Question about Konica Minolta bizhub 180 All-In-One Printer
Error code c0000 in bizhub 210 - Konica Minolta bizhub 180 All-In-One Printer
    President:
  • Konica Minolta Expert
  • 347 Answers
Error code c0000 means imaging unit drive motor is not working or imaging unit get hard so its better to call a service representative.
Posted on Oct 18, 2010
  • Zaheer Ahmed
    Zaheer Ahmed Jun 05, 2012
    Error code 'C0000' = Main Motor M1 malfunction.
    Reset Procedure= Turn OFF and ON the power switch.
    Relevant Electrical components are, Main Motor M1, Printer control board, *PRCB*
    Power supply unit, *PRSU*
    Operations>
    1-Check M1 Motor proper connection and correct as necessary.
    2-Check M1 for correct drive coupling and correct as necessary.
    3-M1 operation check.
    4-Change Printer control board.
    5-Change Power supply unit.
    6-Check developer tank gears.
Solution to bizhub 210 error code c1300
Problem
Polygon Motor malfunction
-Startup failure
- Lock signal fault: Unstable after the first Lock signal has been detected
- Lock signal fault: Lock signal out-of-timing
Solution
1 Turn OFF and ON the Power Switch. 2 Check for proper connection between the PH Unit and Master Board and correct as necessary. 3 Change the PH Unit. 4 Change PWB-A.
Aug 15, 2017 | Konica Minolta Office Equipment & Supplies
My Machine Konica Minolt bizhub 211 telling me Machine trouble service call C0000 what will i do
Main Motor failure check the image unit and or the paper draws or you have a bad motor worse case the main control board
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 05, 2015 | Konica Office Equipment & Supplies
Bizhub 950 error code C0000
This means that there is a problem with the main motor. Recommend turning it off completely, check for any paper jams, and then restart it again. It if continues to fail, time for a technician.
Feb 26, 2015 | Office Equipment & Supplies
My copier is konica minolta bizhub 210 have problem error code M1. please help me solution.
My Friend You must do general service in your photocopier and then you must program your machine.
Sep 29, 2010 | Konica Minolta bizhub 180 All-In-One...
REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA MINOLTA BIZHUB 211.
to remove code "COF32" from your machine, simply change the developer with the new one. code will remove.
wish you best of luck............
Jun 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Konica minolta bizhub 162 have error C0000(main motor malfunction) i try with another motor but same thing! any ideas?!
could be master board (pwb-a) or power supply unit (pu-1) or something that the motor turns is locked up try to you turn the motor by hand whil it is installed in the machine if you cant turn it by hand something is locked up
Nov 30, 2009 | Office Equipment & Supplies
My bizhub 210 is coming up with an error mesage which says ,"CAUTION, MACHINE TROUBLE, SERVICE CALL COF32" Please may you asist me
its the code of ATDC sensor, that means your machine is having low deveolper, kindly change the developer to permanently get rid of this code. thanx
Nov 10, 2009 | Konica Minolta bizhub 180 All-In-One...
C03FF Minolta bizhub 210
C03FF, is the improper or unmatched model setting code. go to "service mode" In service mode please select "ADJUST"
in "ADJUST" please select "Model Setting" in "Model Setting" select the cpm, (Copy speed) of your machine, for example if you have bizhub 210, then select "21" from the list. if you have bizhub 163 then select "16" from the list and press "yes" button. code will remove.
Jan 29, 2009 | Konica Minolta DiALTA Di183F Copier
Konica Minolta bizhub 180 All-In-One Printer Logo
1,863 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
