Question about Sunbeam Heating & Cooling
Model SCK7500DR needs controller
Have window model SCK7500DR, bought 2004 scarcely used. Am told electronic control has failed. Sunbeam tell me discontinued, no parts available. Any substitution part available?
  • 787 Answers
Sorry, you won't find the needed part. If it's not on amazon or ebay you won't find it.
Posted on Jul 07, 2010
Heat and aircondition.My heat and air only work on number 5
Sounds like a "fan motor speed controller" or FMSC.
Either that module has gone out...or we're not getting the signal from the control panel sometimes called the EATC.
Lincoln has an EATC (for electronic air temp control)...GMC has something similar.
There is a way to run a diagnostic test of the EATC but am having trouble finding it for GM models.
If EATC test is done and fails...it will tell you it failed and would need replacing.
If EATC passes...it will tell you it passed and the fan motor speed controller would be at fault.
Usually, when a speed controller fails, the blower motor either doesn't turn OR it runs full blast.
Both parts EATC and the FMSC are expensive.
Since yours is running full blast...at least its providing air.
I'd try to run a diagnostic check to be for sure and maybe your parts might be less expensive and available at your local parts store.
Hope this helps...
Aug 13, 2011 | 2004 GMC Envoy
I have a Sunbeam Queen washable electric Blanket dual control model BL445D. One of the detachable controls is not working and I would like to buy a replacement one? can you tell me where I can find one...
Hi. You can locate a Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
You're looking at $64.00 recommended retail.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
May 26, 2010 | Sunbeam Heating & Cooling
We have an sunbeam electric blanket model BL 0750 We dont seem to be able to programme it to heat up. Control lights are flashing
Hi. If you have a double or queen size blanket, switch the controls from one side to the other. If the fault follows the control, then the control is faulty. If the fault stays on the same side of the bed, then the blanket may be faulty. Most recent Sunbeam models have 3 years warranty. Once you've checked the controls, if it's under warranty call Sunbeam Customer Service on 1800025059 option 1 to report a warranty issue.
Otherwise: if the control is at fault, a new BL0750 has a recommended retail of $75.20. Get in contact with your local Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
but if all else fails email me as I'm happy to help!
May 25, 2010 | Vacuums
Sunbeam Model No. SCK 14200 DR no cooling...
Un plug a/c from wall and remove the screws from the electrical compartment of the unit and locate the thermostat, remove the 2 wires of the thermostat and use ohms meter to check the part for continuity, if you dont have continuity with t-stat turned down below room temp., replace thermostat.Good luck.
Mar 05, 2010 | Sunbeam SCA103RWB1 Room Air Conditioner
No power
There should be a fuse inside the housing.
10 or 15 amp.
That might be the problem
Kurt
Apr 06, 2009 | Sunbeam 5891 Bread Maker
My sunbeam mixmaster is stuck on one speed - fast!
it will be the motor suppression capacitor fitted accross the speed control. When they fail and go short circuit, sunbeams run at their highest speed. Remove it and replace and all will be well.
Feb 09, 2008 | Food Mixers
Heating & Cooling Logo
136 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
