Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Sponge caught in erotor - Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
  • 518 Answers
Disconect mains from unit only then atempt to remove sponge and if cant get at it ,removeunit and dismantle
Posted on Jul 07, 2010
What's a sponge filter?
In sponge filters water is forced through porous foam. Water flowing though the sponge allows the growth of a colony of beneficial bacteria which neutralizes toxic ammonia. Most sponge filters uses two sponges attached to one lift tube which is an advantage that the sponges can be cleaned one at a time, reducing bacterial loss.
Aug 09, 2012 | Fish
My 1993 pontiac grand prix se has the gold, diamond, mag type wheels, but the silver outer trim of the wheel has turned dark. what can i do to this outer area of the wheel to return it to its original...
they have wheel cleaners that aren't harsh and will scratch the rim itself,, what your seeing is brake dust that gets caught on the rim, any spray cleaner from your local auto parts store will remove this grime with a spray , light wash with a soft cloth or sponge, and a rinse
Jul 21, 2011 | 1993 Pontiac Grand Prix
We brought a Lexmark Pro205 and it comes up with a paper jam when we hadn't put any paper in, we had literly taken it out of the box, how do we solve this???
ligned sponge located below the printhead. Should you have a paper jam and want to pull out the paper from inside the printer, there is a possibility that you will also pull out some parts of the sponge. The improperly placed sponge may then cause the paper to jam again.
Solution
If you realize that the sponge is not in its proper position, you will need to push it to the correct position (as seen on the images below). Then, when paper goes through the rollers, it will not be blocked by the sponge.
Properly placed sponge (Click for larger a view.) Improperly placed sponge (Click for a larger view.) jam_1.png jam_2.png
Oct 28, 2010 | Lexmark Prospect Pro205 Wireless...
Whilst working, my Ariston oven ventilator tangential fan motor at times produces an intermittent metallic noise, as if metal is touching with metal. What could this be, and how can this annoying noise be...
Whilst Working? An explanation of what you were doing would be extremely helpful.
#1) If it sounds like metal on metal, chances are its METAL ON METAL.
#2) Its pretty obvious you didn't make graduate highschool, let me explain this as simple as possible so you don't hurt yourself trying to read it.
#3) Your fan (thing that blows) probably caught a wire (metal string), or was altered slightly and is now hitting a metal ventilator (sponge) which is installed near the fan on this particular model.
Oct 11, 2009 | Ariston Technologies Ovens
Oven Caught Fire!!
Remove oven racks and look for two screws in the back on the bottom. Remove screws and lift out oven bottom. Do not use self clean.
Mar 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Epsom stylus c40 sx head cleaning sponge is leaking black ink needs new sponge
hi,,
you can wash that sponge and you can used it again instantly..
rey
Nov 05, 2008 | Office Equipment & Supplies
Error - carriage jam message
My Photosmart 2610 just started having this same problem today. As many of you have done, I also went to the hp support website and tried just about everything. Finally I discovered the answer to my problem on my own. Here's what I did (you might want to have a wet rag handy to wipe the ink off your fingers):
1) With the printer on, I pressed "okay" to clear the error message. You should immediately hear the sound of the carriage (the contraption that holds the cartridges) moving inside.
2) Open the print cartridge access door (the main access point for the cartridges) and confirm that the carriage is indeed moving.
If the carriage won't move at all, I'm not sure that this solution will help you. However, if the carriage moves from side to side after you press "okay", please read on.
3) This is unorthodox, so bear with me: when the carriage moves away from it's "resting place" (in my printer it's on the right hand side) and is near the center of the printer, unplug the power cord from the printer. The purpose of this is to free up the undercarriage (which was the part that actually was jammed on my printer).
4) Ensure that the carriage moves freely from left to right and right to left by pushing gently on its sides.
5) Move the carriage to left side of the printer so you have room to access the undercarriage.
6) It might be helpful to have a flashlight or some other light targeting the undercarriage for this next part. If you look directly underneath the undercarriage, you should see a foam/spongy product resting in the base of the printer. The purpose of the sponge is to absorb any ink that escapes from the cartridges. Herein lies the problem: over time, as the undercarriage adjusts to enable the carriage and its cartridges to do their work, the undercarriage gets caught on the inky sponge. Note that the undercarriage is fragile, but is moveable by gently pushing it toward the front or back of the printer.
7) Adjust the undercarriage so you can see the sponge and the "axel" (for lack of a better term) that turns to move the undercarriage forward and back. It may take some detective work, but you should be able to determine where the sponge is supposed to lie. Your goal here is to push the sponge down as far as it will go so that it won't obstruct the movements of the undercarriage.
8) On my printer, there was also a small amount of sponge wrapped around the "axel" that prevented it from moving smoothly. I unwrapped it and double-checked that nothing else was obstructing movement.
9) Final step: leave everything where you moved it, shut the lid, and plug it back in. A little prayer never hurts either. Good luck! AIM ID if you need more help: GnarlyVeaux
Jan 15, 2008 | HP Photosmart 2610 All-In-One InkJet...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
130 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
