Question about Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White
Went to turn on self cln,
My self clean oven is giving me a message E-1 and F-5.
I tried it setting the timer for 1 hour and I'm still getting the same message and now it wont let me shut it off!!
HELP!!
Thanks!,
Mary Stitch
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F5-E1 error indicates that you’ll need to check the door latch/switch and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 10, 2010
How does the self-clean feature work on a Frigidaire CFEF366EMB model?
Hi Beverly,
I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
-To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
-Next you will press the "Clean" button, and the display will show "---".
-Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
-The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
-"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
When the self-clean cycle has completed:
-The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
-Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
-If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
-When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
-Best Regards-
Jan 23, 2014 | Frigidaire Ovens
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Moffat Stove with a self-cleaning oven. I would like to know how to clean the oven using the "self cleaning" feature
hi there! I have a moffat stove and hopefully these instructions help you.
First clear out the racks in your oven. Take them out and remove any excess chunks at the bottom.
Then close your oven door and lock it by pulling the lock latch.
Now looking at your oven knobs [not your burner knobs] turn both of them so they are both on the arrow knob [your oven knobs should have small pictures on them and both should have arrows]
Now you need to set the time so in the middle of your oven their should be a timer and one start and stop timer on top of each other. Both timers go in increments of half an hour. So if you are starting your self cleaner at 3 move the dial to 3 or if you are starting at 3:30 move the dial to one tick after 3. Once you set your start timer, you need to set your stop timer.
Setting your stop timer, it is recommended to set it for 3-5 hours. I set mine for 4 hours. So then set stop timer to time you want the cleaning to be. If you set your start timer at 3:30 put your stop timer at 7:30.
The oven will start cleaning according to the time you set. The oven will get very hot. I recommend to not used the burners as the temperature goes to 500 degrees! You will smell an odor and that is your oven cleaning.... Hope this helps...
Sep 13, 2010 | Ovens
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
Frigidaire oven
Try resetting the timer to manual, consult your user instruction book.
Dec 11, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
F1 error
I have had the same problem and the machine is 12 years old - serviceman who came told me the console can be replaced for $400 - I am opting to purchase a new oven
Nov 13, 2008 | Maytag Ovens
Wont lock in self clean
Whirlpool Gold range: start the self cleaning but after message: cln door comes message, E1-F5- . door does not lock and cleaning can not start.
Oct 10, 2008 | Thermador C302U Electric Double Oven
Self cleaning lock handle does not unlock
Unplug power, wait one hower and plug cord back.
That should reset the oven, if it does not, the oven timer control is clearly defective and should be replaced , you find parts here.
Oct 08, 2008 | Thermador Ovens
VDSC307-4bss how to operate self-cleaning oven
I continued a search and found a manual on line... simple process to turn on self-cleaning operation... close the door and set to "clean" ... timer on this model is automatic... runs for 3 1/2 hours.. fan continues for an additional 30 minutes ... open the door and the oven is clean. Thanks
Mar 28, 2008 | Viking VCSO244 Dual Oven
Self cleaning oven not working right
shut the power off and see if it resets.
Jan 09, 2008 | Ovens
Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White Logo
275 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
