Hi I Have Problem
Hi
i have Motorola Surfboard SB5101i for my internet service provider.i wan use my Aztech DSL600EW as my wireless internet
how did i setting to be able suft net from wireless internet? thanks
You
Posted on Jun 28, 2008
  • 21 Answers
Hi Andy,
The WAN port on your Aztech DSL600EW (by default) is configured to be automatically assigned an IP address when connected to a cable modem (Motorola). Connect the WAN port of the Aztech DSL600EW to the Ethernet port of the Motorola, then configure the Aztech for wireless connectivity to your laptop as per the manual instructions.
Posted on Apr 18, 2008
Hi Currently i am using internet Type: Broadband provided by Local Cable operator Modem:Motorola SB5101i Connection type: PPPoE [with username/password] Using with: Dell inspiron15 Laptop Location:...
There is a configuration facility included with the modem that you should be able to access to help troubleshoot the connection.
The Cable Modem has three active interfaces, the HFC, the Ethernet and the USB and each
interface has both a MAC and an IP address associated with it. When operating normally it is the
IP address of the HFC interface that is used for diagnostic access to the modem. However the IP
address associated with the Ethernet interface is always available to the client side network,
unless it has been disabled by management command. This means that a PC on the client side
can access the WEB pages within the modem using the reserved address 192.168.100.1. This is
a non-routed address so it cannot be reached from the Internet (routed) side of the network
The SB5100 family of modems contain an internal DHCP server, which is active until the modem
registers with the CMTS. In the case of a problem that prevents the modem from completing its
registration, the modem can still give an IP address to the client PC to enable diagnostics access.
This address is given with a very short lease (around 10 seconds) so that as soon as the
registration does complete the client PC obtains its proper IP address from the core network
DHCP server.
Mar 15, 2017 | Arris SURFboard® SB5101 Cable Modem
Hey,im needing immediately the password of the motorola sb5101i when i type in adress bar 192.168.1.1 it ask login and password but i dont know the login or password and i really need it i need to change...
HI i beleive you are looking for a user name and password for the motorola sb5101i
here are the username and password for the modem which are default
USER NAME:-ADMIN
PASSWORD:-leave it blank>>press login(this should work)
DEFAULT IP FOR YOUR MODEM:-192.168.100.1
IF THIS doesnt work try to turn off the modem and turn it on back...this might work
or else you can try to reset the modem,once this is done you might have to reconfigure the modem...contact your internet service provider to set it up
Apr 25, 2011 | Computers & Internet
Well,when i type in the adress bar 192.168.1.1 it ask the login and the password but i dont know the login or password my cable modem is a motorola sb5101i SURFboard Thanks
USER NAME:-ADMIN
Apr 25, 2011 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
How to set up password
insert the disc supplied by your ISP internet service provider then enter the the user name and password you provided to your intenet service provider ISP then just follow the prompts
hope this helps
Dec 22, 2010 | Arris Surfboard SBG900 Modem Cable Modem...
I cannot find the security key on the bottom of my motorola surfboard modem
Contact your local Internet Service Provider for assistance with your cable-modem.
Or, if you have connected a wireless-router to the cable-modem, and now you are trying to connect a wireless-device to the wireless-router, that's where a "security-key" is needed.
Dec 20, 2010 | Arris SURFboard SBG900 (49402201900) Modem
Where can i find a driver nfor my motorola surfboard SB5101i pls help me...
Download it from here
http://www.driverfiles.net/download.php?ID=30479
Mar 28, 2010 | Arris SURFboard® SB5101 Cable Modem
Connection drop-outs
I hate to be the bearer of bad news but from the information on the forum sites you have a bad router. They have tried the newest firmware but this unit will continually lockup. Here is one forum you can check as see what they are saying: http://forums.macrumors.com/showthread.php?t=299590
Nov 25, 2008 | D-Link DIR-625 (790069292637) Wireless...
Motorola SURFboard SB4200 With Buffalo Airstation
If it were me, i would return the airstation. then i would buy a linksys WRT54G. They are about 50 dollars. Then use that to set up your wireless network and you will find it quite easy.
Apr 24, 2008 | Arris SURFboard SB4200 Modem
Is your laptop wireless adapter a compatable brand. It doesn't necessarily mean the router is bad, you may even be getting RADIO interference from a cordlees or a cell phone in it's path. Do you have the capability to plug a cat-5 cable directly into your laptop from the router when you lose wireless? Check the wireless channels and see about changing the channel on your cordless phone too. May not work, just a hunch.
Good Luck
Mar 18, 2008 | Linksys Wireless-G WRT54G Router
How to connect linksys router with aztech adsl modem
To setup your router
first check..
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connection..
Step 1:
Connect the Broadband modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
to config your router i need some more information
your internet service providers (isp)name , and how many computers do u have totally..
Nov 16, 2007 | Computers & Internet
Computers & Internet Logo
204 people viewed this question
David Payne
David Payne
