Please help the touch screen on my copier/ scanner quit working all of the other functions work great. The touch screen simply doesnt respond.
  • 4,281 Answers
For that you need to RESET all settings to factory defaults.
Press menu button and enter in touchscreen settings then enable it or disable and then reenable it then restart printer then check.
If it will still not work then RESET all settings to factory defaults with menu button and then restart.
If it will still not work then you need to repair touchscreen or replace it.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jul 07, 2010
How to change paper size Toshiba studio 232
The books are great for this but it will be in your user functions. another way is to touch the screen where the cass't is and it should flash, not all do this but all are controlled through your user function mode right there on your touch screen.
Sep 03, 2014 | Toshiba E-studio 232 Multifunction Copier
Pfaff creative 7570 touch screen doesnt work
it's possible that the computer has gone out, since it's used it would be a good idea to have it checked.
Mar 08, 2014 | Sewing Machines
My touch screen wont respond to touch or stylus or anything at all...screen looks great it just doesnt respond
Can you please advise which model, and what is the problem you have....good detail works best for a better, faster reply..Please use this link ... Contact Us at Bargain Box
My touch screen doesn't respond to touch and I am unable to make copies.
Does it respond to any touches or is it greyed out? This problem can be caused by either a bad touch pad or a defective scanner. Try accessing other options on the front such as the administrative menu. If those work, then the scanner might be bad or locked? Lift the automatic document feeder lid and check the lock on the left hand side to make sure the scanner is not locked. Restart the machine as well, could be an intermittent problem or static discharge.
Jun 06, 2011 | HP LaserJet M3035 MFP Printer
Terrybarnett@talk21.com printer epson sx114 dell 1525 vista scanner will not work all other functions ok installed driver but when pressed box states scanner stopped working please help
Please check the twain_32 folder in C:/Windows
If there is a Dell folder and you're not using a Dell scanner, please delete the Dell folder.
Do not touch the rest of the folders and files in the twain_32 folder.
If you are using a Dell scanner, please contact Dell. It's a software conflict issue.
Nov 27, 2010 | Epson Stylus Multifunction Inkjet Printer/...
MP3 Touch screen is stuck . Can't configure
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
Dec 29, 2009 | Sylvania SMPK8854 Digital Media Player
Lg cookie touch screen not responding. i can turn it on perfectly and all the buttons work but the touch screen just doesnt.
my lg cookie toucch screen not responding , i can turn it on perfectly and all the buttons work but the touch screen just doesnt.
Dec 06, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Touch screen not working...
Hi guys,
i post this solution for those wo will be in the same situation in th next future. I had the same problem with my HTC TyTN (Herm 200). The touch-screen was simply not working. I read many 'solutions' on the net but none worked. I did not try the hard-reset because i was convinced this is not a software problem, and resetting the WM5 will not help. So i brushed the corners, looked for small particles which were pressing on the cover of the touch screen. but it did not work. finally i found one post (i don't remember where exactly) where a guy used a credit card and pushed it all around the touch-screen under the metal case (a bit harder). i tried it and it worked. i pressed harder especially in the lower part, above the buttons. and simply it worked ! no problem since then.
Feb 26, 2008 | HTC TyTN Smartphone
Touchscreen doesnt respond
Hi Your touch screen is part of your LCD and it was connected together thru a small thin cable and it is fragile. When this cable is bad or lost contact , your touch screen is disabled. Only way is to open the case and replace. The method to replace it was tricky. If you make a mistake, you can damage your LCD or scratch it. Please visit these sites for some information: 1) http://www.pocketpcman.com/index.html 2) http://stores.ebay.com/ElecRealm (Store sell Touch Screen) 3) http://www.pdaparts.com/ I hope these information will help you to find the solution for your MDA. Actually, I am repaired all phones and PDA too. If yo need for my help, you can email me at joe_dao2003@yahoo.com. I am writing a lot instruction of how to repair or replace the housing and LCD/touchscreen or can be called digitizer. Good Luck. Regards, Joseph
Apr 30, 2007 | T-Mobile MDA
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
