Question about KitchenAid 24 in. KUDP01DLBS Free-standing Dishwasher
My Kitchenaid dishwasher (model KUDS02SRSS0) keeps burning out my dispenser. First I replaced the dispenser, then I replaced the control board and dispenser, it worked for two weeks and now I have a melted solenoid again in my dispenser. I've measured voltage to the solenoid and it is getting 110V through the entire diagnostic cycle. This is wrong. It should only get power at some point during the cycle to open the dispenser. It appears the control board has failed again and in the same way the original board failed. How odd is that? Should I put a new control board and dispenser in yet again or should I be looking for something else that caused this?
  • tsbergman Jul 07, 2010
    This was quite helpful. I needed to make sure I'm not wasting my time if some other damaged component is causing this grief. This answer confirmed I'm on track and should get these components swapped yet again.
  • 6,784 Answers
HI. The relay that controls the voltage and timed release command, via logic chip, is indeed damaged(stuck on). This is a common theme with this particular design. The original control board was recently replaced with a substitution model(W10084141). This sub board was authorized as a suitable replacement for the original design. The necessary action are to replace the damaged control device and the dispenser assembly, once again. This fault dose not include any other sections or components in this unit. It is totally isolated to these two parts that are damaged, once again.
Posted on Jul 07, 2010
  • Michael Masters
    Michael Masters Jul 07, 2010
    The dispenser has also been discontinued(the original design). The new sub part will be(W10224430)
Kitchen aid dishwasher rinse dispenser not working
Hello Cecil;
My name is Peter. I am a retired field service appliance technician.
Your problem is one of two components: Either the dispenser or the main control board. I will bet on the dispenser. Sears wants about $100.00 for the assembly. Go into the internet. Search W10195174. You can get this part for $38.00 plus shipping. If you install this part and it does not solve the problem, you can return for credit less shipping and restocking charges. Get back to me if it does not solve your problem. I have faith in you.
Do not ruin my record. I received three personal E mails today. Two were from people such as you advising they got his clothes dryer and her oven working. The other person we are still working on her refrigerator. Peter Goodwin, Glen Burnie, MD, Goodwinpeg@aol.com Keep me up to date.
1.) Dispenser assembly -
a.) Turn power off at the breaker box
b.) Replace as instructed on the video below.
Dishwasher Dispenser Assembly part W10195172 How To Replace
May 09, 2015 | KitchenAid Kitchen Aid KUDS35FX Dishwasher
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
Dtergent dispencer does not open
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Troubleshooting
Dispenser Lever
Wax Motor Actuator
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Gd bless you
Lights are on, but dishwasher will not start. Called a local repairman. He decided the control board failed. he ordered a new board and replaced it. Now he says the new board is defective. I think...
That model has an electronic thermal fuse that clips onto the control board housing. the dishwasher will not start if that fuse is blown. you can check it if you have a meter. If it has continuity through it, its good, if no continuity, replace it. They cost between $20-$30. If that is not the problem, I would be looking at that motor. Kitchenaid makes a great dishwasher, but I can't count how many motors I've had to replace in them. Hope this helps, good luck.
Oct 16, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
Won't power up
The control board is above the dispenser so it is unlike the water would get up there... I would check the door switchs you may have a loose one... good luck
Aug 17, 2008 | KitchenAid 24 in. KUDP02FR Built-in...
KitchenAid 24 in. KUDP01DLBS Free-standing Dishwasher Logo
163 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
