Question about Apex Digital HT-150 System
Apex dt250 digital convertor-- light stays red and will not turn green and display shows--- is there a reset procedure
  • 11 Answers
If you're electronics savy, as in replacing capacitors, open it up.. that's your problem.. one or two of the caps on the power board has gone bad.. most likely a 470uf 25v, which can be replaced with a 470uf 35v found at Radio shack for about $1.29. You can tell if it's bad if the top is cracked open & leaking or just domed out instead of being flat.
Posted on Aug 10, 2010
  • denguy Sep 16, 2011
    Thank you so much, Szieve! I have two Apex DTCs, both of which had stopped working a couple of months ago. After reading your post, I popped the top of one of them, took a close look, and lo and behold one of the capacitors had a beautifully domed top (versus flat like the rest). I open up the other Apex DTC, and sure enough, yet another blown capacitor. A quick trip to Radio Shack...salesman points me in the right direction...grab a couple 470uf 35v capacitors ($1.49 each)...dig out my old rusty soldering kit...and before I know it, two previously bricked DTCs are as good as new, maybe even better! The hardest part in the whole process was finding my old soldering kit! Thanks, not only for the solution to my problem, but for a new-found confidence! Can't wait for my next project!!
Toshiba 24SLV411U no display
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Sep 03, 2016 | Toshiba Televison & Video
PF2020 RESET CHILD LOCK
Turn your television and Apex DT250 receiver on.
Push the "Menu" button on the Apex DT250 remote control.
Press the remote's "Up" and "Down" buttons to scroll through the menu options. Stop when "Parental Controls" is highlighted. Press the "Right" button to select this option.
Enter your four-digit password. If you have not set your password, use the default code of "0000."
Use the "Up" and "Down" arrows to change or set the parental control movie ratings. You can select from "None," "G," "PG," "PG-13," "R," "NC-17" and "X." Once your setting is highlighted, press the "Right" button to go to the next screen.
Use the "Up" and "Down" arrows to change or set the parental control TV ratings. You can select from "None," "TV-Y," "TV-Y7," "TV-G," "TV-PG," "TV-14" and "TV-MA." Once your desired setting is highlighted, press the "OK" button to save your settings. Once the settings are saved, you will be taken back to the main menu. Press the "Exit" key to exit the main menu.
Oct 31, 2012 | Apex Digital PF2020 20" TV
The red light stay on it will not show green
corrupt board maybe affected.. mainly its memory.. need to replace new board for that...some causes if you dont turn it of properly or either low voltage area
Nov 12, 2010 | Apex Digital HT-150 System
I have an Apex Digital TV Converter box # DT250A. Today, all of a sudden my TV screen went greenish and then the picture on my TV went out ( static looking screen ). The light that's on my Converter Box...
The DT250 likely has one or more bad 470uf 25v capacitors. You should replace all four. Look at some of these youtube videos for how do do the replacement.
http://www.youtube.com/watch?v=on_2CP52cW4
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1
Order 4 new 470uf 25v capacitors from digikey.com P/N P10274-ND
Use first class mail as your shipping method. Will be under 10 dollars total.
Jul 05, 2010 | Apex Digital Televison & Video
Apex DT250 wont turn from standby (red light) to On (green light)
The DT250 has one or more bad 470uf 25v capacitors. You should replace all four. Look at some of these youtube videos for how do do the replacement.
Sep 24, 2009 | Apex Digital HT-150 System
I have a apex DT250 and all of a sudden my tv screen is blank,apex does turn off and on,menu screen doesn't even come on..
Sep 10, 2009 | Apex Digital (AL-A300ATX) 300-Watt Power...
Apex Digital HT-150 System Logo
704 people viewed this question
Top Apex Digital Audio Players & Recorders Experts
Robert Rankin
Steve
Are you an Apex Digital Audio Player and Recorder Expert? Answer questions, earn points and help others
