Question about LG 42LC2D 42 in. LCD HDTV
Remote control sensor problem
The remote control sensor doesn't seem to be reading the info coming from the remote control. Everything worked fine and now it doesn't. The remote operates the DVD, Audio and PVR fine but not the TV. I tried to reset the codes and nothing works. It won't turn up/down, on or off.
  • 11,361 Answers
Remote IR receiver:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LG+42LC2D+&stock=all&limit=20
You can find out when he will have it back in stock.
Posted on Jul 07, 2010
Bravia kdl52ex700 volume control doesn't work
Look for any jammed buttons on remote, any obstruction like a sticker or gum on the sensor on the TV. If you have such obstructions, the TV will respond only partially.
Aug 15, 2012 | Sony Televison & Video
Batteries seem fine.
Hi Paul,
Base on your questions, I'm assuming that you are trying to sync your universal remote control to your GE 13GP344. If so, you may try the codes below.
GE Universal codes
000/ 003/ 004/ 009/ 022/ 031/ 044/ 052/ 054/ 055/ 087/ 092/ 103/ 107/ 125/ 164/ 181
Enter 3 digit code at a time.
Note : Codes vary on the brand and model no. of the universal remote control. Codes above are the most common 3 digit used for GE television, however if the codes didn't resolve the issue, you should give me the brand and model of it to determine the exact codes for your unit.
You may also confirm if your remote control is working fine by aiming directly the infrared emitter (sensor) to your cellphone camera, while pressing any button key on the remote control, you will be able to see the flash of the infrared coming from the sensor. Please watch this video for more info on how to do this.
Please let me know if you need further assistance.
Nov 11, 2011 | GE 13GP344 13" TV
My KLH 5100 System worked fine for nearly a year. Very suddenly the remote control seems to have no effect on the unit. It doesn't switch it on, or off, or change the volume...nothing. I changed the...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 08, 2011 | KLH R5100 Receiver
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
I have 2 questions. First of all I just got a 2005 Chevy Impala and the speedometer works when it wants to. I noticed that when I turn the key in the ignition the speedometer goes down and eventually will...
As for the first problem it could be a speed sensor in the transmission. Do you have a check engine light on? You need to drive it with a scanner on it to check the speed sensor. If the sensor is reading fine but the speedo doesn't read right you likely need to replace the cluster. As for the second problem, this is a common one on the 4t65E trans. You need to replace the Transmission Pressure Control Solenoid.
May 22, 2011 | 2004 Chevrolet Impala
Fujitsu air con unit. Remote wont work. has new batteries
Check the micro processor control whether it is in manual mode or not. If not check the sensor whether it is functioning or not. If everything is fine then remote control has to be changed.
Aug 15, 2009 | Heating & Cooling
Sony TV no longer responds to Harmony remote
try using some rechargeable batteries. they tend to have more miliamps and last longer.
Jan 14, 2009 | Logitech Harmony 670 LCD Remote Control
New flatscreen/remote not working
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
If your Remote is ok, then the problem with the Remote sensor or related components of the device.
Oct 16, 2008 | RCA DIRECTV Satellite Remote Control
Technical Question
#1 Customer has using remonte control which is not same and made for the Model we replaced laser #2 we open the same unit the one we have replaced laser, put 2-3 small drops of lubricant oil on tracking mechanism (shaft) so when you forward DVD movie in frames tracking DC motor was driving that lasser more smoothly, and made the big difference. It's very critical how much resistance DC motor have while reading disc. Customer was happy -We had rersolve this without any JVC tech support.Those liitle tips nobody has -You should make a notes yourself Zack-Tech
Jan 19, 2007 | JVC XV-N5SL DVD Player
LG 42LC2D 42 in. LCD HDTV Logo
445 people viewed this question
Computer Repairing
Computer Repairing
