Question about Maytag MDG3600BW Gas Dryer
Gas dryer dosn't heat properly
I have a Maytag Neptune 2000 gas dryer model MDG4000BWW. The igniter gets hot an the gas burner turns on for a little bit and then the gas flame drops out. After a little time the gas turns on again then cuts out. The air in the dryer gets warm but not hot so the clothes take an extra long time to dry. The lint screen and passages are clean. Is there a temp switch that is not working properly?
    President:
  • 1,430 Answers
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Posted on Jul 07, 2010
Describe your Neptune MDG9700A Gas Dryer Problem igniter clicks a couple of times then stops, burner does not light. had code of 02
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Maytag Neptune MDG9700A Gas Dryer
Maytag mdg6700aww dryer clicks to start the igniter. Sometimes the burner ignites, other it doesn't and I can smell raw natural gas from the vent. Not drying. Help
heatman101
Aug 14, 2011 | Maytag Neptune MDG6700A Gas Dryer
Hello . i have no heat in my maytag neptune model md5500 dryer how can i fix it the gas is ok. Z.z.
check your burner make sure it is clean, if it is dirty either blow it out or vacuum it out. If it still don't ignite it may be the thermo copuler. Hope this helped Tim
Sep 03, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a Neptune MD5500 natural gas dryer. At startup, the igniter glows and the the burner begins but the flame quits after about 1 to 2 minutes. If it is shut down and restarted, it seems to act the...
alex
I have a MDG6700 with the same issue..all my research on this problem points to the 2 coils on the gas valve. Tomorrow i am going to change them (kit is about 30 bucks to get local)..coils test good but other postings about this dryer say one coil gets hot and is weak and close the gas valve thus stopping the heating process..
Aug 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
MaytaG MODEL # MDG4000BWW. Rumbles and sweels as
check the rollers,the pulley and if it shakes as bad as it sounds the blower wheel is probably damaged
Jul 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer does not heat.....gas is on, can hear igniter clicking. Burner is not getting any gas. Perhapes problem with gas valve igniter??
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a maytag dryer, model # MDG4000BWW. It has...
check the high limit/cycling switch thermostat located on the heat housing ,you will need to remove the front panel to access this,then, bypass the high-limit with a jumper wire and see if the flame stays on longer,if this doesn't help, then check the radiant senser on the tube also they get dirty,you can clean the senser eye or bypass this also and see if its weak,if not then replace the 2 gas coil valves on the gas valve body as these will get weak and shut off the gas supply
May 20, 2010 | Dryers
Maytag MDG4000BWW gas dryer does not heat up
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch. The links below are listed in order of failure commonality.
1.Gas Valve Coils
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3479&PartID=3479
2. Ignitor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di3018&PartID=3018
3.Thermal Fuse
http://www.repairclinic.com/SSPartDetail.aspx?s=t-MDG4000BWW-%3d%3di516650&PartID=516650
These are only the most common parts that tend to fail. There are numerous other components that could cause the same symptoms. If the above assistance does not resolve your issue, you may request assistance with an on-line technician, or you can order a service manual from www.repairclinic.com
Aug 30, 2009 | Maytag MDG3600BW Gas Dryer
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Maytag MDG3600BW Gas Dryer Logo
299 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
