Question about Sanyo PLC XU48 Multimedia Projector
LCD projector lamp hours
How do I check the lamp hours used on the PLC-XW50 projector? By following the manual - does not work.
SOURCE: Sanyo Projector PLC-XU50 Lamp Hours
Turn projector on and before doing anything else, press and hold the UP arrow on the machine for 30-40 seconds WHILE watching the display screen on the wall - the remaining hours will display only momentarily - if you look away you could miss it. Cheers
Posted on Jan 31, 2008
  • 18 Answers
SOURCE: How to check lamp hours on xf-45 or xf-35?
On the XF-45, you push the "UP" button and then the "Menu" button and hold both of them for approximately 20 seconds. After that you will see a bunch of numbers in the top left hand corner of the screen. Using the Left and Right arrow keys, move the "Group" number until it reads 111. Then using the Up and Down arrow keys to scroll through each lamp (0-3).
If you move the "Group" number to 110, you can see total number of hours that socket has run.
Posted on Apr 09, 2008
  • 5 Answers
SOURCE: sanyo plc xu 40 lcd projector problem
not only reset the timer is good enough
u must use serive cable to disable the shut off function
and technically reset the system
Posted on Jul 10, 2008
  • 3 Answers
SOURCE: Reset Lamp Hours Timer
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "VOLUM -" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
This works for Toshiba TDP T-9
Posted on Jul 11, 2008
  • 3 Answers
SOURCE: Sanyo PLC - Z5 Lamp Replacement Light
Just had the same problem. Based on other suggestions on here I tried resetting the overheat switch, and IT WORKED!
So, you have to pull the 6 screws (one of them is shorter than the rest, remember where it goes) that hold the top on the projector. 3 are on the back, 3 on the bottom - look for the arrows next to the screws.
Put the projector on it's feet, and pull off the top. The button wires will still be connected, so just hold onto the top and find the black circle/shaft above where the lamp is. The shaft has white paint on the top/tip of it. Push it down with a light amount of force. You should hear/feel it click.
Put top back on, put screws in, and you should be good to go.
Don't forget to reset the lamp replacement counter in the menus.
Posted on Aug 01, 2008
Where can I find the lamp counter-menu on a PLC-xf-46, I just want to check how many hours are on. I do find the counter-reset menu, but that's not what i'm looking for. many...
hold down the UP button on the keypad for 30+ seconds, a pop-up menu will appear on the screen indicating the lamp hours. if that doesn't work, hold down the POWER-ON/OFF button for 30+ seconds. it's one of those 2.
May 26, 2011 | Sanyo PLC-XF46 LCD Projector
No electricity goes through my Plc-xu110. it was working perfectly until a current surge b/c someone turn-off the breaker abruptly. In that case what should I do?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Mar 14, 2011 | Sanyo Projector Lamp for PLC-XU100,...
Sanyo plc-xt16 Projector After the projector is turned on and the countdown finishes on initial start up the projector shuts itself off within 5 seconds. The fan runs for 1 minute and then the projector...
It sounds like the lamp is going.
Do you know how many hours of use are reported on the lamp?
Many times these projectors have circuitry to shutdown when they suspect the lamp is near the end of life. Lamp hours vary and usually will go up to and even beyond expectancy, but there is occasions you can receive a bad lamp and have it blow in a matter of hours...not common but it does occur.
I hope this helps,
Magoo
Mar 09, 2011 | Sanyo PLC-XT16 Multimedia Projector
Hello, I have a PLC XP45L. As soon as I turn on the projector it goes off. The only light on top of the projector is the READY light. We replaced the lamp last year and probably have around 50 hours on...
good day mr david, just clean the air filter of your projector, check all the fans if working... if this problem occur again your lamp ballast is defective.
jahting
Oct 29, 2009 | Sanyo PLC XP45L Multimedia Projector
Is there any way to check the bulb life on a Sanyo PLC-XU30 projector? I know some projectors have an option on the menu screen which lets you know how long the bulb has left. Its just that i bought it off...
on my XU 55 the trick to read the lamp hours is to press and hold down the power button in about 20 seconds when the projector is turned on. there will come a window in the upper left corner that tells about total hours and lamp hours. the window will disappear quite fast, so one might need to do it twice.
Jul 28, 2009 | Sanyo PLC-XU30 LCD Projector
Sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on.
Aug 04, 2008 | Office Equipment & Supplies
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
Jan 22, 2008 | Sanyo PLC XF45 Multimedia Projector
Sanyo PLC XU48 Multimedia Projector Logo
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
