Question about Nikon COOLPIX L100 Digital Camera
I have installed the Nikon Transfer software and am using the usb port connector. All I get is "the camera is busy" and zero program showing up in the dialog box where you select "always use this program". I am running Windows xp. This is very frustrating! The manual is less than helpful. Why won't the camera transfer the pictures? thanks rll st. Paul
I had the same problem with the same camera. What worked for my pc was to start the Nikon Transfer software, select the camera and press the "start transfer" button. Nothing happens for about 6-7 minutes, but after that the transfer starts.
My pc: XP SP3
Camera: Coolpix L100
Nikon Transfer: ver. 1.3.0 (i used the software that came with the camera not the up to date version 1.5.3, but it might work with that version also
Posted on Jul 18, 2010
Unable to transfer pics from camera , by using cameras usb port .playback error message comes up on camera screen
First install the software belonging to the camera, so the compute knows what to do when you connect a camera. Then connect the camera and you can transfer and edit your photo's.
When you lost your CD, go here to get view NX2 it is free.
Current versions of Nikon software Nikon Knowledgebase
Mar 31, 2015 | Nikon D5200 DSLR 18-55mm Lens Kit with...
Viewnx2 does not show any devices to transfer from
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Jun 04, 2013 | Nikon D7000 Digital Camera
I have a Nikon L24. I do not have the cd needed to install the software so I went to the Nikon site and downloaded the software needed to transfer my pics from my camera to my computer. I hook my camera up...
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Apr 10, 2013 | Nikon L24 Digital Camera
Nikon Coolpix S52C camera transfer pictures problem.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Sep 06, 2012 | Nikon COOLPIX S52c Digital Camera
I tried to install software which came along with my digital camera nikon coolpix s3000. After installation I opened the icon but it showed some error. I need to transfer pictures from camera's internal...
If you need it, you can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
To copy pictures from internal memory to the memory card, press the Playback button, select MENU, then select Copy.
Mar 08, 2011 | Nikon Coolpix S3000 Digital Camera
I am unable to get my nikon coolpix l11 to install on my computer that has windows xp. I downloaded and installed nikon transfer 1.5.3 for windows and i installed it but nothing happens. I plug my camera...
Consider NOT using the USB connection.
Nov 16, 2010 | Nikon Coolpix L11 Digital Camera
Coolpix s220 won't transfer pics via usb cable
If you can get the pics using a card reader, why are you insisting on using the camera and USB cord? Pros always use a card reader.
Feb 07, 2010 | Nikon COOLPIX L3 Digital Camera
No source identified, no transfer
First. reboot the computer. If you leave your computer on all the time, an occasional reboot will often clear up an unresponsive program and "sharpen the teeth" so-to-speak. If you've done this, try going directly from USB cable to the camera. If it is still unresponsive, try plugging into a DIFFERENT USB port on the computer. If you've done all of this with the same cable, try using that cable and camera on a different computer. If it is unresponsive there, you may suspect the cable as being bad. Try a different cable. If you're still having issues, suspect that the USB port in the camera has gone bad and have a reputable repair shop take a look at it.
Jul 10, 2009 | Nikon Coolpix S210 Digital Camera
Card Full but showing none
As long as the xD card was not formatted it is possible to recover the images that were accidently erased,lost or corrupted. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and many people have had much success in recovering lost images.
Data recovery is a booming industry, and many appropriate services and software can be found by searching regional phone and business directories or the Internet for terms such as "image recovery" or "data recovery".
May 18, 2009 | Sony Cameras
Transfer pictures from my Nikon, Coolpix S51
Hi!
Try to plug into a different USB port. If that does not help then go to Control panel->systems-> hardware tab-> device manager->and now try to see if your Camera appears under the options listed (would be under Scanners and Camera, Click on every + sign to see)
Do rate the solution.
Thanks
Rylee
Feb 10, 2009 | Nikon COOLPIX S51 Digital Camera
Nikon COOLPIX L100 Digital Camera Logo
402 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
