Question about Kenwood KAC-7252 Car Audio Amplifier
My amp is not showing any power being ran to it and the wires are good and the fuse is good
  • 24 Answers
Dose the amp play hook it up
Posted on Jul 08, 2010
How do you replace the selenoid and 15n amp fuse on a Craftsman Lawn Tractor - 19.5 turbo twin
First see start is good, its on under right dash panel to back of motor. Use a ohm meter, check power to solnoid, show 12v on other side with key being turn to start-12v, If not check the wire or two. If 3 wires reground sol. to frame.
May 25, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My amp doesn't want to turn on, it's doesn't smell burnt, and the fuse is still good... What could it be?
It's the remote wire it is what activates the on off feature ..... You can test this option by running a small wire from your power on the amp ( the red wire) to the remote wire on the amp if it comes on then that wire needs ran or replaced .
Oct 27, 2013 | MTX Audio TN250-1 Class D Mono Amplifier...
I have the dual amp xpa 2500 and i ran all the wires and everything but the indicator light wont turn red nor green what can cause that problem?
Check all the wiring again. If you can use a multimeter, make sure your power wire is getting power at the amp. Also, check to make sure your ground is good. Also, check the remote wire for 0.5 amps when the radio is on. This will make sure it sends the signal to turn the amp on. Also, check all your fuses. Make sure to put the fuse in your power wire. Hope this helps.
Aug 22, 2011 | Car Audio & Video
I wired a 1200 watt amp kit with a 2x 12 inch box set. I have checked the fuses and they are fine. There is no power. What do I need to check next.
if the power wire is ran to the battery an none of the fuses are bad , check ur ground wire make shore its get good ground an if thatdont work take apart the amp an see if the wire are connected to where ur power goes an the fuses
Jun 19, 2011 | xXx XA10002 Car Amp
My coil does not have any power going to it. what supplies the coil its power ive checked all the fueses and they are good. i ran a hot wire and it fired right up.
The coil is powered directly from the ignition(no fuses) on the pink wire. Perhaps you have a security system installed that is interrupting the circuit. It may also be that the wire itself is broken.
Dec 04, 2010 | 1995 GMC Sierra C1500
Kenwood KAC-729S keeps blowing fuses. Checked all cables, re-ran power, remote, and ground. All good, still blows them at power-up.
Hello opey_69a,
Here are the troubleshooting steps for fuses blowing.
1) Remove all wiring except ground, power and remote and see if the amp powers up without blowing the fuses. If it does, the problem is in the input cables or speaker wiring.
2) The use of loudspeaker impedances below the recommended minimums will cause the amp to draw excessive current - check.
3) A shorted or grounded RCA cable may cause the fuses to blow - check.
4) If an amplifier fuse blows continually, with only +12 volt, ground and remote leads connected, the amplifier is probably defective, most likely shorted output MOSFET's. In this case the amp needs professional repair or replacement.
Hope this helps.
Sep 19, 2009 | Kenwood KAC-729S Car Audio Amplifier
Kenwood KAC-7252 Car Audio Amplifier Logo
76 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
