Question about Lexmark C534N Printer
Error 120.10 service fuser error
  • 2,296 Answers
Service Fuser Error appears on your Lexmark printer when the fuser does not warm to the required temperature. For this error on this Lexmark model, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Posted on Feb 26, 2011
5 Suggested Answers
jaylex
  • 417 Answers
SOURCE: dell laser printer m5200: 922 service fuser error
The fuser is not warming up replace fuser.
Thanks J
Posted on Jan 19, 2008
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: 920.06 SERVICE FUSER ERROR
    A 920 fuser error indicates that the fuser unit in the printer is below the proper temperature for printing. Turn off the printer for 30 seconds. Bypass any surge device or power strips, plug the printer straight to the power outlet in the wall. Make sure the printer is an operating environment where the temperature is above 16°C (60°F). If none of the steps above correct the issue, the fuser unit or possibly the power supply unit on the printer will need to be replaced. This will require a service action on the printer. I hope I can assist you more on this.
    Posted on May 26, 2010
    printmastert
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: error message. 924.01 service
      The 924.01 service fuser error indicates either the fuser unit is not able to reach/maintain the correct temperature or the fuser unit is not working. What you can do:
      • Turn off printer. Turn on after 30 seconds.
      • Plug printer straight to power outlet in the wall. Bypass any surge devices or power strips, they draw away power from the printer.
      If problem continues, contact Lexmark technical support(under warranty) or your local authorized service provider for professional repair.
      Posted on Sep 22, 2010
      tballone
      • 126 Answers
      SOURCE: i have a Lexmark c540n printer that has the fuser
      you can reseat the fuser, and see if the message goes away. Or you will need to replace the actual fuser assembly. unfortunately you can't just remove/clear the error. see picture attached as this is what the fuser looks like
      after you replace it let me know if you still receive the error.
      Posted on Oct 19, 2010
      E studio 520 code c447
      All error code soloution of fuser unit Fuser Unit Error Status Counter
      Purpose
      When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
      counter varies, depending on type of error.
      Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
      any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
      After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
      "10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
      after the fuser unit related error is resolved.
      C41: Thermistor or heater abnormality at power-ON
      C43: Thermistor abnormality after abnormality judgment
      C44: Heater abnormality after abnormality judgment
      C45: Thermistor abnormality during printing
      C46 to C49: Reserved
      Description
      When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
      manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
      error is resolved.
      For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
      [Fuser unit related service call] in the Service Handbook.
      0: No error 10: C47 (Reserved)
      1: C41 (Once) 11: C47 (Reserved)
      2: C41 (Consecutively occurs) 12: C48 (Reserved)
      3: C46 (Reserved) 13: C49 (Reserved)
      4: C43 14: C47 (Reserved)
      5: C44 15: C48 (Reserved)
      6: C45 16: C49 (Reserved)
      7: C44 17: C47 (Reserved)
      8: C45 18: C48 (Reserved)
      9: C44 19: C49 (Reserved)
      * Default: 0
      Setting Timing
      Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
      error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
      Caution
      Remember to resolve the fuser unit related error, and then reset to "0." also 447
      Jan 17, 2014 | Toshiba Office Equipment & Supplies
      Error code c43
      Purpose
      Description
      error is resolved.
      * Default: 0
      Setting Timing
      Caution
      Jan 14, 2014 | Toshiba Office Equipment & Supplies
      Call for service C 430
      Purpose
      Description
      error is resolved.
      * Default: 0
      Setting Timing
      Caution
      Dec 31, 2013 | Toshiba estudio 255 Copier
      TOSHIBA E STUDIO 207 ERROR C 44
      Purpose
      Description
      error is resolved.
      * Default: 0
      Setting Timing
      Caution
      Jul 08, 2012 | Toshiba E Studio 207
      Error call service 4000:00433933
      The codes on this model are the same as on the Kyocera Mita copiers.
      ie: 4-digit codes
      Call service 0150 engine pcb EEPROM error
      Call service 0420 option paper feeder communication error
      Call service 1010 lift motor lock error
      Call service 1140 lift motor going up error
      Call service 1150 lift motor going down error
      Call service 2000 main motor error
      Call service 2200 drum motor error
      Call service 4000 laser scanner unit (polygon motor) error
      Call service 4200 laser scanner unit (pin photo sensor) error
      Call service 5100 short-circuited main charger output
      Call service 6000 broken fuser heater lamp M wire
      Call service 6020 abnormally high fuser thermistor M temperature
      Call service 6030 broken fuser thermistor M wire
      Call service 6400 zero-crossing signal problem
      Call service 7000 toner motor lock error
      Call service 7410 drum unit non-installing error
      Call service F000 communication error between the main controller board and operation panel board
      Call service F010 main board (system DIMM board) checksum error
      Call service F020 main or expanded memory error
      Call service F030 general failure
      Call service F040 communication problem between main board and engine board
      Call service F226 main pcb video data control error
      May 18, 2011 | Kyocera FS-3900DN Laser Printer
      E 352dn Mono Laser Printer: error 922 service fuser error...
      Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T632, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
      If the printer is out of warranty, your next option is to change the fuser which costs around $90 on Ebay.
      May 18, 2010 | Lexmark E 352dn Mono Laser Printer
      Error 58.04
      This is from the service manual and should help you determine if you need to call in for service. If is in warranty I would anyways since the fuser would be covered if at fault.
      58.04 ERROR To continue turn off then on. The low-voltage power supply has experienced an error.
      1. Reinstall the fuser. Check the connector
      (J1901) between the fuser and product.
      Replace the cable or fixing unit if the
      connector is damaged.
      2. Reconnect the connectors of the fuser
      control PCA (J303, J305) and the DC
      controller PCA (J107).
      3. Replace the fuser. See Fuser
      on page 191.
      May 03, 2009 | HP LaserJet 5200tn Printer
      980-fatal-error
      Service call 980:Error
      Cause: Error by media clinging to the fuser
      Error description: Media has clung to the fuser.
      Solution: Power OFF. Replace the fuser unit.
      Nov 19, 2008 | OKI C5800Ldn Led Printer
      980: Fatal Error
      From the Service Manual:
      *Service call
      980:Error
      *Error by media
      *Media has clung to the fuser.
      *Power OFF
      Suggestion -
      Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
      Apr 07, 2008 | OKI C5800Ldn Led Printer
      Lexmark C534N Printer Logo
      828 people viewed this question
      Top Lexmark Office Equipment & Supplies Experts
      Don  Farrell
      Don Farrell
      Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
