Question about Health & Beauty
I have a sungift 200 mobility scooter with an intermittent power problem. I have removed the top cover of the steering column, and there is no immediately obvious fault i.e corroded or disconnected wires. Sometimes when I turn the steering column, the power will just cut out, and the power light goes off, then if I turn the steering agin, it may or maynot return the power. I am quite sure it is an electrical fault, but where do I start to look?
  • 46 Answers
There is a short in the cord going from the controller to the speed controller check the wire down through the tiller where it passes through the under the scooter i would bet on the wires being frayed and grounding out when you turn , patch or replace the wire and put wire loom over it to keep it from happening again
Posted on Jul 11, 2010
What & where is the wig-wag control on rascal 200 mobility scooter.
Hi look on youre tiller steering column for a lever similar to photo ... Cheers
Nov 26, 2016 | Health & Beauty
Where can i obtain a manual for a Sungift mobility scooter
Contact your local mobility centre, they normally have somewhere they get all manuals , you could always try to google it also, imput scooter name and manuL download at the end, if its available on line that should bring it up.
Aug 14, 2016 | Health & Beauty
How do you remove a steering column from a 99 Mercedes Benz E320
disconnect both battery terminals let everything power down for 10min remove key and lock steering.remove airbag then steering wheel the stalks and clock spring then top and bottom column covers.next lower dash cover loosen and remove bolt and nut at knuckle where column and rack connects.unplug all sensors of column then undo securing bolts
Apr 03, 2016 | Cars & Trucks
My problem is with the tiller column of a 3 wheel mobility scooter it's very lose, it pulls to the right
if i remember correctly where the column goes into the floor area , base of scooter , you may have to turn the scooter up on end. there should be a large locking nut that can be tightened up not too tight other wise the steering won't work correctly.
Regards
Dec 15, 2012 | Electric Mobility Mobility Electric Power...
Parts
You don't need to go to a Mobility scooter manufacturer to get a bearing. Take the bearing down too your local bearing shop. They will measure it or use the numbers on the bearing to find you an exact match and you will get the bearing for allot less money too.
Jul 15, 2012 | Electric Mobility Health & Beauty
I'm trying to take some of the sloppyness out of the steering column, but as I don't have a manual, I'm reluctant to start taking bits off!
Joan and John,
This is typically not a do-it-yourself repair. The reason is that there are many parts to the steering column including upper and lower bearings and races, steering linkages, a front console wiring harness, and many other small parts. These parts must be assembled in sequence and aligned properly otherwise the scooter will not steer straight and will have noise and sloppiness in the column. You could also damage the wiring harness that goes through this area.
With that being said there ARE some adjustments that can be made to the tiller and steering column to improve its performance.
The tiller angle adjustment knob should be as tight as you can make it by hand.
If you place a block of wood under the front of the scooter you can check for free play with the front wheels off the ground. The tiller should move left and right without binding or noise. The top cup of the bearing race has some lock nuts that you can use as adjusters. Loosen the lock nuts and turn the top race clockwise until the sloppiness is gone and there is some resistance. Re-tighten the lock nuts making sure the column is centered. You don't want to over tighten the bearing races. The tie rods and ball joints are not a DIY adjustment or replacement.
If you need replacement of the top and bottom bearings find a local scooter mechanic or bike shop to do it for you.
If you have serious steering problems do not drive the scooter until it is repaired.
Hope this helps
Feb 10, 2011 | Pride Celebrity X 4-Wheel Electric Scooter...
Heavy steering on my s/h sungift 200,ok when raised off ground.tyre pressures correct.could it be something to do with the fibre washers on the main steering column.i dont think it is very old.have checked...
Hi Dave. I have had a few scooters that have had this problem. Most of them had the bearings tightened up to tight. Either the bearings on the steering column, or the bearings in the left or right stub axles. Just loosen off very slightly will help. Make sure that there is not too much movement in the bearings after adjusting them. Also give all the linkages a bit of a lube.
We are Invacare sales and service agents here in New Zealand, but I have never heard of this model.
Good luck. Neil.
Jul 10, 2010 | Invacare Supply Group Health & Beauty
I have an ActiveCare Medical Mobility Scooter - 4 Wheel Pilot Mobility Scooter (Model 2410), and do not know how to disassemble for transport in a 2004 Buick LaSabre. Is there an instruction manual...
Hi Rosemary. The best way is to remove the seat by releasing the lever to turn it slightly, then lifting it straight up and off.
Next take off the battery cover, disconnect the batteries and remove them from the scooter. This will make the machine much lighter and easier to lift or push up a ramp.
Next release the steering column and fold down towards the rear. Place a piece of packaging or similar under it, so that it doesn't rub on the body panels and scuff the paint.
Good luck. Neil.
Dec 18, 2009 | Electric Mobility Red Pilot 2410 4 Wheel...
Pride victory mobility scooter
1. Remove the four screws on the outside perimeter of the console base.
2. Lift off console top cover and disconnect the front-to-back cable.
3. Remove the throttle lever from the throttle pot.
Remove the four screws holding the console base to the mounting plate.
Oct 23, 2008 | Pride New Mobility Legend 4 Wheel Scooter
Health & Beauty Logo
642 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
