Question about Olevia LT27HVX 27 in. LCD Television
My remote will not work. i tried replaceing the batteries, but it still will not work!
  • 11,361 Answers
The problem can be the IR receiver in the TV or the logic board.
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 07, 2010
  • pjenkins329 Jul 07, 2010
    okay.
    i have managed to turn the tv on and off with the Satilite remote control. i can increase the volume but my biggest problem is that with the Satilite remote i can not access the closed caption. when the tv remote first stopped working the close caption was on, but now it is off and i can not figure out how to get it back on. would buying a new tv remote work? and where can i buy it in raleigh nc?
  • Bud Martin
    Bud Martin Jul 07, 2010
    OK, the IR receiver in the TV is OK since you can use other remote to control it.
    http://www.newremotecontrol.com/Mfrs/Oth...
    You should contact them to get the exact one you need.
I CAN NOT GET THE REPLACEMENT REMOTE TO WORK FOR THIS UNIT
Try removing and reinstalling the batteries. Be sure there is no glass cabinet door between the remote and the Akai device. Try aiming the remote at an angle instead of straight on. Try installing new batteries
Feb 15, 2013 | Akai New Original LCT3201TD Remote Control
REMOTE DOES NOT WORK I HAVE CHANGED BATTERIES
If you have been change the battery but remote still not work, please dissemble your remote check battery lead/wires for defective and other part on pbc. If nothing wrong there, the problem is usually the IR bulb on remote. Try replace with same model or just replace your remote with new one.
Regards
Regards
Mar 26, 2011 | Televison & Video
Remote stopped working all together. Replaced the remote and it still doesn't work. Tried replaceing the batteries as well. Light on remote flashes but that's about it. It is a Sharp Aquos HDTV not sure of...
If the TV still works fine and it's just the remote malfunctioning, try removing the batteries from the original remote and leave them out for 10-15 minutes. Put the batteries back in and try the remote.
Mar 14, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My garage opener remote on my 2003 santa fe just stopped working. How can I fix it?
There is a battery in the remote.If the battery gets old the remote will stop working.Replace the battery and check.Also if your battery is new but still the problem is there then,try to open the garage door by keeping less distance between remote as well as the garage door.Also there is a sensor in the garage door.If that sensor is not functioning then this can be one issue.In some cases the internal remote circuit gets short,in that case the remote needs replacement.But does the garage door sensor light shows any sign of getting connection from remote when you press the remote button.Open the door and try to close the door with remote and check.As per the problem,in most cases its weak battery related problem,and replacing the battery solves the problem.You can try all the possibilities and see which one helps.Thanks.Helpmech.
Nov 12, 2010 | 2003 Hyundai Santa Fe
Ford F150 remote key does not work after car battery
cbridges2232,
Any luck with your keyless remote issue? I'm having the exact same problem with my Ford F150 CrewCab after car battery replacement.
Oct 07, 2009 | 2001 Ford F150 Styleside SuperCrew
Remote not working and I need to press menu or ok on screen
1. change batteries
2. clean the lens on the reciever end
3. clean battery post with 70 percent achl
If that does not work try and get a universal remote meanwhile here is a site for a duplicate replacment remote www.remotes.com.
Thanks
Sep 17, 2009 | Televison & Video
My remote stopped working. Replaced batteries so
1) Reset the remote. To do this, remove the batteries and hold down one of the number buttons for about 5 seconds to drain the capacitors. Replace the batteries, reprogram the remote to your TV and see if it works.
2) If it doesn't, try a second set of replacement batteries just in case.
3) If none of the DirectTV codes work, you have 3 options.
1) Contact Directv and see if they have additional codes not listed in the manual.
2) Contact your televisions manufacturer and see if they have additional codes to try.
3) Purchase a 3rd party remote that works with both devices..
Jun 03, 2009 | LG 32LB9D TV
Wii remote has no power
try replacing the battery's, if that doesn't work try resyncing the remote, still dont work you will have to replace, try also to power/unplug the unit.
Nov 23, 2008 | Nintendo Wii Console
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Olevia LT27HVX 27 in. LCD Television Logo
148 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
