Question about Sony XDCAM HD PDW-F330 DV Digital Camcorder
Error 03-b57 xdcam pwd-f330 - Sony XDCAM HD PDW-F330 DV Digital Camcorder
3 Suggested Answers
SOURCE: Hi when i put the
03-354
03: optical drive two-axis (FCS, TRK)
-354: No signal from disc required for OP focus servo can be detected. Disc is not rotating
I would try another disc and if you get the same error call Sony's service center.
Posted on Nov 09, 2011
dalehendel
  • 12 Answers
You can't use 50 GB discs in your camera. Insert a 23 GB disc and the error will clear.
Posted on Nov 04, 2013
Sony camcorder xdcam pdw-700 error codes 91-225
No matter what errors are present you will need the manufacturer to repair it, they do not supply repair info or parts to the public, only approved repair stations.
Feb 22, 2017 | Sony Office Equipment & Supplies
Pdw u1
This indicates the hard drive has errors from bad sectors to file corruption, the hardware should be tested, maybe possible to repair.
May 08, 2012 | Sony PDW-U1 XDCAM Drive Unit PDW-U1 USB...
Need instruction book for sony np-f330
NP-F330 is a Sony battery. If you really want the datasheet on it, you may download it here.
If you're asking about a manual for a camcorder that uses the NP-F330 battery, please reply to this post and give the camcorder model.
Mar 07, 2012 | Video Cameras
Hi when i put the XDcam DLA 50 GB disc in my Sony PDW 510 XDCam recorde geve code 03 - 354 error. i dont know about dat. do You can help me ? Thank
03-354
Sep 21, 2011 | Sony PDW-510 Camcorder
Parse error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING, expecting ')' in /var/www/proxy/.release/.core/proxy_s.php on line 367
Connect to the local server using Windows Authentication and specify
the AdventureWorks database as the database in use. To connect using
SQL Server Authentication, set values for the "UID" and "PWD"
attributes in the $connectionInfo parameter. For example:
$connectionInfo = array("UID" => $uid, "PWD" => $pwd));
$uid = "Administrator";
$pwd = "Password1";
$pwd = "Password1";
$serverName = "(localhost)";
$connectionInfo = array( "Database"=>"dbase");
$conn = sqlsrv_connect( $serverName, $connectionInfo); if( $conn )
echo "Connection established.\n";
else
echo "Connection could not be established.\n";
die( print_r( sqlsrv_errors(), true));
// Perform operations with connection.
/* Close the connection. */
sqlsrv_close( $conn);
May 09, 2011 | Computers & Internet
Error 03-454 on pdw1500 deck
What is error03-354 on my Sony XDCAM PDW-F350L?
Thank you. HELP! email: kaltpro@gmail.com
Jan 18, 2011 | Sony PDW-510 Camcorder
When trying to import XDCAM (SD) clips into Final Cut Pro, the xdcam transfer software is first coming up with the error - ERROR SCANNING DEVICE - The mediapro.xml file cannot be found. This is most likely...
The Sony XDCAM EX series camcorder including Sony PMW-EX1, Sony PMW-EX1R, Sony PMW-EX3 and Sony PMW-350. For FCP users who are facing the same issue to import Sony XDCAM EX MP4 to FCP X, there are 2 solutions for you to fix the problems.
The first solution is using third-party Sony XDCAM Transfer software. Prior to importing Sony XDCAM EX MP4 with with XDCAM Transfer, you may use the Sony XDCAM EX Clip Browse to first copy the SxS-based media to local storage. Then you can ingest MPEG-4 wrapped XDCAM-EX media to QuickTime-wrapped media with XDCAM Transfer application on your scratch disk. Then you can simply choose the XDCAM EX Easy Setup that corresponds to your footage and edit as you would with any other native format in Final Cut Pro.
If the first solution is too complicated for you or you encounter some unsolvable problem when adopting the first method. A much simple but reliable alternative solution is recommended to you. You can use a third-party application to transcode Sony XDCAM EX MP4 to FCP X best native compatible editing codec -Apple Prores, which is specially developed by Apple for fast and fluid post-production editing workflow in Final Cut Pro X.
http://www.multipelife.com/transcode-xdcam-ex-to-prores-for-fcp-x.html
Apr 12, 2017 | Sony Televison & Video
Sony XDCAM HD PDW-F330 DV Digital Camcorder Logo
152 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
