Question about Dell Dimension 4700 PC Desktop
Computer Does Not turn On
Hello, my computer is no longer starting up. When I go to turn power on, it beeps 4 or 5 times, the green light on motherboard comes on but that is it...the screen is black and when I push one of the buttons it says it's in Power Save Mode and to move mouse or press button on keyboard but my keyboard is not responding either...someone please help!!!
  • 3 Answers
Three things to look at. . .
1) CPU Heat Sink is full of 'House hold Dust - Clean it off !
2) If youre one to leave ur PC running 24/7 - 365 days a year -
The slightest bang, drop, jolt (See in you Theasaurus Bud) will shear the contact between the Proccessoe surface and the Heat Sink - Giving you zero Heat transfer - New Heat sink Grease !
3) Bung your Ram Module into the trash or the nieghbours roof, replace it ( it's the cost of a tube of toothpaste nowdays ) and if it still does work after allll that - Get your .357 Mag. out - Great target - seriously !!
Posted on May 06, 2008
    President:
  • 2,712 Answers
Its most likely a problem with the RAM. You may need to replace the modules..
Posted on Apr 18, 2008
Lenovo desktop 3282 beeps twice then 5 times and goes no further
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery
5. Remove the real-time clock (RTC) battery
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Aug 01, 2012 | Lenovo Computers & Internet
The computer repeats 4 short beeps constantly when turned on ... power supply light is green and also motherboard light is green
Hello, depends on which make of bios you have. If you're lucky it's a keyboard error, but take a look at this page of bios beep codes.http://www.5starsupport.com/info/beep_codes.htm
regards,nicam49
May 11, 2012 | HP Compaq dc5100 PC Desktop
My daughters Dell is only 4 weeks old, you push the power button and the light on the button illuminates for about 10 seconds, nothing appears on the screen and then it shuts off. Have true about 15 times...
Hello sean_gillett,
Remove power completely from the device. If it is a laptop, remove the battery. Wait about 30 seconds for the power to drain, then reapply the power source.
If it's a laptop, you may need to let it charge 15 or 20 minutes. A desktop should power up just fine. If it does not, contact Dell immediately for warranty repair!
If this helped you, please give me 4 thumbs up!!
Jul 06, 2011 | Computers & Internet
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Hello, When I power ON the desktop, It flashes a green light then after 1 second will start beeping with a red light. it beeps four times then pauses then beeps again for about twenty...
This issue might happen due to RAM.
To resolve this issue:
Turn of the power supply for your desktop.
Please remove the side case on your tower(CPU).
find the RAM slot and remove the RAM from the Slot.
Clean the RAM terminals with the help of cloth or Eraser.
After cleaning place the RAM on RAM slot.
Now try to turn ON the PC desktop. If it is working thats fine or else you need to replace another RAM to check.
Please refer the below figure to find the RAM Slot and the lock to remove the RAM.
Jan 21, 2011 | HP Compaq dc7700 PC Desktop
My computer is not starting, no beeps, no lights except that the fans are working? the last time i used my computer it was working perfectly. after almost one year, when i switch my computer on, i noticed...
One of the most common failures is Power Supply. Try first, unplugging and leaving off for a few minutes before trying to start it again. Sometimes this helps, but I expect you will need to dig deeper.
Oct 20, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Dead thinkpad by ibm
The CMOS battery supplies energy to the Real Time Clock when the computer is not connected to the electrical socket, and does not have the battery inserted. It should not prevent the computer from starting up. You will however be asked to reset the time and date of the computer.
Hope it helps.
Oct 03, 2009 | IBM ThinkPad R50e Notebook
Computer will not come on
beeping 4 times in a row is a hardware problem
repalc motherboard if video is intergrated
Mar 26, 2009 | IBM ThinkPad T30 2366 Notebook
Hp xw6200, 6 beeps, and red power button...failed start up.
6 long beeps indicates that there is a problem with the memory, take them out, clean the contacts and the DIMM slots and reseat them.
Hopefully this will resolve the problem, if not new memory may be required
kind regards
Dec 12, 2008 | HP xw6200 PC Desktop
Dell Dimension 4700 PC Desktop Logo
132 people viewed this question
Alun Cox
