Question about Lucent PARTNER18 Corded Phone
Can you program a 18D phone to bring back up an incoming call number? Does that have to be programmed per each phone or from extension 10 for all phones?
  • Lucent Master
  • 2,460 Answers
Yes :-)
It has to be programmed from extension 10 and from the phone. One sets the destination and the other sets the button. Technically, you can do everything from the main phone, but it's easier to do the system programming from the main and the extension programming from the extension, that way you can see the button you're assigning to the feature.
Check out the quick guide here. http://public.carl.airpost.net/Avaya/Partner%20ACS%20quick.pdf
Page 38 gives you the #31x commands to set up CID, and page 110 gives you the featrure codes you need to assign to the extenson buttons.
Carl
Posted on Jul 08, 2010
Caller id partner
To program a Caller ID Name Display button using remote administration on Partner ACS Release 3 or later systems:
  1. In the Partner ACS R3 System window, select Extensions. The Extensions window appears.
  2. Select the extension you want to program. The Individual Extension Parameters window appears for the selected extension.
  3. Select the Button Programming button. The Button Programming window appears for the selected extension.
  4. Optional - For new systems where no download is available: From the Phone Model box, select the arrow and choose Partner-34D, Partner-18D, Partner-18 Non-display, Partner/MLS-6 Non-display, MLC-6 Cordless, MLS-12 Non-display, MLS-12D, MLS-18D, or MLS-34D for this extension. The button layout for the type of phone you selected appears.
  5. Select the button you want to program. The Partner Set Button Programming Information dialog box appears.
  6. Select the Caller ID Name Display button.
  7. When you are finished, select the OK button.
  8. Repeat steps 5 to 7 to program other buttons for this extension.
May 22, 2014 | Avaya Eurostyle 18D Corded Phone
When in night mode, how do I make the samsung idcs 18d ring on every extension
if you know your password for your phone system do this. enter programming mode by pressing transfer key, type 800 enter your password then volume up key then speaker key. go to program 601 station groups find unused station group ie 510. make this group unconditional and under members add all thr extensions you want to ring then press speaker key. then go to program 406. enter line number of line and under night mode tell it the station group number you programmed above
May 07, 2014 | Samsung Falcon iDCS 18D Display Phone with...
Does this system have ability to block phone numbers?
Outbound yes, incoming no. In program 404, there are 8 lists of 10 numbers that let you set up restrictions and assign them to extensions.
I block my incoming calls by using my VoIP provider's call block feature.
Carl
Feb 07, 2011 | Lucent 18D Corded Phone
Hello.. We have the parter-18D phone system. one of the phone rings when there is an incoming call, but it shouldn't, since this is not the main phone Ext 10. How can I program this phone to ring only...
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
May 06, 2010 | Lucent PARTNER18 Corded Phone
Privacy
Unfortunately you cannot toggle this feature.
On extension 10 or 11
Feature 00
Left Intercom, Left Intercom, Right Intercom
Enter extension number that you don't want to ring
hit the line key until display shows No ring
To do next extension : Right Intercom and enter next extension number.
Follow same procedure for all extensions.
Feature 00 to exit programming
Let us know if you need additional assistance.
Cheers
Jul 16, 2009 | Avaya Eurostyle 18D Corded Phone
I cant forward calls on a partner 18D phone
Chad first think is you need to enable your extension in comand #322 This is done on ext. 10 or 11 Press Feature 00 Left Intercom, Left Intercom #322 Enter your extension number Press 1 to assign Feature 00 Next you will need to program your mobile number in speed dial On extension 10 or 11 Press Feature 00 Feature 85 Input your mobile phone number Next is to program a button on your phone Go to your phone Press Feature 00 Select a button to program (Press it) Press Feature 11 dial 85 Done Button works like a toggle switch on and off
Jun 10, 2009 | AT&T Partner 18 Phone (315805B)
Programing Ayava partner - 18d Phone
This will need to be done at Extension 10 or 11.
Press Feature 00
Press LEFT intercom, LEFT intercom
Press right intercom. Display will ask for an extension number.
Enter the extension number you want to modify.
Now it should say "program ExtXX"
Press * * (STAR STAR)
then touch the lines in the order you want to pick them up, when finished entering the order....
PRESS * * (STAR STAR)
Then Press Feature 00 to exit programming.
Apr 30, 2009 | Avaya Corded Phone avaparp18d
Avaya 18D Change Number of Rings
Programming is done on extension 10 or 11
Press feature 00
Left intercom, Left intercom
#506
mode 1
line 01
number of rings 4
do the same for all lines
Cheers
Apr 13, 2009 | Avaya Corded Phone avaparp18d
Avaya 18D unable to make outgoing calls
Sounds like you changed your line selection. Changing line selection on a Partner system is done on either ext 10 or 11.
enter **
press the lit line in the order you want the to be used, i.e. line 2 then line 3 then line 4 etc.
enter ** when finished with line selection
Hope that helps
Mar 20, 2009 | Avaya Partner 18D Display Phone (315807BA)
Incoming calls to office cause all phones to ring in classrooms
Hope that helps
Dec 02, 2008 | Lucent PARTNER18 Corded Phone
Lucent PARTNER18 Corded Phone Logo
140 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
tfelton3
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
