Question about Cameras
Once the power on it says fomat set ok then if press ok button display says check sd/mmc card thats all
  • kakima Jul 07, 2010
    What make and model camera? What type of memory card?
    Is it possible the camera was designed to work with SD cards but you're trying to use an SDHC card?
    We want to help you, but you have to provide some details so we can do so.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
Having gone over a month with no response, I assume this is no longer a problem.
Posted on Sep 02, 2010
How do i format the memory card on the kodak easy shareDX7590. I just bought and inserted a knew kodak 8 gm memory card and it says it need to be formated and i do not know how and have pushed all the...
To format a memory card, press the MENU button, use cursor-up/down to select Settings, press the OK button, use cursor-up/down to select "Format," and press OK.
The DX7590 works with MMC and SD cards. It does not work with SDHC cards. If you mean an 8GB card, then that's an SDHC card and will not work with the DX7590. The camera is limited to cards 2GB and smaller.
Sep 24, 2011 | Kodak EasyShare One Digital Camera
Can i download pictures from my aspire 6920g to a sd memory card
1. open Windows Explorer
2. push the sd card into the sd card reader with its contact side down until it is flush
3. sd card is detected and displayed as a drive called SD/MMC (N:) where N is its drive letter
4. clicking on the SD/MMC drive will list any folders that are in it
5. with SD/MMC high-lighted, click on File and on the drop-down list, hover cursor over New
6. on the New list that opens, click on Folder to create a new folder on the SD/MMC drive
7. right click on the new folder and from the drop-down list click on Rename
8. rename the folder appropriate to the photos you want to download to the SD/MMC drive
9. navigate to the photos and high-light using shift+click for a block or ctrl+click for individual
10. with cursor over high-lighting, hold down right click and drag to new folder and release
11. select from the pop-up list that appears on release to either Copy Here or Move Here
12. repeat from 9 for more photo downloading and when done do an eject before removing ....
13. for Windows XP, click on the Safely Remove Hardware icon at the right side of the Taskbar
14. for Windows 7, can do same as XP or just right click SD/MMC and select eject from the list
15. **WARNING** failing to do an eject or Safely Remove Hardware can result in corruption!!!
16. once message appears that media can be safely removed, push the card in until it clicks
17. once click is heard, stop pushing and it will pop out sufficiently to be grabbed & pulled out
Apr 30, 2011 | Acer Aspire 6920 Notebook PC
Htc smart phone securitykeyguard code forget?
1. Power off unit
2. Remove MMC/SD Card or Dummy card.
3. Press Record Button while pressing Power button to switch on.
4. On the white screen, press the action button of the Joystick.
5. Choose Erase IPSM.
And, if there is an SD card in the unit, more options appear other than just erase IPSM...
Feb 16, 2011 | HTC Cell Phones
My camara c875 will not format new card.When i go to fomat the camara will not respond
According to the manual, your camera can accept SD or MMC cards up to 1GB. Is the card you're trying to use bigger than that?
Sep 30, 2010 | Kodak EasyShare C875 Digital Camera
The memory card cannot format rejects reformating
You card might be faulty or not supported by this model.
The memory card support for V610 is SD/MMC up to 2 Gigabyte
Format your SD card. NOTE this will delete all existing data on your SD card.
Do the following:
  1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
  2. Turn on the camera.
  3. Press the Menu button, then go to the Setup Menu.
  4. Scroll up or down to the Format option, then press the OK button
Jan 25, 2010 | Kodak EasyShare V610 Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    How do i transfer pic from the internal memory to the memory card
    www.kodak.com/global/en/service
    FOR MANUAL DOW[section title] Choosing Internal Memory or SD/MMCCard
    The camera offers two options for storing pictures and videos:
    Internal Memory —Store pictures and videos in 16 MB internal
    memory.
    SD/MMC Card —Store pictures and videos on a card. The number/length
    of pictures/videos depends on the size of the card. Purchase accessories at
    a
    dealer of Kodak products or visit www.kodak.com/go/dx6490accessories. For
    storage capacities, see page 114.
    Managing Your Storage Location Setting (after inserting the card with power
    OFF)
    1 Turn on the camera.
    2 In any still or video mode, press the Menu button.
    3 Press to highlight Image Storage , then press the OK button.
    4 Press to highlight an option, then press the OK button:
    Auto (default)—the camera uses the card
    if one is in the camera. If not, the camera
    uses internal memory.
    Internal Memory—the camera always
    uses internal memory, even if a card is
    installed.
    5 Highlight Continue, then press the OK button again.
    The setting remains until you change it and applies to all camera
    functions.
    6 Press the Menu button to exit the menu.
    NLOAD.
    Jul 09, 2009 | Kodak EasyShare C643 Digital Camera
    Error 608
    You must reinstall the software from your device. switch it off from the power button and then back on with the joystick pressed down.You will have a blue screen. Put inside one sd-card formatted in fat16 file system with the rom named as winceimg.bin ( you will find it on google).Choose winceimg by sd/mmc card by pressing joystick center. Wait untill on the display will write "restart your device". This will solve your problems
    Mar 06, 2008 | Mitac Mio 168RS GPS Receiver
    SD/MMC Compatibility?
    I'm not sure that this will be a once a for all answer, but the link below says that any device with an sd slot can handle mmc but devices with slots designed exclusively for MMC cannot handle SD. Since the axim has an SD slot, I would say that it is compatible with MMC although I haven't tried an MMC card and the manual doesn't specific mention MMC memory.
    Sep 13, 2005 | Dell Axim X5 Pocket PC
    Cards not working with camera
    If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
    Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
    Cameras Logo
    21 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
