Question about Frigidaire Dishwashers
Motor hums but will not start. dishwasher purchased 2001, Price for replacing motor? .
  • joycejenkins Jul 07, 2010
    Thanks Rylee I will look into the cost of replacing the motor.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You are right the issue seems to be with a bad motor. To check the price of motor you can click on this link. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 07, 2010
CAN YOU GIVE ME REVIEWS OF LG LDF7551WW?
I find the LG dishwasher to be of good quality and the only complaint I have regarding the LG brand of dishwasher is that the motors used all have Korean bearings and after a year or so you end up with a dishwasher that gets noisy (a hum) that gets louder, By replacing the motor bearings with good quality bearings solves the problem a small price but you must do this or have it done!!!
May 06, 2013 | LG Dishwashers
My Model #KUDS01FL has been making a humming sound and a service repair man stated it needs a wash motor/pump assembly because a ball bearing is probably not working to capacity. What is the cost of this...
If its just the pump motor that you need, the part number is W10239404. The average replacement cost for the pump is about $112. You can purchase parts on line at any of these websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites have helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need. The pump motor lists as item 10 under the "Pump and Motor Parts" listing.
NOTE: The best price I found was $105 at appliancepartspros.com
If you need further assistance, please post back with your complete model number and let me know. I hope this helps you.
May 10, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
My dishwasher starts humming in middle of cycle and wont go further the rinse cycle works fine
Hello & Welcome to FixYa
Either of these two things can cause this problem: first is the timer motor, if the sound is coming from the control then the timer needs replacement. If the humming comes from the bottom of the unit then it is the motor that needs replacement. When the motor won't work you usually hear humming sound and replacing the motor is recommended repair. Please get back to me if you have any other questions.
Kevin
Mar 14, 2011 | Whirlpool 24 in. ADP5966 Free-standing...
After my dishwasher fills with water, and starts to run, the motor is making alot of noise. Its loud and I'm afarid to run it. Could the motor be bad?
If you hear a loud hum/buzz sound from the bottom of the unit then it is the motor that is bad and if the hum comes from the control then it is the timer/electronic control that is bad and needs replacement. However, after reading your question I believe it is the motor that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 13, 2010 | Maytag 24 in. MDB5600A Jetclean II...
My dishwasher starts fills water and never starts wash cycle?
If you hear a hum when it should be washing, the motor has seized. Replace motor. If it fills with water and stops quite, run it through a test using the tech sheet under the bottom panel to access. These dishwasher have had issues with the motor.
Oct 09, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Dishwasher just hums, faintly, when I turn it on.
motor is locked up.. if you let it hum faintly for a couple min it will cut out most likely.. thats the thermal trip built into the motor.. the motor assm needs to be replaced..
Apr 10, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher motor makes like a grinding noise on start up
Hi. This grinding or hum can be associated with internal electric motor failure. the grinding and humming sounds are warning signs that will ultimately, lead to total failure.The actual term we in the industry use is A.C. hum. This will occur when the internal electric motor windings begin to break apart from the center housing inside the motor casing. this will disrupt the current flow, causing over heating. the grinding is because of the alignment that has been disturbed as well. The solution is to prepare for the replacement of the electrical motor or, you can repair it.
please rate and have a great day.
Mar 21, 2009 | Dishwashers
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
Frigidaire dishwasher does not clean
the start switch in the motor is probably bad,it could also be the motor relay.if you can get to the motor run the unit and while it hums try to turn the motor.it also could be something is stuck in the motor let me know.
Aug 13, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher fill with water then just hums
the hum is probably the main pump powered up but not turning. the pump is an induction motor and a usual fault is the motor capacitor. try to access it, find the value of the capacitor and replace. it is a cheap part
Apr 02, 2007 | Kenmore 24 in. 16039 Built-in Dishwasher
Dishwashers Logo
24 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
