Question about GE AHK40LK Dehumidifier
GE Dehumidifier Model #AHM30LKG1 making noise and hot air
We have a GE Dehumidifier Model #AHM30LKG1 that has recently started making a vibrating sort of noise, where you can hit/tap the unit and it will stop making it for awhile, then come back on. It has also been putting out hot air and making the area we use it in extremely warm, which it has never done til recently. We took the back off and blew it out with air and the back of the blue fan, the bolt was really hot. Need to know what is wrong or if we just need to get a new one.
  • ia_pug_lover Jul 07, 2010
    It is collecting water...we connected a tube so it can drain automatically
5 Suggested Answers
  • 52 Answers
SOURCE: Humidifier Fan Doesn't Stop
RH at 70 % seems to me a little excessive you really should be working somewhere around 50 to 56% the fan has to move Air through the system.
I would like to know your room Air temp what is the Air temp comming off the system. what are your parameters.
Posted on Jun 09, 2009
SOURCE: I have an old Sahara 25 dehumidifier need water collector chamber
I contacted GE on the web and found out they don't make the parts anymore for this unit. I used Gorilla glue to repair the cracks in the old semi soft plastic water collector chamber.
dmbrownpe
Posted on Jan 30, 2010
heatman101
  • 43501 Answers
SOURCE: 0GE Dehumidifier AHM65LKM1 not taking moisture out of the air
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 25, 2010
  • 4736 Answers
SOURCE: My GE basement dehumidifier is overheating. The
Yes, the first suggestion is I hope your dad can get it back together without any parts left over (LOL). Over heating is generally caused by an clogged or dirty air intake filter. Simply removing it and vacuuming it or if it's really dirty, washing it in warm water and mild dish washing liquid will clean it. Rinse it thoroughly, shake off excess water and allow to dry completely. Never operate the unit without the filter in place. Doing so, can damage the unit.
Getting back to the heat for a moment and where you're using your dehumidifier. Dehumidifiers do generate heat, it's not abnormal. Operating it in a basement can cause it to over heat. This happens because the air temperature at floor level is colder than at shoulder level. Dehumidifiers struggle in temperatures below 65 degrees F (unless you have a Low temp unit, designed for basement applications). Raising the unit up off the floor, on to a sturdy table, counter top, etc, that an handle the weight of the unit, plus a full bucket of water, will generally resolve the problem.
Actually, a basement application , higher is better.
I hope this helped you and thanks for choosing FixYa.
Posted on Aug 16, 2011
Dehumidifier started making a loud noise. Is this something we can fix?
a change in tone of the noise from a working unit indicates to me that a bit of dust/dirt has built up on the internal fans blades and has caused a imbalance in the fan now , this usually requires a complete disassembly and cleaning out to remedy
Jul 27, 2015 | Midea Westpointe 50 Pint Dehumidifier
Vibration Noise Fix
Place the dehumidifier feet on foam or rubber vibration absorbing pads.
Touch all sides of the cabinet with the compressor running to see if your touch will dampen the noise. Once the noisy area is identified check that the fasteners are all in place and tight. Sometimes loostening and retightening a number of fasterners around the noisy area will cure this problem.
Apr 30, 2014 | Honeywell DR90A1000 TrueDRY Dehumidifier...
I have an Aprilaire 1750 installed inline with my upstairs central air system in the attic. The unit's ducting appears to be installed as indicated in the installation manual, but when the unit is running...
Your dehumidifier is likely working correctly. When operating and removing moisture, a dehumidifier will supply warm/hot air to your house. Your dehumidifier moves less air than your A/C, so your supply ductwork in your house is oversized for the dehumidifier. This will lead to uneven feeding of your supply duct branches with just the dehumidifier operating.
Since your dehumidifier is installed in the attic, make sure that the ducting connected to it is well insulated. Also make sure that your dehumidifier cabinet is insulated. These actions will help prevent heat gain from the hot air in your attic.
Is your dehumidifier bringing in fresh air from outside? If the outside air is hot and humid, the dehumidifier will supply warmer air to your home.
Some people run their A/C fans continuously to help with the air distribution, but this is a bad idea since it increases energy usage considerably.
DryDog
Aug 06, 2010 | Aprilaire 1700 Dehumidifier
Whirlpool dehumidifier makes a lot of noise when running and vibrating, dehumidifier is only 4 years old it does take out the water but very noisey any way to quiet it down?
When the compressors start to go bad they often start to get very loud also...the cost to replace the compressor will probably be more then a new unit...
Also check out this tip about dehumidifier problems...
May 02, 2010 | Whirlpool AD50USS Dehumidifier
I HAVE 4 EA NEW LHD659EBK DEHUMIDIFIER and they make lots of noise and vibrate a bit, this is normal in these Dehumidifiers ..
These can be noisy.
Does the noise only happen when the compressor runs? These compressors float on rubber bushings to isolate the vibrations and maybe one of the three nuts on the mounting studs may be loose.
The fan bearings can also wear out.
Nov 21, 2009 | LG LHD45EL Dehumidifier
My fedder dehumidifier m7dh45b2a makes an annoying noise
This noise is the vibration from the compressor...sometimes things can come loose and magnify the noise...check for loose parts and tighten as needed...
The compressor may also be going bad...
heatman101
Oct 06, 2009 | Maytag M7DH45B2A Dehumidifier
Dehumidifier making room very hot
Humidity, [Swetting] until the Room is totally dried out.Remember you are also drawing off infloor and underfloor dampness too.
Regards,DT
Aug 30, 2009 | Goldstar DH504EL Dehumidifier
The dehumidifier is blow cold air
Is it collecting water? The air coming out the back top half should be cool/warm. It will be a little warmer at the bottom near the compressor.
Apr 07, 2009 | Kenmore 54701 Dehumidifier
Noise vibrations in dehumidifer
sounds like a sealed system issue it has a 5 yr. warrenty on the sealed system, cost to repair might mean an new one instead
May 03, 2008 | Dehumidifiers
Dehumidifier keeps shutting itself off.
For some reason it is overheating and shutting itself off. There is a law that all electronics are supposed to have a point to where it automatically shuts off if it gets too hot from a malfunction or loose connection in the circuit board. It is to protect the consumer. You either need to take it to a tech or get rid of it. Get a new one.
Sep 13, 2006 | GE AHG40LA Dehumidifier
GE AHK40LK Dehumidifier Logo
189 people viewed this question
Top GE Dehumidifiers Experts
Gene Tuck
 steve
steve
AZBen
AZBen
Are you a GE Dehumidifier Expert? Answer questions, earn points and help others
