Samsung washer error code d5 turning off and on will not reset this
SOURCE: Maytag neptune error code d5
there is a small button on the inside edge where the door closes, it was broken off since there was nothing there I didnt see it.It was only a hole where the button was.So I had to get a new button and replace it.
Posted on Jun 17, 2008
make sure it is installed correctly - there are 4 yellow plugs at the back that need to be taken out.
Posted on Jun 20, 2008
SOURCE: Fault code on an Amana Washer
The door is open. Be sure that the door is completely closed.
Posted on Mar 01, 2009
  • 220 Answers
SOURCE: error code d5 on front load neptune washer
d5 is a door lock error code,more than likely a bad door latch it's an easy repair,here is a link to the Neptune repair manual this the Mah 3000 but they all come apart the same way the only real difference was in the control panel and the door latch in yours uses a solenoid to lock instead of a wax motor
http://www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Posted on Sep 13, 2009
SOURCE: error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Posted on Jan 20, 2010
Samsung front load washer code d5
The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. the problem is related to faulty door locking assembly.There is a switch in back of door, if this fails it wont work. God-Bless!
Nov 06, 2015 | Samsung Washing Machines
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
When i try to start the washer code d5 shows ands chimes
Hi
The reason for d5 error is due to defective door lock switch. It is a door lock error code, more than likely a bad door latch it's an easy repair. When washer displays this code it means door is open while washer is running. Check the lid switch and striker.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Feb 02, 2011 | Washing Machines
Code D5, what is it?
A d5 error code usually means Sd. This error code is displayed when the control detects the basket has not seated on the hub or that the pressure switch has detected a Suds-lock condition. The washer will try to run a mini-clean out cycle using cold water and a 5 minute pause to clear the suds. If this cycle does not clear the display and complete the cycle the clothing may need to be rinsed by hand and then rewashed. The fault is caused by using the wrong detergent or excessive amounts of detergent.
Note: If the Hard Reset does not work, there may be an internal failure with the washer.
Dec 11, 2010 | Kenmore HE2 Plus Front Load Washer
Not sure if this is the right wasing machine that matches ours or not but we are getting a d5 error and don't know what it means
The error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle.The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly.But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem. This has to be checked to confirm the fault.Keep updated with any more queries.Thanks.
Oct 14, 2010 | Samsung WF337AA Front Load Washer
When i turn it on it beeps and the letters d5 show up
hello,
this indication is an error code saying that the door of the washer is not well luck /close
what you are to do to solve the problem is to put off the washer from the power supply then on it again after some time then open then door and close it properly with care the d5 code will be solve
thank you and thanks for using fixya.
Jul 12, 2010 | Samsung WF337AA Front Load Washer
WASHING MACHINE DOES NOT GO ON
Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
Aug 24, 2009 | LG WD-3245 Front Load Washer / Dryer
Error Code d5
It sound like a loose or a broken lid switch issue. The lid switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Good luck!
Aug 21, 2007 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
802 people viewed this question
Top Washing Machines Experts
