Question about Welding Tools
What is the configuration of the water cooling lines and pump on a western arctronics 30 KVA spot welder?
  • 10,865 Answers
Hello. Call Western Arctronics directly at 970-482-7271. They will email or mail you the info you seek. J.
Posted on Jul 08, 2010
Why does the welder quit arching after 30 minutes?
Motors and generators are the same in this sense. The winding of a field coil is defective. The winding heats up with use and the winding expands causing it to short out and quits doing it's intended purpose. An hour of cooling allows the winding to contract thus clearing the short circuit. A good motor rewinder person can find the defective winding with an oven or heat gun and can rewind it for a fraction of a new welder generator.
Oct 07, 2014 | Miller Trailblazer 301g Cc/cv, Ac/dc...
Installing tig torch to water cooler
You can directly connect your water cooling argon torch to the tank, but the pump electric wires must be connected in accordance to the switch, when you press the switch you start to weld and the pump is on, release you stop welding and the pump is off, rather an electrician to do the connection for you
Aug 28, 2014 | Miller COOLMATE 3 115V TIG TORCH WATER...
?many battries are using in galaxy 3000 g3k
If the Galaxy 3000 is a 10 or 15 KVA UPS, you need 20 batteries of the 12v 20ah if the UPS has standard backup time.
If it is a 20 or 30 KVA, probably it needs 24 batteries.
Talking about the 20 or 30 KVA UPS, if the battery is 34ah, it uses 24 batteries; in any other case it uses 20 batteries.
Jun 19, 2014 | MGE UPS Galaxy 3000 UPS System
Miller Trailblazer, welds great for about 30 minutes. Then I loose my arc. It will spark but not maintain the arc. I let it cool off for 15 to 30 minutes it will weld for another 15 to 30 minutes.
Sounds pretty normal. These units are not rated to weld continuously. They might only be rated at 5-10% for cheap welders and longer for better ones. They are never designed to run continuously. You need to get into the higher end ($$$) before you get that ability.
You can try to blow cool air into the unit to help it cool. Sometimes this can extend the work time.Basically you can try that or work to your temp cut off limit as you have been or upgrade to a better unit. That is about all you can do.
Apr 04, 2011 | Miller Trailblazer 302 Welder Generator...
Need R&R information to replace for waterpump Geo Storm 1993 4 cyl
Hi!!
Here is the Info you requested:
WATER PUMP REMOVAL & INSTALLATION
Except Twincam Engines See Figures 1 and 2
  • Disconnect the negative battery cable and drain the cooling system.
  • Loosen the power steering pump adjustment bolts and remove the drive belt.
  • Remove the timing belt; refer to the procedure later in this section.
  • Remove the tension pulley and spring.
  • Remove the water pump mounting bolts, water pump and gasket. Clean the mounting surfaces of all remaining gasket material.
  • To install, reverse the removal procedures. Tighten the water pump bolts to 17 ft. lbs. (23 Nm) and the tension pulley to 30 ft. lbs. (40 Nm).
  • Connect the negative battery cable and fill the cooling system, then start the engine and check for leaks.
Twincam Engines See Figure 3
1.6L DOHC ENGINE
  • Support the engine using a suitable floor jack and remove the right front engine mount.
  • Remove the engine mount bridge and the upper timing belt cover.
  • Remove the power steering belt and the lower timing belt cover.
  • Loosen the timing belt tension pulley and remove the timing belt.
  • Remove the power steering pump and bracket.
  • Remove the water pump attaching bolts, then the water pump from the vehicle. Thoroughly clean all remaining gasket material from the mating surfaces.
  • Reverse procedure to install and tighten the water pump bolts to 17 ft. lbs. (24 Nm). Connect the negative battery cable and refill the cooling system. Start the engine and check for leaks.
1.8L ENGINE
  • Disconnect the negative battery cable and drain the engine cooling system.
  • Remove the timing belt covers; refer to the procedure later in this section. Loosen the timing belt tensioner pulley bolt, then remove the belt from the water pump pulley.
  • Remove the 2 bolts from the power steering pump bracket, then position the pump aside with the lines still attached. Be careful not to kink or damage the steering fluid lines.
  • Remove the water pump mounting bolts, then remove the pump from the engine. Thoroughly clean the gasket mating surfaces of all remaining gasket material.
To install:
  • Install the water pump using a new gasket, then tighten the retaining bolts to 18 ft. lbs. (24 Nm).
  • Position the power steering pump assembly, then install the retaining bolts and tighten to 25 ft. lbs. (34 Nm).
  • Install the timing belt to the pump pulley, then tighten the tensioner pulley bolt to 30 ft. lbs. (40 Nm).
  • Install the timing belt covers.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Mar 11, 2011 | Geo Storm Cars & Trucks
MY 1999 suburban has water dripping from the engine. I can't find where.
check your hoses for small holes and cracks. especially close to the hose clamps if not then check your water pump and radiator. sometimes the water will drip from a hose and travel down wires landing in a different spot on the ground. or the easy way out can be to take it to a mechanic and have them pressure test your cooling system. itll take about 30 mins and be about 40$
Sep 16, 2010 | 1999 Chevrolet Suburban
New fuel pump but won't pump fuel
start from the geginning. fuel tank- trash water etc. fuel line, valve open line not plugged, caberator clean and float not stuck closed. use air to blow lines out. good luck
Sep 02, 2010 | Bobcat Miller 225 Welder Generator 907209...
My miller matic 35 welds and stops after about 2 inches let cool for about 30 to 40 sec and it welds again. fan runs
these need a good power supply , i looked and did not see the duty cycle on this welder if you are doing heavy welding 100% power it will need 30- 40 minutes to cool of to weld again. it all depends on the units duty cycle, stated on the welder spec plate ..can you bypass the auto feed speed mode ? this might be the issue.. good luck ..use all the protection you can when welding these are like the sun and can and will burn exposed skin and eyes .. if'n i was any help throw me a bone and vote thanks jay
Jul 28, 2010 | Miller MATIC 140 MIG WELDING PKG w/cart...
Welding Tools Logo
60 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
