Question about Foxconn (945G7MA-8KS2) Motherboard
Memory upgrade I have a Foxconn 945 7MA series motherboard in a desktop pc system from Evesham Technology, purchased in Oct. 2006. It came with 1Gb of RAM (2x512Mb), described on delivery sheet as 'DDR-2 RAM 533MHz'. I want to add 1Gb of RAM as a single card (leaving me with one spare slot) and would like confirmation that I'm after DDR-2 SDRAM 240 pin DIMM. Also, recommended memory and supplier. Many thanks - Dave M
    President:
  • 2,351 Answers
Hi Dave,
Foxconn 945G7MA-8KS2
Memory (Page 10 in user manual).
This motherboard includes four 240-pin slots with 1.8 V for DDR2. These slots support 256 Mb, 512 Mb and 1 Gb DDR2 technologies for x8 and x16 devices, and support maximum memory bandwidth of 8.5GB/s using DDR2 533 memory,
10.7GB/s using DDR2 667 in Dual-Channel interleaved mode, You must install at least one memory bank to ensure normal operation.
Need you're manual? Click on the link below.
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=945G7MA-8KS2&TypeID=en-us0000001
Foxconn 945G7MA-8KS2 motherboard main page link.
http://www.foxconnchannel.com/Product/Motherboards/detail_overview.aspx?ID=en-us0000024
To upgrade with 1GB. This includes S/H. (Free S/H).
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80098-35
TigerDirect less S/H. (S/H not included).
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1026780&CatId=1647
I did find others for less on the surface. Untill you go to check out & get slammed for shipping (ground), falls between $4.99 to $9.99. I use Corsair myself. Never had a problem.
Have more questions, feel free to ask.
Mike
Posted on Apr 30, 2008
Need help finding part for Evesham desktop that want connect to my tv. i have found my motherboard model which is foxconn-945g7ma, however when i search for it on the internet i find two types Foxconn
You would only be able to connect that to your TV if your TV has a VGA connector, (also called D-Sub.)
There is NO HDMI or DVI connector on any 'flavor' of that model Motherboard.
Mar 29, 2014 | Evesham Computers & Internet
What are the memory specifications for the Foxconn 661MO3C-6L?
The memory specifications are as follows...
System Memory
Two 184-pin DIMM slots
Supports PC 3200/PC 2700/PC 2100 memory
Supports 128/256/512 Mb technology up to 2GB
Mar 17, 2010 | Foxconn 661M03-G-6L P4 Socket 478/SiS...
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
I want to upgrade my Evesham Axis 2600 with new motherboard & processor to speed things up? Any suggestions please?
Selecting your Motherboard is the most critical. CPU is Last except for Dual Core. If you are on a Budget, I have a rule of thumb: $100 for Motherboard, $100 for CPU, $75 for Hard Drive and $75 for Memory. Reccomend: NewEgg.com - Asus MB, Min 2.8mhz CPU, Ram over 4 can be a waste unless you are a power user. RAM wont help speed too much more, and a Seagate HD SATA 3.0 a Gig is plenty. Dont use your old hard drive except for the backup. Always be able to go back to your old system until you are done. Hansel and Gretel Rule !
Dec 31, 2009 | Evesham Computers & Internet
I would like to upgrade memory, but want to assure compatability
Let me make sure, even if your motharboard supports 4 GB memory, A system of 32 bit (most users use 32 bit and among intel processors only intel core2duo/dual core supports 64 bit) wont show more than 3 GB of ram. its an operating system limitation.
But sorry to say, The max limit for your motherboard is 2GB.
Thanks
Apr 04, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Want to upgrade from 512ddram to at leat 1G. How would i know that my new purchase would be compatible with my set. I'm using a pentium d 820 on foxconn 865G7mf-sh motherboard. Tnx.
http://www.foxconnchannel.com/product/Motherboards/detail_spec.aspx?ID=en-us0000166
That page has all the specs.
It says that you can use Dual Channel 400 / 333MHz DDR x2 DIMMs, Max 2GB
That can be bought at bestbuy for under 45 bux!
Kingston Technology Kingston ValueRAM - Memory - 1 GB - DIMM 184-pin - DDR - 333 MHz / PC2700 - 2.5 V KVR333/1GR $44.99
http://bestbuy.upgradebase.com/
Dec 16, 2008 | Computers & Internet
I currently have a Evesham machine which I would like to upgrade the RAM on but unfortunately I cannot find the model number to check for compatible memory. The machine was purchased in Feb 2002 and is...
take the existing memory stick with you to npc world and get them to identify it
- even if you don't purchase from them, you will have your answer!
Nov 18, 2008 | Evesham Computers & Internet
Cannot locate access to memory slots in order to upgrade RAM on Evesham Voyager 64 laptop.
The Voyager would have been even faster with more than the supplied 512MB of memory - you can't upgrade this yourself, but Evesham will supply 1GB as standard for an extra £89.
http://www.evesham.com with the limmitted memory capacity, i would definitely turn off all unused open programs and services you dont need in windows. you may do this and realize you don't need more memory.
Oct 23, 2008 | Evesham Computers & Internet
Can you expand the memory on a Systemax Intel SIS651 System
Your motherboard is actually a Foxconn 651M03.
According to your system you have :
512MB DDR333 PC2700 Non-ECC Memory (512MB x 1)
(One stick of 512MB)
The motherboard manual says this:
System Memory
Two 184-pin DDR DIMM slots
Supports PC1600/PC2100/PC2700 memory
Supports 64Mb/128Mb/256Mb/512Mb technology up to 2GB
(This means you can have a total of up to 2 Gigabytes of RAM)
If you upgrade your RAM, you will need to make sure that you get the correct type.
If you want to keep the RAM you have, you will only be able to have 1.5 GB of RAM because you only have two slots to work with. If you want to upgrade to the full 2 GB, you will need to buy 2, 1 GB sticks.
Jul 17, 2008 | Computers & Internet
Foxconn (945G7MA-8KS2) Motherboard Logo
344 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
