Question about Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw
When using my saw at full revs and cutting it almost dies. have looked at tuning it but the points are fixed unlike a normal saw. the only part adjustable is the idle speed. any ideas??
    Brigadier General:
  • 4,088 Answers
The jet screws have special 'D' heads that are intended to prevent owner tampering. Your options are to make your own special 'D' head screwdriver or to take the saw to a servicing dealer for adjustment. Check the fuel filter, air cleaner, and muffler for plugging. Make sure the fuel lines are in good condition. Check the carburetor fasteners for tightness. If there was a problem and repaired, that might correct the lean-running condition. Don't continue to operate a lean-running saw as that will damage the engine internals for lack of lubrication. Hope this helps!
Posted on Jul 11, 2010
Saw will not rev up to full rpm when you pull trigger it revs up to 1/2 to 3/4 throttle and starts cutting out.
Engine may be too worn or may have run out of oil at some point, compromising the bearings.
May 13, 2015 | Garden
How to set the high and low
Turn mixture screws completely in gently, then wind out 11/2 turns each. The saw will be able to start and run at this point. On idle wind Low clockwise till motor starts to die then anti-clockwise 3/4 turn.
High speed is a little more difficult, On full revs wind clockwise till saw starts to rev out (lean Mixture) then back till the sound starts to bubble.
Jul 26, 2014 | Husqvarna Garden
Stihl trimmer must use choke for full throttle
Sounds like a tuning issue and carb problem. Before you go spending money on carbs or carb kits and start stripping down the carb, try this first.
*Unscew both H and L tuning screws ( not all the way out but back them off)
*Pull over until the engine fires up, it should run for a second and cut out.
*Screw both the H & L all the way back in.
*Then reset the carb to standard settings.
*Unscrew the H tuning screw 3/4 of a full turn.
*Unscrew the L tuning screw 1 full turn.
This should be the standard settings.
Start saw as normal and see if its any better. Failing that your probably looking at cleaning the carb or replacing diaphrams.
Apr 19, 2013 | Stihl Trimmer Zama Carburetor...
Rebuilt a Stihl TS400 concrete saw, and now it wont cut, the engine dies down and has no power but revs up? Ive tried everything!
All these people are missing a basic thing: check the compression. If you did all thus work yourself, you may have reused the head gasket or not installed the new one correctly. It will run with no load, but once force in exerted, the pressure finds the leak and exploits it. There is a reason 2-cycle engines run at 130-160 psi normally.
Dec 27, 2012 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Need instruction on how to adjust carberator
Adjusting carbs on chainsaws is not to be taken on lightly, there will normally be three screws, an L screw, an H screw, and an idle scre, the L screw will increase the fuel mixture from idle to half throttle ( they are fuel screws not air screws ) the H screw will adjust from half throttle to maximum revs, start with a base setting of between one turn and one and a half turns out, start the saw and warm through, allow it to idle, if need be increase the idle screw to get an idle, turn the L screw in slowley, the revs will increase as the mixture leans off, it will reach a point where it starts to die, now back it off a quarter of a turn, blip the throttle, the saw should pick up clean, if it has a flat spot increase the L screw slightley, now set the idle so it idles without the chain moving on the bar, now screw the H screw in to get full revs, be aware this should be set with an engine rev counter, do not exceed the manufacturersmax revs, hobby saws normally run at about 12500 rpm with an idle speed of 3000 rpm.
Oct 26, 2011 | Garden
Hi, i have a 1999 husqvarna 254xp... its abit hard to start and never idles more than 3secs.....from doing some looking into , i think maybe the L screw needs adj? if so could u explain in simple terms how...
In simple terms here we go, turn both L screw and H screw fully in until they stop ( clock wise ) now turn the L scew out one and a half turns out, and the H screw one and a quarter turns out, start the saw ans warm up the engine, allow the saw to idle, if need be turn the idle screw in to gain a slightly fast idle, start to turn the L screw in, the revs will start to increse as the mixture leans off, thet will reach a point where the engine then starts to die because it is too len, at this point unscrew the screw quarter turn, check the machine revs up clean, if there is a hesitation unscrew the jet a smaal bit at a time until it revs clean, now adjust the idle screw so the engine idles without the cutting chain rotating around the bar, the H screw should be about right however if it sounds too rich at full throttle srew the jet in a small amount until it sounds right, the maximum rpm should not exceed 13500, this should realy be check with a rev counter, if the engine revs too high there is a fear that it will over heat and seize.
Apr 13, 2011 | Husqvarna Forest & Garden No.967012396 345...
My saw goes really flat and almost cuts out when cutting at full revs. have tried tuning but the tuning points are fixed unlike a normal saw. Any ideas??
If you are speaking of the H and L jet screws, they have special 'D' shaped heads that require the use of a special 'D' shaped screwdriver. This is so thanks to the EPA who has decided that folks in the USA have no business adjusting their own saws which is causing untold pollution. The only options that you have are: make your own 'D' head screwdriver, or take the saw to an authorized dealer for adjustment. (they are the only ones permitted to have the necessary tool) Good luck!
Jul 07, 2010 | Husqvarna Forest & Garden #952802239 235E...
Cuts out on high revs 240 chain saw
Many saws made today are using electronics for engine control. If the engine rpm's starts to rev to high, the electronics in the coil will start to 'cut out' some of the spark. This is normal in this senerio.
But, now the real problem causing the senerio;
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 10, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna Forest & Garden #952802239 235E 16" Gas Chain Saw Logo
161 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
