Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
PART THAT SUPPORTS THE ICEMAKER BROKE OFF AND I NEED A REPLACEMENT. I DON'T KNOW WHAT PART TO LOOK FOR. IT IS GE MODEL TFX26PPDACC REFRIGERATOR AND THE NUMBER ON THE ICEMAKER IS 463409G059.
ICEMAKER BROKE AND I NEED A NEW ICE MAKER. I DON'T KNOW WHAT PART TO LOOK FOR. IT IS GE MODEL TFX26PPDACC REFRIGERATOR AND THE NUMBER ON THE ICEMAKER IS 463409G059.
Posted on Feb 19, 2011
Serial # k15004707 model # mf12665xew3 french doors ice maker in upper left corner. After the ice maker fills with water it drips off the front side.
Refrigerator Leaking From Icemaker
If it's leaking from inside the freezer then it's coming from the icemaker or the drain. Lets start with the icemaker. If it's the icemaker there will likely be an ice hanging from the icemaker or just a big block of ice in the ice bin. In any case, it will be obvious.
There are a few reasons this will happen: one is the icemaker will stop turning when it gets to the fill cycle. This will happen when the gears in the icemaker break. On GE icemakers that were made before the year 2000, you can see the gears by taking off the cover on the front of the icemaker. However, if the small gear is broke you can't buy it as far as I know. I have been taking them off of junk icemakers for years. So this part may be hard to find. But if the big gear is broke replace it. Another reason icemakers leak is the fill tube is stopped up and I already discussed this earlier (replace water valve and clean out tube).
Another reason icemakers leak is that the water comes in too fast so it over fills the first cube mold. When this happens you will get a few drops of water when it fills. To fix this you have to take the icemaker out and remove the piece on the side of the icemaker. I don't know the name of it so for this we'll call it cube separator because that's what it does (most of them just snap off others have a screws). Now take silicone (RTV) and put a small amount around the first cube mold only under the cube separator. Now reinstall the cube separator and wipe off excess silicone and it shouldn't leak anymore.
Another reason that icemakers leak is that the refrigerator water valve sticks after the icemaker goes out of the fill cycle. When this happens the valve stays on and the icemaker keeps on turning, in which case, replace the refrigerator water valve.
May 05, 2015 | Maytag Refrigerators
How to fix a kenmore ice maker leaking water
Feb 20, 2015 | Kenmore Refrigerators
Ice maker leaking water
Jul 14, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
How do I get my my GE refrigerator model no. GSS201EPJWW to stop making ice? Bin fills with ice but don't know how to turn off icemaker. Thanks
slide the panel out from in front of the icemaker,there is a slide switch on the icemaker marked on/off
Jan 11, 2013 | Refrigerators
I need the part number to replace ice maker in GE Profile TFX27PF or TFT27PF
The replacement part number is WR30X10093 it is GE's newest electronic icemaker,all newer style icemakers and designed to also work for older models such as yours
GENE
Sep 17, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
We have a ge side by side refrigerator...while moving it we broke something off the back...it was like a little tube or coil...it was really short..maybe 4 inches...i think it led to the icemaker...i dont...
Possibly the water inlet valve? Look at the water line on the back that goes up the back to the ice maker. The bottom end should be connected to the water inlet valve. This is also where the water supply from the house connects.
Oct 02, 2009 | GE Profile PSI23NCR Side by Side...
Replacing icemaker in GE GSH25JSTE side by side refrigerator.
generally its very easy. for your model it looks like the icemaker goes across the rear of the freezer section. if you will look on the left hand wall on the icemaker you will see a philips head screw remove this screw and pull the icemaker towards you and it will come out then unplug the wiring harness (this is probably the hardest part) there are 2 clips that keep the harness connected securley and you sometimes have to use a small blade screw driver to release them. onec icemaker is removed you have to remove the fill cup and the end stop off of the icemaker and reinstall on the new icemaker. one done just reinstall and turn it on. youre done!! BTW the new icemaker mostlikely will not have the green light the old one did so dont think youve got the wrong icemaker.. let me know if you need any further help Thanks Peyton
Mar 16, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Howling noise
I don't see anything located directly behind the icemaker on this model. Try to better isolate the location of noise if you can. If the icemaker is at fault, I wouldn't bother trying to repair. Order another one. One other thing to check is the water flow. When the noise happens again, stick your finger in the ice mold and feel for water. If it just filled, then problem may be in the water valve. Hope this helps,
Oct 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
532 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
