Question about Garden
I have a Husqvarna 235R trimmer. One of the fuel tubes going to the primer bulb cracked. I replaced the tube. At the same time I didn't know that the tube from the carburator to the fuel tank was cracked also. I replaced that one also. I don't know how far the tube extends into the fuel tank though. I couldn't get the bulb to prime so I switched the tube connections (the one from the carb to the bulb and the bulb to the fuel tank) to the bulb. I was able to get the bulb to prime and start the engine but the engine will not stay at idle. So I swithced them back and cannot start the engine. Which tube does the fuel filter go on the one from the carb or the one from the priming bulb.
  • jasll Aug 31, 2010
    I notice no response on this request and I have also had this same problem on my Sears Weedwacker after replacing broken lines. I believe I have lines correct but primer seems to be sluggish (does not readily return to dome shape after several pumps). I replaced the plug and it fired and ran strong for several seconds and then I could not get it to fire. It's 8 years old with no maintenance so am I looking at clogged ports and a need to rebuild carb?
trippssmengi
  • 76 Answers
SOURCE: I have a Homelite trimmer
Sometimes even if the diaphram and gaskets look ok they may not be. If the diaphram is stretched or distorted even a little they wont work properly,same for gaskets and other parts of the carb. sometimes the littlest things can make a big difference. I would try a complete rebuild kit and while everything is out of the carb. spray the carb real good and then lite-ly blow out the carb. with an air hose also if you take a twist tie from bread and take off half of the paper from the wire and carefully probe all holes in carb. that might do the trick for ya. After you put the high and low adjustment needles back in (if your zama carb. is set up with them) you'll want to set the low needle (after turning all the way in till it just bottoms) at 1 and 1/4 turns out and the high at just about 1and 1/2 turns out, then while running make final adjustments.
Posted on Jan 09, 2009
  • 38 Answers
SOURCE: Troy Built gas trimmer will not prime.ill not prime
To me it sounds like your line is clogged. It pumps towards the tank but not towards the carb. Open it up, and check your lines out, if it's clogged it could be a little too much oil (just saying if it smokes alot when it's on).
Posted on May 09, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: 323L Husqvarna trimmer
This sounds like the carb needs to be adjusted like it is letting to much fuel into the cylinder. There is supposed to be fuel and air mixture in the cylinder to make it fire. If there is to much fuel what will happen is that it will just build up in there and the air wont get hot enough as it compresses to start the engine.
Posted on May 21, 2009
  • 376 Answers
SOURCE: Craftsman trimmer won't prime
A new carburetor would be simplest solution. You could try disassembling the carb, cleaning and replacing diaphrams, but just replacing the carb would be my choice. What is the model # on the trimmer and I can tell you the part # of the carb you need.
Posted on May 24, 2009
#1 Taper
  • 1040 Answers
SOURCE: Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
Posted on May 26, 2009
Husqvarna 235R Manual The fuel lines on my 235R disintegrated. I have cut new ones from the right sort of tubing but cannot figure out where to route them to prevent fouling other parts. Is this shown...
The fuel hose from the tank goes under the carb to the left hand side of the carb and in front of the two feet on the bottom of the air filter housing, it is all a bit tight under there, the right hand pipe goes from the carb to the shorter connection on the primer, a pipe from the longer connection on the primer goes back to the tank
Oct 09, 2013 | Garden
Where do the fuels connect from fuel tank on husqvarna 326l
You should have 3 tubes, a fuel delivery tube, a fuel return tube and a fuel suction tube, the fuel delivery tube ( the one with the fuel filer on in the tank ) goes to the connection on the carb nearest to the pump cover held with a single screw, the other connection on the carb goes to the suction side of the primer bulb ( the shorter of the two connections ) the return to tank tube fits to the longer connection on the primer, this tube is just pushed into the top of the fuel tank,
Dec 29, 2012 | Husqvarna 28cc Gas Line Trimmer
Primer bulb
Hi Bob McDonnell....
Here is how your fuel should be routed...
Please rate me
Bud
Sep 26, 2012 | Garden
Need to replace the gasoline pickup tube on a Homelite SX135.
The typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to top fitting on carburator. Hope this helped and best wishes.
Sep 02, 2009 | Craftsman 25cc Gas Line Trimmer
My Poulan Pro weed trimmer SM132 does not run. I replaced the primer bulb and spark plug and it ran fine for 10 minutes. Now it will only start with the choke on and dies immediately. It will not start...
The primer does require two lines attached as it is a Walbro style primer. All four SM132 models uses the WT628 Carb. Since the trimmer ran 10 minutes then you have got all the lines connected right. Mostly you got trash in your carb or it simply needs rebuilding as the diaphragm may have pin hole in it or the check valves are worn out. Depending on the age and use of your unit you may also have a sticking piston ring.
Aug 23, 2009 | Poulan Garden
Primer bulb on weedeater won't prime
when you prime the bulb it sucks gas from the tank with the small tube, any excess gassed pumped will be fed back to the carb via the big tube leading to the tank. If you prime it and the bulb stays pushed down, then you have a clog or kink. To fix , pull the small tube out of the tank through the fill hole. Pull off the filter on the end and put the tube back in the tank. If it primes, your fuel filter was clogged. If it still wont prime check the hose going to the carb and make sure isnt clogged or kinked.(take of carb and blow in it). If that doesnt fix it take off the bulb from the carb with two screws. The bulb assembly will come off too(rectange metal thing) Take off the two black gaskets, be carefull with them. Take off hoses from carb and bulb asembly. Blow carb cleaner in all holes and over surface. Put back together.
If the carb wont prime and the bulb isnt staying depressed. then you might have a bad bulb or carb gaskets. Make sure hoses are not cracked, cloged, or pinched.
Jun 17, 2009 | Troy Bilt Tb70ss Gas Trimmer
Primer Button
This part is sold as an assembly Part# 530038874
Undo the screws holding the primer and note the fuel line location
as the new one will be identical.
Note the long and short tube connection under the primer bulb itself and the designated tube for each
Jun 04, 2009 | Garden
May 21, 2009 | Husqvarna 28cc Gas Line Trimmer
How do you install primer bulb on husqvarna 125b blower, which line to hook up where
Hello . After you replace the primer bulb , the left tube on the primer bulb goes to the fuel filter inside the tank and the one on the right is just a fuel return that goes inside the tank . Hope this help
May 02, 2009 | Husqvarna Forest & Garden 125bt Backpack...
Garden Logo
256 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
