Question about Husqvarna 24HP VTwin Hydrostatic 54" Cut Riding Mower
Hotwire seat switch
Need to hotwire seat switch on 24v54 Husqvarna riding mower. It has 3 wire switch.
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
  • 42 Answers
SOURCE: how to replace drive belt
here is a diagram that will hopefully help you. let me know if it helps, or if you need further assistance. thanks.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chus%5cimages%5c33%5c28%5c0009.tif&ilsc=16&iliv=0&ilbr=0&ilif=g&ilre=8
Posted on Mar 15, 2009
SOURCE: mower quits when engaging mower deck of husqvarna yth 2348
Try putting a jumper wire on the wire going from the engine to the seat. Take that plug and put a wire from one side to the other. Be careful not to cut your feet off when engaging deck.
Posted on Mar 31, 2009
  • 106 Answers
SOURCE: My riding mower blows fuses once you turn the key.
Sounds like you are on the right path, maybe some wires on the ignition were replaced backward, and you are sending +12v directly to ground? Does it blow right away?
Posted on Jun 04, 2009
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
How do i hotwire my 1997 cbr 600f3 lost my key and need asap to ride in charity event
This has been asked before, the link is below. The answer doesn't say how to hotwire it, but provides hints on how to replace the key. A modern bike is probably pretty hard to hotwire.
http://www.fixya.com/motorcycles/t5589340-hot_wire_cbr
Jun 10, 2015 | Honda Motorcycles
How do I bypass the seat safety switch on a 5424 Husqvarna zero turn mower?
ether unplug it if wont start then jump the wire pigtail with a wire you can bypass both switch like this
Sep 16, 2014 | Husqvarna Rz5424 Zero Turn Lawn Mower...
When installing key in my b/d rechargable mower don't go in easy & won't start
IGNITION COIL BAD PULL WIRES OFF BACK AND HOTWIRE OR REPLACE IGNITION
May 09, 2012 | Garden
Wire seat so mower doesn't shut off
Put a piece of wire hooped in plug the seat switch plugged in to. It not good to jumper out safety items.
May 03, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
How to hot-wire a Simplicity Landlord 2010
Why hot wire when you can get a new key. There are only two types of keys.
Feb 01, 2012 | Briggs & Stratton Garden
Someone broke into my 1999 grand am ruined ignition switch and plug ins need to know how to hotwire
You won't be able to hotwire it due to the passlock antitheft system. Read about it in this link.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 16, 2011 | Cars & Trucks
Husqvarna Riding Lawn Mower 46 Cut model #454140010G MOWER will not ingadge
I can not say this enough, check the safety switches. There should be one on the seat, the clutch /brake pedal and /or the equipment pto switch. Also, check the wires running to these switches. They tend to move and vibrate as you mow and a worn spot in the wires can cause a short, resulting in the mower not starting.
Good Luck!!!
Jul 17, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
My Electic Front Drivers set Will not go Back and Forth It ia a 1991 Buick La Sabre
First you'll need to determine if the fuse and / or relay is good. If so, then check the seat switch by ' hotwiring ' ( running a positive wire from the battery to the positive side of the switch ) . if the hotwire worked, your switch is bad - if not then you may have a bad seat motor or corroded connection. You may need to remove the seat from the vehicle to further test connections and / or run your hotwire to the positive side of the motor, which may be difficult at best. I'd check the fuses first, then relay, the call your local shop since everything else can get complicated.
Nov 05, 2010 | 1991 Buick LeSabre
24v54 husqvarna: how to I increase max cutting height by a couple of inches?
It's not do-able without major modifications that may compromise safety, if you need much longer grass or wish to brush hog like cutting of really tall weeds you need a different rig or a power sickle attachment. I'm sorry but it's just not a good idea to hike the deck like that.
Jun 03, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Mower quits when engaging mower deck of husqvarna yth 2348
Mar 30, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna 24HP VTwin Hydrostatic 54" Cut Riding Mower Logo
101 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
