Question about LG LB1000ER Air Conditioner
WE HAVE A LG-( MODEL LWHD1006RY6) THE PROBLEM IS A LOUD BUZZING OR HISSING NOISE THAT DOESN'T LET US SLEEP.IT DOES COOL BUT IT JUST GOT TOO NOISY.WHAT CAN WE DO? IS IT THE COMPRESSOR? DOES IT NEED A LITTLE OIL;WE DO LIVE IN A VERY WINDY PLACE.
  • Tia Coleman
    Tia Coleman Jul 02, 2013
    try this. remove from window or wall. take off outside case. Look to see if the copper coiled piping is raddling when turned on if so. take wither zip ties or bailing wire and wire them together without having the piping touch. This should make it much better. Or it may mean that you need to have it charged. Good luck..
4 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: On the Heat Cycle, the compressor buzzes loudly
Bad start capacitor or run capacitor.
Posted on Dec 27, 2009
  • 70 Answers
SOURCE: Compressor ?
Sounds like you are over heating the compressor, try cleaning the out door unit coil. Take a hose and blow water through it, be carefull not to bend the fins.
Posted on Jul 17, 2010
  • 387 Answers
SOURCE: i have a new lg
sounds as though the contactor is not pulling in tightly. but it also spunds as though the fan or fans might be hitting some thing . check them out shut the unit down and spin the fans and see if you hear something. if not then it could well be a contator .. But as I think a bit more could be lose fan, or compressor is not setting on it isloator bushings .
Posted on Jul 18, 2011
Wine Enthusiast Silent Wine Refrigerator is making a loud buzzing/whirring noise.
Since this unit doesn't use a compressor, the only moving parts are the whisper fans inside of it that circulate the air. One of those fans may be going bad. If you are handy you can remove the back to see if all the fans are working but your best bet is to use the one year warranty and have a qualified techncian figure it out.
Jan 07, 2014 | Refrigerators
Sanyo 25" 10yr old model
is the sound like hissing or like a spark something like?hissing can caused by leaking of high voltage that is dangerous and sould be fix right away
Jul 13, 2011 | Sanyo DS25390 TV
Hissing noise coming from all speakers when 5.1 system is on, does not increase with volume
Is it DANGEROUSLY LOUD hissing, like undecoded digital data?
Maybe you have a DTS source coming in on analog cables or your unnamed HTS can't deal with it or whatever digital bitstream you're feeding it.
Read the manual.
Mar 22, 2011 | LG Audio Players & Recorders
Hissing sound when turned on and goes dark when sound stops.
takes long time for tv to come on, there is a loud buzzing sound and poping noise
Mar 16, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
My freezer stopped freezing and is making a loud buzzing noise with the red light on at the bottom. Cant sleep HELP
the loud buzzing is the freezer high temp alarm. dont know why its warm though.
make sure you don't store anything on top of or on the sides of the unit as the condenser of most freezers are buried in the walls of the unit and it will over heat the compressor. if unit is in a hot garage this will compound the problem.
Jul 02, 2009 | Frigidaire 20.3 cu. ft. Upright Freezer...
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Very loud fan or vibration noise
Listen from the back of the TV and locate the source of the noise. There may be fan with a bad bearing. The noise will lead you to it.
Nov 06, 2007 | Soyo Dymond DYLT037A Television
Loud as Hell
Is it installed in a window? Check to make sure it is installed correctly. usually there is a felt or foam strip that is used to dampen vibration when you place it in the window. It also acts as seal to keep outside air and bugs out. If you place your hand at various locations on the unit does the sound go away? If it does then you know it is a vibration problem. Just add new foam or re-adjust the foam or gasketing it already has. If that doesn't work then try to locate the source of the noise. Use a mechanics stethoscope or even a cardboard tube from paper towels will work. Once you have located the source then you can tell the store what the problem is when you take it back and get a new one. Cheap air conditioners are noisy. Some more than others, it's why they are cheap. But your problem does sound like it could be a product issue.
Sep 25, 2007 | Haier Mechanical Air Conditioner HWF05XC7
LG LB1000ER Air Conditioner Logo
297 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
