnostic Mode
For a detailed explanation of the MALL module diagnostic mode, refer to Body Control Module Cell 51.
What interior light ? Dome , courtesy lights etc....They don't work with switch, keyless entry , door opening ?
What
Dec 03, 2015 | Buick Cars & Trucks
2004 yukon slt courtesy light relay location
Here is a description of the courtesy lights , there is no relay ! Controlled by the BCM - body control module !
The courtesy/illuminated entry lamps, may be manually turned on or off by placing the interior lamp switch in the ON or OFF position. If an outside door handle is lifted or a door is opened, the courtesy/illuminated entry lamps illuminate. After all the doors have been closed the courtesy/illuminated entry lamps will remain illuminated approximately 15 seconds. The courtesy/illuminated entry lamps will also turn on prior to any door being opened, and remain illuminated approximately 40 seconds when the driver removes the ignition key. When the driver places the dome lamp defeat switch in the OFF position, the courtesy/illuminated entry lamps will be disabled.
The left and right front door courtesy lamps are controlled, and receive voltage and ground from the drivers door module (DDM) and the passenger door module (PDM) respectively. The body control module (BCM), DDM, and the PDM communicate through class 2 serial data for the lamp illumination commands and the door ajar switches.
The remaining courtesy lamps are controlled and receive voltage from the BCM. Voltage for the courtesy lamp supply voltage circuit and the backup lamp supply voltage circuit is from the TBC B fuse in the instrument panel fuse block directly through the BCM to these circuits. A short to ground on either of these circuits will open the fuse. Ground is provided to the footwell lamps and all courtesy/reading lamps at G203. Ground is provided to the right middle and right rear door at G306. Ground is provided to the left middle and left rear door at G302.
Mar 17, 2015 | Cars & Trucks
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
Door panel lights wont turn off
push the door switches in by hand and see if the lights go out. Here's some diagnostic info:
Vehicles may be equipped with either a generic electronic module (GEM) or a central timer module (CTM) depending on vehicle options.
  • Vehicles with 4-wheel drive or the power group option will be equipped with a GEM.
  • Vehicles with 2-wheel drive and no power group option will be equipped with a CTM.
Courtesy Lamps The GEM and the CTM illuminate the interior lamps when any door is open or ajar. The interior lamps are: the interior lamp, the cargo lamp and the door courtesy lamp. The courtesy lamps will shut off when:
  • The doors are closed and the illuminated entry (GEM only) feature is not active.
  • The vehicle speed is greater than 15 mph (24 km/h). The interior lamps will not be reactivated until the vehicle speed is less than 10 mph (16 km/h) and a new door open warning lamp switch signal is received (GEM only).
The system inputs to the GEM/CTM are as follows:
  • The door open warning lamp switches. (Grounded when door is ajar; an open circuit when the door is closed.)
  • The vehicle speed sensor (VSS) input. (Sinusoid Wave: 0.7V-20V, 2.2 Hz/MPH [1.37 Hz/km/h] [GEM only].)
The system output to the GEM/CTM is as follows:
  • The interior lamp relay coil output. (Grounded when activated; open circuit when deactivated.)
Interior Lamp Relay The GEM and the CTM control the interior lamps and illuminated entry function with the interior lamp relay.
The relay is activated by applying ground to the relay coil through GEM C267-15, and is deactivated by removing the ground signal.
Panel Dimmer Switch The panel dimmer switch is integrated into the headlamp switch and controls the interior lamps by activating the interior lamp relay.
Illuminated Entry (GEM Only) The GEM illuminates the interior lamps when an unlock signal is received from the remote anti-theft personality (RAP) module. The illuminated entry feature will be canceled when any of the following conditions are met:
  • 25 seconds have elapsed since the illuminated entry feature was activated and the courtesy lamp feature is not activated.
  • The GEM receives a request from the RAP module (remote transmitter lock button pressed) and the courtesy lamp feature is not activated.
  • The ignition is in the RUN or START position and the courtesy lamp feature is not activated.
The illuminated entry inputs are:
  • RAP illuminated entry request. (Grounded pulse of varying length.)
  • Ignition switch in the RUN position. (Battery voltage on both the RUN and RUN/ACC inputs.)
The illuminated entry outputs are:
  • Interior lamp relay coil output. (Grounded when activated; an open circuit when deactivated.)
RAP Module The RAP module sends a signal to the GEM on the illuminated entry request circuit to indicate a request to turn the illuminated entry feature on or off. Circuit 1013 (BR/LG) is normally sent 12 volts by the GEM. The RAP module shorts this circuit to ground with a pulse of either of the following lengths:
  • 200 ms pulse from RAP receiver assembly requests illuminated entry ON (unlock button pressed).
  • 300 ms pulse from RAP receiver assembly requests illuminated entry OFF (lock button pressed).
GEM Sleep Mode The GEM and the CTM sleep mode deactivate all outputs to conserve battery power. Sleep mode is entered when the ignition has not entered the RUN or ACC position and 45 minutes has elapsed since the last wake-up input was received. In this mode, GEM current consumption is reduced to 5.0 mA or less. During sleep mode the GEM monitors the following wake-up inputs:
  • Both front door open warning lamp switches.
  • Ignition switch in the key-in, ACC and RUN position.
The GEM sleep mode outputs are:
  • None. (All circuits are deactivated during sleep mode.)
If a change in any of the above inputs occur while the GEM is asleep, the GEM will wake up and monitor all of its inputs and have the ability to activate any of its outputs.
The following components are under the control of the battery saver relay:
  • Interior lamp.
  • Engine compartment lamp.
  • Glove compartment lamp.
  • Panel dimmer switch.
  • Interior lamp relay.
The battery saver relay becomes active (relay coil is energized) when the GEM is in the awake mode, and is deactivated (relay coil is de-energized) in the sleep mode. The battery saver will remain active until the ignition switch is removed from the ACC or RUN position and 45 minutes have passed since the last active input was received (see sleep mode inputs). At that time, the relay will be deactivated and power to the above circuits will terminate.
The battery saver inputs are the GEM sleep mode inputs.
The battery saver output is the battery saver relay.
Inspection and Verification — GEM/CTM
  1. The interior lighting system is a generic electronic module (GEM)/central timer module (CTM) controlled system. Refer to Section 419-10 for additional information regarding GEM/CTM diagnostic strategies.
  1. Verify the customer concern by operating the interior lamps.
  1. Visually inspect for obvious signs of mechanical and electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Switch(es)
  • Fuse(s) 14 (15A), 15 (5A), 4 (5A), 8(5A), and 103 (50A).
  • Wiring harness
  • Loose or corroded connector(s)
  • Circuitry open/shorted
  • Bulb(s)
  1. If the concern remains after the inspection, connect the New Generation STAR (NGS) Tester to the data link connector (DLC) located beneath the instrument panel, and select the vehicle to be tested from the NGS menu. If the NGS does not communicate with the vehicle:
    • check that the program card is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
Oct 07, 2009 | 1999 Ford F250 Regular Cab
Interior lights do not come on
Is it an old van? Can you see on the door frame a switch does it come out when the door is opened (push in and out a few times). 3 position switch on always / off always and door switch?
Apr 10, 2017 | 1999 Ford Windstar
Door Lock
door lock blown this sometimes blows tracks off the main pcb behind the control panel. appliance doctor
Jan 29, 2007 | Hotpoint WMA44 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
