Question about Anti-theft Alarm System 3 Series E90 E92 Bnib
My car alarm goes off consistently after setting it. I drive a 2005 325i. Is it set to semsitive? How can I fix this?
If its the standard alarm then get in touch with a main dealer, if its a after market alarm then there should be a little screw on the brain of the alarm box that changes the sensitivity!
Posted on Jul 08, 2010
The alarm on my 2007 ford escape randomly goes off. how is this easily and cheaply fixed?
It depends what is setting it off. If it is just a loose door latch, it is usually easy to fix. Lock the car and set the alarm. Pull on each door handle to see if a door switch opens and sets off the alarm. If it does, adjust the latch on the door to close the door more fully.
If it is not a door switch, maybe the inertia switch is too sensitive. Unless your model has an adjustable sensitivity, that problem is harder to solve.
Aug 12, 2017 | Ford Cars & Trucks
Alarm keepsgoing off?
Should you post a model number i could tell you how to fix that alarm. Sometimes when the power goes out or if there is a battery backup the alarm set previously was not reset thus goes of at that set time.
Aug 07, 2015 | Audio Players & Recorders
Alarm goes off at 5:00 am everyday
You need to check the manual for the alarm settings menu that allows you to go through the settings and disable the alarm.
Jan 31, 2015 | Cars & Trucks
Nissan alarm
try and find if there is a sensitivity adjustment for the alarm and set it to a lower setting
Jan 11, 2014 | 2004 Nissan XTerra
Samsung Galaxy S4-Alarm Problem
Go to your alarm settings and make sure that the Smart Alarm is off, I know that the smart alarm makes the alarm go off early, this could be possibly be the problem.
May 23, 2013 | Samsung GALAXY S4
The anti-theft alarm goes off everytime you open door regardless if it is locked or not
Interesting, seems alarm has been set-off before<now circuit is ON> and not been re-set back to neutral<re-set circuit to OFF> so when doors are closed, alarm memory retains previous set alarm memory <circuit set to ON>. It'ill go off again whenever door being opened, regardless it have been armed or left open as the memory circuit recognise it still as before alarm set-off<circuit is set ON>.
Solution, 1) Read your car owner's manual in the alarm section, read on how to re-set alarm to neutral if it has been set-off while armed [my experience is by turning the ignition key as if you are going to start the car engine but do not start engine then back to off position, do it 3 times as it will beep after 3rd run]. 2) On 4th run, start the engine, lock all doors then unlock it, 3) Turn off engine, get out from car, lock doors and arm alarm. 4) Dis-arm alarm, open doors and see if it still set-off alarm as before.
If all that doesnot work, go to your local dealer as alarm system has a system fault that can't be fixed without proper equipments.
Follow the instruction on how to accept and mark advise as giving you a core solution. Return a thumb up and praise response. Thank you.
Jan 05, 2011 | 2000 Honda Passport
I have a g1100b. having problems setting the alarm. I keep setting it to 0600 but the alarm consistently goes off at 1300 daily. any ideas of how to set the alarm correctly?
If the date changes at noon then you just need to cycle through another 12 hours to be sure that it changes at midnight. It sounds like your clock is off by 12 hours.
If this doesnt work then have the watch AC'd or reset. This might correct a problem with the circuit board.
Sep 18, 2009 | Watches
Open door alarm keeps going off
Check all your door switches by hand & see if one acts intermittently.
May 26, 2009 | 1996 Dodge Stratus
Viper 5701 2 way alarm and remote start
Most ford need the door triggers double diode isolated. When the GEM module goes to "sleep" it will set of your alarm . Cut the factory wires where you hooked up the door triggers determine which side goes to the door and which side goes to the GEM module. If it is a negative trigger solder in a 3amp diode with stripe towards the door then solder the door trigger from the alarm to the door side of the diode. Repeat for all door triggers.
Dec 18, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Anti-theft Alarm System 3 Series E90 E92 Bnib Logo
438 people viewed this question
Top BMW Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
greg benton
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
